Hallo
WNW Information on this kit
This is my second WW1 bomber in 1/32.
The AEG was my first.
Considering all my 1/32 builds from WNW I did, so this one caused me some more headache as I was used.
The building process showed me, that there are some issues where I think the designer of the kit was absent.
The cooling pipes running from the engine to the cooler at the front strut are wrong in transverse distance.
You must cut them, otherwise the strut would crack.
The other thing is many important details are not shown at all in the instructions. Instead of this the guns are shown multiple times.
The pivot point of the rudder is such an item.
On the other hand the outer struts.
They have cables running vertically twice, in the front and rear.
What for? There is no explanation in the instruction.
For lighting or  Bowden cables.
If the latter, then for assembly or disassembly the wing.
If you decide to make such a model, be sure that you are firm with all rigging techniques required.
I did it, as you can find on my threats.
Already posted couple of times.
Well, the next time will be a modelling break for one month.
Since I will be engaged with my digital model railway in H0, where most locomotives are upgraded with sound.
Some programing is needed and some mapping of functions too.
Happy modelling
Happy New Year 2022
  • Like 34
  • Thanks 4
Great work, I was going to comment on the propellors as well, they look incredible, very realistic.
Propellers are made with Mr. Gunze RLM 79 and oil. Oil color put on a carton, wait a minute, and than use a brush and not diluted prepared as described oil color and brush. Like dry dot. After one day you continue with a clear varnish.
Happy modelling
Thank you all for your replies.
It is a good boost to continue.
Albatros B.II and Dh.2 are intended in February to get started.
Happy modelling
Whilst the subject is not my cup of tea,   it’s very nice indeed, good effort with the prop finishing effect’s.    Happy New Year.  😉
Soo... a famous Nutswings Gotha. Superb work on this model. The wood grain on the propeller is very effective. Love that sagey green.
Lovely work on your Gotha -
As others have already said, great wood effect on props
Regards
Dave
Thank you so much for your nice replies.
If anyone needs help for WW1 a/c, so feel free to contact me.
Happy modelling
