keiron99 Posted January 3, 2022 Posted January 3, 2022 I've just almost completed construction of a Revell 1/72 ME 262. I have just added the wheels as the final step...and the whole model tips back! I should have thought of this but I'm not experienced and it doesn't mention anything in the instructions. From what I can tell it needs about 10 grams right at the tip of the nose for it to stand upright. Does anyone have any tips as to how I could achieve this bearing in mind the kit has now actually been built?!
Black Knight Posted January 3, 2022 Posted January 3, 2022 Drill a 3mm hole in the nose wheel bay. Start stuffing small bits of lead and blue tack through the hole with a thin pointy stick - the ubiquitous cocktail stick Keep stuffing, you can move the blue tack about with the stick, until you get a balance. You can either leave the access hole or cover it with a piece of tape or thin plastic card A handy supply to have on hand is 'Liquid Gravity'. Its micro sized steel balls. With this you pour the balls in through a hole and squirt some PVA or superglue in with them.
keiron99 Posted January 3, 2022 Author Posted January 3, 2022 (edited) Thanks. There's simply not enough space to add enough blu tack. I'll have to investigate the Liquid Gravity, (Edit - I just looked it up. Not cheap!) Edited January 3, 2022 by keiron99
Black Knight Posted January 3, 2022 Posted January 3, 2022 No, its not cheap. But you'll find it lasts a long time and you'll hardly ever use it I've had my bottle for many years and I've used very little from it. I use it only in similar forgets to yours or on builds where there just isn't room for big pieces of weight, eg in a OV-10 Bronco
Tentacles Posted January 3, 2022 Posted January 3, 2022 Other possible ideas: - clean up a piece of clear spruce to make a relatively discreet prop to go under the tail. - make a simple base & glue the nose wheel to it 2
Richard E Posted January 3, 2022 Posted January 3, 2022 Another alternative, try to find some anglers' micro lead shot (available from your local High Street Angling Supplier or on-line auction sites) and carefully pour it into the nosewheel bay in the way which @Black Knight has described. One of my father's friends shoots clay pigeons and he gave me the contents of a couple of shotgun cartridges a few years ago and I'm still making use of them. 1
dogsbody Posted January 3, 2022 Posted January 3, 2022 It does mention to add 20 grams into the nose, in Step 3. https://www.super-hobby.com/products/Me-262-A1a.html Chris 1
Pin Posted January 3, 2022 Posted January 3, 2022 - Use thick PVA glue instead of BlueTac suggested above to fix led pallets - make vignette, fix the front wheel
dnl42 Posted January 3, 2022 Posted January 3, 2022 This has happened to me a number of times, even when the instructions very clearly and unambiguously indicated nose weight was required. Fill the hole with a sprue plug. Liquid Gravity is smaller than the buckshot I've seen available, so a smaller hole will do. And PVA will do a fine job of securing it. Don't use a glue with strong outgassing as it can will melt the plastic.
stevehnz Posted January 4, 2022 Posted January 4, 2022 I'm lucky enough to have several life times supply of smallish lead shot, given to me by a friend who reloaded his shot shells. I tend to use 5 min epoxy to secure it now after reading that lead can react with PVA glue with unfortunate results, the swelling of the shot after the reaction causing bulging & cracking of the joins. I've not had this happen to me but having used PVA early on I wait with trepidation. The mentioned method of pushing shot through a small hole will work well with 5 min epoxy, mix a small amount of epoxy stir in shot then pick up & push through hope with tweezers, they will stick to previous shot & anything else in there as they drop in. Don't mix too much at once 'cause 5 minutes isn't very long, ask me how I know. Steve.
Tijuana Taxi Posted January 4, 2022 Posted January 4, 2022 Liquid gravity looks the best bet, tenner for 240g which would last for ages. Might even be able to inject it with one of the small syringes you get over the counter in a pharmacy (no needle) That would keep the hole size to a minimum which should then be easy to cover up.
keiron99 Posted January 4, 2022 Author Posted January 4, 2022 Thanks, lots of good tips. I think I'll get a little bottle.
Pin Posted January 4, 2022 Posted January 4, 2022 5 hours ago, stevehnz said: lead can react with PVA glue with unfortunate results ???? Where did you read about this? I don't see how is it possible. CA yes, PVA unlikely (unless there is a gap in my chemistry knowledge)
Dave Swindell Posted January 4, 2022 Posted January 4, 2022 2 hours ago, Tijuana Taxi said: Liquid gravity looks the best bet, tenner for 240g which would last for ages Divers lead shot, less than a tenner for a kilo
ckw Posted January 4, 2022 Posted January 4, 2022 13 minutes ago, Pin said: Where did you read about this? I don't see how is it possible. CA yes, PVA unlikely (unless there is a gap in my chemistry knowledge) I've seen this discussed in various Railway forums. Here is a pretty good explanation https://gardenrails.org/forum/viewtopic.php?t=11777 Cheers Colin 1
Pin Posted January 4, 2022 Posted January 4, 2022 7 minutes ago, ckw said: I've seen this discussed in various Railway forums. Here is a pretty good explanation https://gardenrails.org/forum/viewtopic.php?t=11777 Hm. "The ester groups of the polyvinyl acetate are sensitive to base hydrolysis and will slowly convert PVAc into polyvinyl alcohol and acetic acid" so in theory it is possible but it would require quite high humidity or contact with water for prolonged period of time.
stevehnz Posted January 4, 2022 Posted January 4, 2022 38 minutes ago, Pin said: ???? Where did you read about this? I don't see how is it possible. CA yes, PVA unlikely (unless there is a gap in my chemistry knowledge) It was mentioned quite recently in a thread. As said, I've not had it happen to me, time yet I guess. Try googling Britmodeller lead PVA, will bring up some results. I think from my reading it depends a bit on the lead purity or otherwise & I would imagine the PVA composition. For my part now, I'll stick with 5 minute epoxy. Afaik, that is safe. Steve.
Pin Posted January 4, 2022 Posted January 4, 2022 Although the article above mentions PVA and I admit there may be a slight theoretical possibility for PVA to emit acetic acid because of hydrolytic deterioration (that may require years of water contact an that would make a polymer into a goo) it does not mention that anybody had any real problem with lead/PVA combination. The post mentions UHU+lead (with UHU composition being unknown) and "lead + CA" combination that is known to be problematic. I use lead with PVA for years (the link contains photos of solving tail sitter problem when I drilled a hole in the nose, filled it with lead pallets and fixed them with PVA); no budging or any other problems are found yet. 1
stevehnz Posted January 4, 2022 Posted January 4, 2022 10 hours ago, Pin said: no budging or any other problems are found yet. & hopefully that will continue. I'm picking the even if the reaction began within the model, it may only become obvious if the lead is tight packed with no room to expand. Never the less, I'll stay with my epoxy now I think. Steve.
Mike Posted January 4, 2022 Posted January 4, 2022 At about 1mm these look similar to Liquid Gravity, and they work out a bit cheaper per ball https://www.amazon.co.uk/Stainless-bearings-Tumbling-tumbler-polishing/dp/B016N9UPKG
