AliGauld Posted December 24, 2021 Share Posted December 24, 2021 Another one that has been lingering in the stash. I have very fond memories of my friend building the Airfix Sunderland when I was younger. Always wanted one but didn't have the space. Still not sure I have. I was going to build this for my nephew but he has now emigrated. It will still be the version he wanted though. I have bookmarked @tonyot 's fabulous build and will be referring regularly to that and his magazine article in January 2021 Scale Aircraft Modelling. I need the help and will have to look to see which portholes to blank off and fill. The only bit of aftermarket but a necessity for this. I will try to get some plastic cut tomorrow. Thanks for looking, Cheers, Alistair 30 Link to comment Share on other sites More sharing options...
billn53 Posted December 24, 2021 Share Posted December 24, 2021 I wish I had the space . . . . 2 Link to comment Share on other sites More sharing options...
AliGauld Posted December 24, 2021 Author Share Posted December 24, 2021 19 minutes ago, billn53 said: I wish I had the space . . . . Still not sure I have but what the hey, going for it anyway. Cheers, Alistair 2 Link to comment Share on other sites More sharing options...
GREG DESTEC Posted December 24, 2021 Share Posted December 24, 2021 Should be interesting! I have the old Airfix kit sitting on the SoD. I started it about 5 years ago with my youngest son, and it's still not finished 😤 I suggest you start clearing a space for it now 😜 Cheers Greg 2 Link to comment Share on other sites More sharing options...
AliGauld Posted December 24, 2021 Author Share Posted December 24, 2021 15 minutes ago, GREG DESTEC said: Should be interesting! I have the old Airfix kit sitting on the SoD. I started it about 5 years ago with my youngest son, and it's still not finished 😤 I suggest you start clearing a space for it now 😜 Cheers Greg Have to clear enough space on the bench first. Cheers, Alistair 1 Link to comment Share on other sites More sharing options...
tonyot Posted December 24, 2021 Share Posted December 24, 2021 Good Luck Alistair,.......all I can advise is that you prepare your parts well and maybe treat it like a vacuform,....... the result is worth it and from what I`ve seen it is well within your capability,..... I had to walk away at times,..... then come back to it after a break. Cheers Tony 1 Link to comment Share on other sites More sharing options...
AliGauld Posted December 24, 2021 Author Share Posted December 24, 2021 7 minutes ago, tonyot said: Good Luck Alistair,.......all I can advise is that you prepare your parts well and maybe treat it like a vacuform,....... the result is worth it and from what I`ve seen it is well within your capability,..... I had to walk away at times,..... then come back to it after a break. Cheers Tony Thanks Tony for your advice and your confidence. I knew from your build that it was going to be more than a challenge, as I recall it fought you all the way. Am I ready for it. I don't know but I'll give it a go. I will walk away at times. I have found that usually works well. Cheers, Alistair 2 Link to comment Share on other sites More sharing options...
bigbadbadge Posted December 24, 2021 Share Posted December 24, 2021 Excellent, looking forward to this one Alistair. Chris 1 Link to comment Share on other sites More sharing options...
AliGauld Posted December 24, 2021 Author Share Posted December 24, 2021 21 minutes ago, bigbadbadge said: Excellent, looking forward to this one Alistair. Chris Could be a long haul. Cheers, Alistair 1 Link to comment Share on other sites More sharing options...
LDSModeller Posted December 25, 2021 Share Posted December 25, 2021 6 hours ago, AliGauld said: I have very fond memories of my friend building the Airfix Sunderland when I was younger. Always wanted one but didn't have the space. Still not sure I have. Hi Alistair Have this kit on the brew at my bench Quick warning for you, depending on which version of the Mk V/GR5/MR5 you want to build, Special Hobby don't provide the correct parts for the latter versions (from 1950-59 RAF Service) I have added a couple of links for you, one a kit Review I did, and my WIP build, if they are any help? Special Hobby Kit review Special Hobby Kit Build - RNZAF MR5 One main issue interior wise is the Rear Deck, that Special hobby provide, and its placement in the fuselage per their instructions per photo below What it actually looks like on the real aircraft Look forward to your build, if you ever need any reference photos/technical knowledge, just sing out Regards Alan 11 2 Link to comment Share on other sites More sharing options...
AliGauld Posted December 25, 2021 Author Share Posted December 25, 2021 2 hours ago, LDSModeller said: Hi Alistair Have this kit on the brew at my bench Quick warning for you, depending on which version of the Mk V/GR5/MR5 you want to build, Special Hobby don't provide the correct parts for the latter versions (from 1950-59 RAF Service) I have added a couple of links for you, one a kit Review I did, and my WIP build, if they are any help? Special Hobby Kit review Special Hobby Kit Build - RNZAF MR5 One main issue interior wise is the Rear Deck, that Special hobby provide, and its placement in the fuselage per their instructions per photo below What it actually looks like on the real aircraft Look forward to your build, if you ever need any reference photos/technical knowledge, just sing out Regards Alan Many thanks for you kind offer Alan, You can be sure that I will call on your expertise when I am struggling. Cheers, Alistair Link to comment Share on other sites More sharing options...
Jonners Posted December 25, 2021 Share Posted December 25, 2021 11 hours ago, billn53 said: I wish I had the space . . . . ...and time! I've long thought about a South African Mk5, but Real Life simply hasn't allowed it (or any other modelling for the last year, unfortunately.☹). Looking at those sprue photos, Alistair, my first thought was "Blimey, that's a lot of parts!". Then the penny dropped! I'll be watching your progress with interest. Jon 1 Link to comment Share on other sites More sharing options...
AliGauld Posted December 25, 2021 Author Share Posted December 25, 2021 2 hours ago, Jonners said: ...and time! I've long thought about a South African Mk5, but Real Life simply hasn't allowed it (or any other modelling for the last year, unfortunately.☹). Looking at those sprue photos, Alistair, my first thought was "Blimey, that's a lot of parts!". Then the penny dropped! I'll be watching your progress with interest. Jon Welcome aboard. It may take a while. Cheers, Alistair Link to comment Share on other sites More sharing options...
Dandie Dinmont Posted December 25, 2021 Share Posted December 25, 2021 8 minutes ago, AliGauld said: It may take a while. Nah, at the rate you build it’ll be done by Hogmanay. looking forward to this. Craig. 3 Link to comment Share on other sites More sharing options...
AliGauld Posted December 25, 2021 Author Share Posted December 25, 2021 1 hour ago, Dandie Dinmont said: Nah, at the rate you build it’ll be done by Hogmanay. looking forward to this. Craig. Just not happening. I'm back at work tomorrow, so will have to slow down a bit. Cheers, Alistair 1 Link to comment Share on other sites More sharing options...
mackem01 Posted December 25, 2021 Share Posted December 25, 2021 Ooh got to watch this one for two reasons: 1/ I do love a flying boat. 2/ originally from..................guess! 1 Link to comment Share on other sites More sharing options...
AliGauld Posted December 25, 2021 Author Share Posted December 25, 2021 2 minutes ago, mackem01 said: Ooh got to watch this one for two reasons: 1/ I do love a flying boat. 2/ originally from..................guess! Well, based on your username I might hazard a guess at somewhere by the River Wear. Welcome aboard. Cheers, Alistair Link to comment Share on other sites More sharing options...
mackem01 Posted December 25, 2021 Share Posted December 25, 2021 You get bonus points too. 1 Link to comment Share on other sites More sharing options...
Dandie Dinmont Posted December 25, 2021 Share Posted December 25, 2021 5 hours ago, AliGauld said: I'm back at work tomorrow, so will have to slow down a bit. There won’t be much going on surely? You can get some of the fiddly bits done! Craig. 1 Link to comment Share on other sites More sharing options...
AliGauld Posted December 25, 2021 Author Share Posted December 25, 2021 34 minutes ago, Dandie Dinmont said: There won’t be much going on surely? You can get some of the fiddly bits done! Craig. Already started fiddly bits. This lot took me 90 minutes. That's it I'm afraid. I've opened up the waist gun doors as well. Need to plan the painting for the innards as there are various colours. Thanks for looking, Cheers, Alistair 11 Link to comment Share on other sites More sharing options...
AliGauld Posted December 25, 2021 Author Share Posted December 25, 2021 As I had the airbrush out I gave the bits a coat of Nato Black or Aluminium. Unfortunately I've run out of Flat Aluminium so I'm going to have to hit Hobbycraft tomorrow in the hope that they have some. Some hope. If not I'll use the Xtreme metals and dull it down a tad. Thanks for looking, Cheers, Alistair 11 Link to comment Share on other sites More sharing options...
alt-92 Posted December 26, 2021 Share Posted December 26, 2021 Coming along for the ride Yes it's big, and I've heard it to be a handful but it didn't stop me from having one in the stash - even if like many finding a good spot may end up being an additional challenge 1 Link to comment Share on other sites More sharing options...
AliGauld Posted December 26, 2021 Author Share Posted December 26, 2021 1 hour ago, alt-92 said: Coming along for the ride Yes it's big, and I've heard it to be a handful but it didn't stop me from having one in the stash - even if like many finding a good spot may end up being an additional challenge Welcome aboard, glad to have you along. At least you will be able to see the pitfalls to avoid whether operator error or not. If it helps I'll be happy. Cheers, Alistair Link to comment Share on other sites More sharing options...
bigbadbadge Posted December 26, 2021 Share Posted December 26, 2021 Excellent great to see this one underway Alistair. Great start Chris 1 Link to comment Share on other sites More sharing options...
Lewis95 Posted December 27, 2021 Share Posted December 27, 2021 Oooh gotta love a Sunderland! I, like you, seem to have an affinity for big kits but not the space for them. Still, I have 72nd Bear H and a Valkyrie on the shelf after purchasing them both last year. 1 Link to comment Share on other sites More sharing options...
