Airfix Vampire FB5
Not quite shake & bake but quite pleasing for all that.  The joining of the upper & lower fuselage/wing halves was quite trying, a bit of filler around the intakes & I don't see how the windscreen fits without shaving a bit of material off the base of the gunsight!  A tail sitter & as I didn't have any depleted uranium lying around I used lead fishing weights but sadly it was impossible to squeeze in enough to keep it on it's nose wheel!  I built it as an FB5, using the expended undercarriage legs & flat wing tips (the kit includes a pair of the latter but tbf I found them a bit too thin so I attached the rounded F3 tips, then cut & sanded them to shape before adding the clear navigation lights from the kit).  Decals from an old Xtradecal sheet for 20 squadron.  I dropped the flaps & opened the air brakes which may not be commonly seen on the ground but the Vampire is quite a clean airframe & I simply wanted to add a bit of visual interest!  Certainly looks nice when completed.
C2EC69B0-F309-4FD7-982D-93B01794716E 0C01D7D9-AD71-4205-911A-A1DBDFE5B324 D56AF6C2-BFEC-4190-8078-FF8B31DA6276 94865EDF-8AD8-405C-8E42-281D03987307 94865EDF-8AD8-405C-8E42-281D03987307 9A6BBFE6-60E0-4A18-9085-C2311858A0D3
