maxwellbest Posted December 30, 2021 Share Posted December 30, 2021 Hi all, title says it all. My attempts at trying to repair/join the aforementioned track with Super Glue as well as Tamiya glue have failed. The tension on the track is such that nothing will hold the join-where the break is seems to have gotten worse. Currently held with Gaffer tap which is a bit annoying, given that the rest of the build has gone reasonably well. Can spares be ordered? Are there alternatives? What glue have others used to join these tracks? It says use instant glue in the instructions, a cursory sweep around the internet seems to belie this... Or just live with it...thanks in advance Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted December 30, 2021 Share Posted December 30, 2021 Hello Maxwell the link is only an example. Its an online shop in the U.S., It should give you ideas as to whats available. You should be able to find a local or maybe Asian supplier thats closer ? https://spruebrothers.com/search-results-page?q=panther+track+1%2F35 Dennis Link to comment Share on other sites More sharing options...
Jasper dog Posted December 30, 2021 Share Posted December 30, 2021 Hi, couple of suggestions: Repair the break with black or a suitably coloured sewing thread, ideally if the repair is on the bottom it won't be noticeable. To give it more support glue the track to road wheels themselves either side of the join. (Tiny spot of superglue should work.) If the build warrants the extra expenditure there are lots of aftermarket tracks available from expensive individual link metal ones to slightly cheaper plastic ones. Good luck Darryl Link to comment Share on other sites More sharing options...
maxwellbest Posted December 30, 2021 Author Share Posted December 30, 2021 Thanks for your timely replies...suggestions. Link to comment Share on other sites More sharing options...
Modelholic Posted December 30, 2021 Share Posted December 30, 2021 Do as Jasper suggests and hide the join behind the schurzen plate. make your holes at least 1 link away each side of the break I've also used staples from a paper stapler in the past. Tom Link to comment Share on other sites More sharing options...
Rob G Posted December 30, 2021 Share Posted December 30, 2021 If you decide to replace the track, have a look here. Highly recommended, especially if you create an account. https://www.bnamodelworld.com/index.php?route=product/search&search=Panther+g+track&fa1=1%2F35&fq=1 The set by Bronco is certainly worth considering for 20 bucks. Link to comment Share on other sites More sharing options...
