MIG 15 - Trumpeter 1:48
p?i=ddd3befaa188ed66792818422cf5ec5e
Mikoyan-Gurevich MiG 15 Bis, Red 40, 1953
I completed my model of this Soviet fighter which I finished with the colors and markings of the mount of pilot Nikolay Shkodin, who obtained five victories during the Korean war. I chose not to install the provided jet engine inside the fuselage and to display it next to the aircraft. For increased detailing, I used aftermarket seatbelt, instrument panel and main wheels from Eduard's.
p?i=412f3c0cb62ed1bbce6b6e287d613567
p?i=2ab895172654aea42a9c033e8e7f4ed2
p?i=8b7c0849e0f26574fb5a3a5c1fbc804a
The jet engine Klimov-vk1 which is provided with the kit is adequately reproduced for this scale and, as said, I am displaying it on a static stand which was scratch built.
p?i=df396b9894f407fe8c98ec16add4dd1c
p?i=aac4786aefc888b409d945dd7be1c6a0
The model was finished with mixes of Tamiya acrylic colors, while Vallejo metallic paints were used for the metallic finished parts. I sprayed the camouflage bands free-hand to obtain feathered demarcations, however, I am afraid that the obtained effect that might be a bit out of scale.
p?i=91d7c547297daab59f0b090fa7b89816
p?i=40bf64f5df6caac749a433e1b190031a
I replaced the 2 x 23 mm gun muzzles with aluminium tubes, while the muzzle of the 37 mm cannon is an Eduard replacement.
p?i=51db2883ec6fddab8aea1c05d0bd174b
I also substantially modified the oversimplified pilot seat to better reproduce the type which was used at the time of the depicted aircraft.
p?i=4fd63540da6a089368e0779a660e0bba
Panel lines were obtained by oil colors washes and other small stains with watercolor pencils.
p?i=95ccac616369c569f568870e4e352bad
This is my first Russian subject and I found it rather an interesting aircraft to build (the build log can be found under this link: MiG15 build log).
I hope that you like my final pictures.
Best regards,
Dan
  • Like 13
