Bozothenutter Posted April 27, 2023 Share Posted April 27, 2023 3 hours ago, petetasker said: It's crossed my mind how these MDC's are actually going to be applied to the model. So far I've only used the Kit World 3D decals and each time I've had to resort to using glue of some sort - qre Quinta any different? Not sure I fancy having glue anywhere around the transparency or are there techniques I don't know about. Rtfm....they actually tell you to use glue. 'Decal' is a total misnomer, decalpaper is only used because it has to be printed on something, and that something needs to seperate from the printed item easily. Link to comment Share on other sites More sharing options...
petetasker Posted April 27, 2023 Share Posted April 27, 2023 31 minutes ago, Bozothenutter said: Rtfm....they actually tell you to use glue. 'Decal' is a total misnomer, decalpaper is only used because it has to be printed on something, and that something needs to seperate from the printed item easily. Not sure there's really any need for 'RTFM' as you put it. My question really was just about techniques for applying on a transparency? Link to comment Share on other sites More sharing options...
jenko Posted April 27, 2023 Share Posted April 27, 2023 I've started using MIG ultra glue (pva). Great stuff, ideal for these sort of "decals" and Eduard instrument panels. Worth a play around with. HTH Dick 1 Link to comment Share on other sites More sharing options...
amos brierley Posted April 27, 2023 Share Posted April 27, 2023 2 hours ago, petetasker said: Not sure there's really any need for 'RTFM' as you put it. My question really was just about techniques for applying on a transparency? My answer to the question is Future floor polish. 3 Link to comment Share on other sites More sharing options...
wellsprop Posted April 29, 2023 Share Posted April 29, 2023 On 07/03/2023 at 20:19, wadeocu said: My disappointment is confirmed by this pic: no CBLS. On 07/03/2023 at 22:20, Des said: Considering buying them for a non-Buccaneer project although the last time I needed a CBLS was back in the 1980s and it started life as a rather generic 1,000lb. On 08/03/2023 at 10:04, Muzz said: I was also disappointed to see there were no CBLS planned for the boxing, I thought it was a given as for some reason I believed they were included in the 1/72 version but on looking I was wrong. I'm trying to CAD the CBLS to 3D print as aftermarket for the Bucc, unfortunately, I can't find any CBLS 100 dimensions! 1 Link to comment Share on other sites More sharing options...
Muzz Posted April 30, 2023 Share Posted April 30, 2023 3 hours ago, wellsprop said: I'm trying to CAD the CBLS to 3D print as aftermarket for the Bucc, unfortunately, I can't find any CBLS 100 dimensions! There's some dimensions mentoined in this thread on the forum, not sure if you've seen it or if it will be any use to you. https://www.britmodeller.com/forums/index.php?/topic/235121583-cbls-carrier-bomb-light-stores-in-172/page/2/ I'd certainly buy a few pairs off you if you succeed! Murray Link to comment Share on other sites More sharing options...
petetasker Posted April 30, 2023 Share Posted April 30, 2023 9 hours ago, wellsprop said: I'm trying to CAD the CBLS to 3D print as aftermarket for the Bucc, unfortunately, I can't find any CBLS 100 dimensions! I’d be up for some as well if you manage to do them Pete Link to comment Share on other sites More sharing options...
Tiger331 Posted April 30, 2023 Share Posted April 30, 2023 On 3/22/2023 at 4:05 AM, wadeocu said: Stefan - The thread is a bit adrift here so let’s do a 216 thread in Cold War aircraft to discuss your options there, but I did want to address your point on the mid 80s ocu emblem here. Most definitely not yellow cutlasses per the old Model Alliance sheet. Look close at those photos you referenced and you can make it out like it is as depicted on the mid 90s Xtradecal sheet: This old sheet was a work of art and excellently researched. The fox heads look authentically hand painted. Still the best buccaneer decal sheet ever done with the exception perhaps of the excellent sheet in the new kit save for an omission or two.- Jack IIRC, this was the work of the Late Dave Howley (RIP) who did a lot of work for the aviation modelling press and Hannants in the 1990s. As an aviation enthusiast and modeller of RAF aircraft he was meticulous with his research. Link to comment Share on other sites More sharing options...
Tiger331 Posted April 30, 2023 Share Posted April 30, 2023 Just now, Tiger331 said: IIRC, this was the work of the Late Dave Howley (RIP) who did a lot of work for the aviation modelling press and Hannants in the 1990s. As an aviation enthusiast and modeller of RAF aircraft he was meticulous with his research. Also, I suspect Hannants will produce another set of Buccaneer sheets to go with the forthcoming RAF boxing of the Buccaneer S.2A/B. Link to comment Share on other sites More sharing options...
wellsprop Posted April 30, 2023 Share Posted April 30, 2023 6 hours ago, Muzz said: There's some dimensions mentoined in this thread on the forum, not sure if you've seen it or if it will be any use to you. https://www.britmodeller.com/forums/index.php?/topic/235121583-cbls-carrier-bomb-light-stores-in-172/page/2/ I'd certainly buy a few pairs off you if you succeed! Murray 45 minutes ago, petetasker said: I’d be up for some as well if you manage to do them Pete I've just found Flightpath already makes them! https://www.hannants.co.uk/product/FHP48122?result-token=vxfmT Link to comment Share on other sites More sharing options...
petetasker Posted April 30, 2023 Share Posted April 30, 2023 50 minutes ago, wellsprop said: I've just found Flightpath already makes them! https://www.hannants.co.uk/product/FHP48122?result-token=vxfmT So they do. I've just ordered a couple. Thanks Link to comment Share on other sites More sharing options...
Muzz Posted May 1, 2023 Share Posted May 1, 2023 15 hours ago, wellsprop said: I've just found Flightpath already makes them! https://www.hannants.co.uk/product/FHP48122?result-token=vxfmT Yeh, I knew that. I've had a set of their CBLS200 before. My experience is they are a pretty old and rough casting. Could still do with a modern updated version! Link to comment Share on other sites More sharing options...
petetasker Posted May 3, 2023 Share Posted May 3, 2023 On 01/05/2023 at 01:02, Muzz said: Yeh, I knew that. I've had a set of their CBLS200 before. My experience is they are a pretty old and rough casting. Could still do with a modern updated version! Arrived this morning. I think they look quite nice and very useable. 2 Link to comment Share on other sites More sharing options...
One 48 Posted May 3, 2023 Share Posted May 3, 2023 I'm really looking forward to the RAF version of this kit, should be available soon ... right? Link to comment Share on other sites More sharing options...
Stephen Posted May 3, 2023 Share Posted May 3, 2023 1 hour ago, One 48 said: I'm really looking forward to the RAF version of this kit, should be available soon ... right? According to Hannants it says November. 2 Link to comment Share on other sites More sharing options...
wadeocu Posted May 10, 2023 Share Posted May 10, 2023 Perhaps expected given that they did a similar set in 1/72, but very nice to see nonetheless: 3 Link to comment Share on other sites More sharing options...
Doccur Posted June 2, 2023 Share Posted June 2, 2023 On 10/05/2023 at 17:29, wadeocu said: Perhaps expected given that they did a similar set in 1/72, but very nice to see nonetheless: This looks lovely, but a bit frustrating they don’t offer the folded nose as a stand-alone product. Ash 1 Link to comment Share on other sites More sharing options...
Jagdtiger1 Posted June 3, 2023 Share Posted June 3, 2023 (edited) @Doccur Yeah, it is a bit of a shame that they don't sell the parts individually. I did find this smaller set which only includes the right engine and nose which seems to be roughly £20 cheaper than the full set. Hope it helps, James. Edited June 3, 2023 by Jagdtiger1 1 Link to comment Share on other sites More sharing options...
petetasker Posted June 3, 2023 Share Posted June 3, 2023 I’ve preordered. I’ll spread the parts over maybe two or three builds. Link to comment Share on other sites More sharing options...
Greg B Posted July 3, 2023 Share Posted July 3, 2023 Hmmm. According to Jadlam one of the two S.2 RAF I have ordered has been dispatched. I’ve even got tracking details. This should be interesting to see what turns up… Link to comment Share on other sites More sharing options...
VMA131Marine Posted July 4, 2023 Share Posted July 4, 2023 2 hours ago, Greg B said: Hmmm. According to Jadlam one of the two S.2 RAF I have ordered has been dispatched. I’ve even got tracking details. This should be interesting to see what turns up… Maybe the 1/72 S.2B in Operation Granby markings that was just released. The 1/48 RAF Bucc isn’t due until the Autumn. Link to comment Share on other sites More sharing options...
Greg B Posted July 4, 2023 Share Posted July 4, 2023 1 hour ago, VMA131Marine said: Maybe the 1/72 S.2B in Operation Granby markings that was just released. The 1/48 RAF Bucc isn’t due until the Autumn. That’s what I’m thinking. Unfortunately the order is very much so the 1:48 kit A12014 due in the Autumn. you never know… 1 Link to comment Share on other sites More sharing options...
Homebee Posted September 7, 2023 Share Posted September 7, 2023 (edited) Source: https://www.aerocraftmodels.com/blackburn-buccaneer-late-style-ejection-seats-for-airfix-148-kit-211-p.asp Aerocraft dedicated 3D printed ejection seats - ref. ACM48057 V.P. Edited September 9, 2023 by Homebee 6 Link to comment Share on other sites More sharing options...
71chally Posted September 26, 2023 Share Posted September 26, 2023 According to the Flory video interview with Paramjit Sembhi on the Airfix Gannet release, the RAF Buccaneer boxing is due in November. 2 Link to comment Share on other sites More sharing options...
Lord Riot Posted October 21, 2023 Share Posted October 21, 2023 Only a few weeks to go until the release of the RAF Bucc yet I still haven’t seen any of the planned markings options, has anyone!? Hoping for a grey underside XV Sqn one and a wraparound mid 80s Lossiemouth example. Can’t wait for this, just in time for Chrimbo too!! I need about three of these beauties. 1 Link to comment Share on other sites More sharing options...
