muppetmic Posted January 2, 2022 Share Posted January 2, 2022 Hello I am using harder and steenback infinity CR with humbrol 90 acrylic paint. I am using a mix of aclcohol and water with a retarder and flow improver. Everytime I start to spray it works for about 10 seconds then the paint flow stops. When i investigate the paint in the nozzle is really thick. I have repeatably cleaned everything, i can see no damage to the needle. It doesnt matter how thin i make the paint it keeps happening. I would be grateful if someone can help. Mic Link to comment Share on other sites More sharing options...
Stephen Posted January 2, 2022 Share Posted January 2, 2022 I think it might be the alcohol causing the paint to thicken as water based acrylics don't respond well to alcohol, are you using the older Humbrol Acrylics or the newer range in the dropper bottle? I haven't sprayed Humbrol Acrylics for several years and it was the older one that came in the plastic pot. At the time I thinned that with Xtracrylix thinner and it worked OK. If you're using the newer acrylics (dropper bottle) then I would suggest just thin with water and add some retarder and see how that sprays. You could also try deionised water which you can buy or (much easier and cheaper) boil the kettle then let it cool down and use that to thin. HTH Link to comment Share on other sites More sharing options...
Tijuana Taxi Posted January 2, 2022 Share Posted January 2, 2022 (edited) If you are using the 0.15 needle perhaps for this paint try the 0.4 that you can get for your airbrush. Also try upping the psi although I don't know what you are using already so just a thought You could perhaps try thinning just with flow retarder, I have used that method successfully with other non airbrush specific acryllic. Edited January 2, 2022 by Tijuana Taxi Link to comment Share on other sites More sharing options...
muppetmic Posted January 2, 2022 Author Share Posted January 2, 2022 4 hours ago, Stephen said: I think it might be the alcohol causing the paint to thicken as water based acrylics don't respond well to alcohol, are you using the older Humbrol Acrylics or the newer range in the dropper bottle? I haven't sprayed Humbrol Acrylics for several years and it was the older one that came in the plastic pot. At the time I thinned that with Xtracrylix thinner and it worked OK. If you're using the newer acrylics (dropper bottle) then I would suggest just thin with water and add some retarder and see how that sprays. You could also try deionised water which you can buy or (much easier and cheaper) boil the kettle then let it cool down and use that to thin. HTH Thanks I will try leave the alchoohol out and just add demineralised water Link to comment Share on other sites More sharing options...
Mike Posted January 2, 2022 Share Posted January 2, 2022 Just a quick extra to what's already been said. Humbrol DEFINTELY doesn't like neat alcohol. I've also had issues with H&S airbrushes and Humbrol, as at the time their pigment grind was something akin to moon rocks I couldn't even get it to spray reliably through a 0.35mm nozzle, nevermind my usual 0.2mm. As another poster has suggested, try 0.4mm if you have it, and work your way down. You may also get some positive feedback from adding some flow improver to your paint. Just a drop in the cup, mixed in, and it will help reduce drying on the tip of the needle. Also, try to blow just air as little as possible while you're spraying, as it will encourage any paint on the needle to dry, leading to the obvious issue 1 Link to comment Share on other sites More sharing options...
muppetmic Posted January 2, 2022 Author Share Posted January 2, 2022 2 hours ago, Mike said: Just a quick extra to what's already been said. Humbrol DEFINTELY doesn't like neat alcohol. I've also had issues with H&S airbrushes and Humbrol, as at the time their pigment grind was something akin to moon rocks I couldn't even get it to spray reliably through a 0.35mm nozzle, nevermind my usual 0.2mm. As another poster has suggested, try 0.4mm if you have it, and work your way down. You may also get some positive feedback from adding some flow improver to your paint. Just a drop in the cup, mixed in, and it will help reduce drying on the tip of the needle. Also, try to blow just air as little as possible while you're spraying, as it will encourage any paint on the needle to dry, leading to the obvious issue thanks mike, so just plain water and retardent Link to comment Share on other sites More sharing options...
Mike Posted January 3, 2022 Share Posted January 3, 2022 20 hours ago, muppetmic said: thanks mike, so just plain water and retardent You could try it with just water (deionised as someone else suggested), then add retardant if you're still getting drying on the tip Link to comment Share on other sites More sharing options...
