fmichelsen Posted December 16, 2021 Share Posted December 16, 2021 It's been a while since my last build in here, so I'm a bit excited to get started. This helicopter will be a part of my Iranian fleet in 72nd scale. I've ordered some new decals for it, and they should be on their way in the mail, but I could'nt wait for them to arrived, so now its time to begin The kit itself should be fine, it is a older kit, with raised panellines, but they look very sharp, so hopefully I can make it work There is however alot of flash in someplaces, and the canopy does not look that good, but I believe it should be possible to make it look decent Regarding the decals, they look terrible. Very very yellow. Hopefully I dont have to use them, or I'll have to check my spare box for others The box: The content of the box; Close-up of the decals.... Time to get started 4 Link to comment Share on other sites More sharing options...
k5054nz Posted December 18, 2021 Share Posted December 18, 2021 Excellent! Iranian choppers are cool, I always enjoy seeing them. Is there a 214ST in your future? 1 Link to comment Share on other sites More sharing options...
fmichelsen Posted December 19, 2021 Author Share Posted December 19, 2021 11 hours ago, k5054nz said: Excellent! Iranian choppers are cool, I always enjoy seeing them. Is there a 214ST in your future? Yeah I really like them, think they look cool in those colours About the 214ST, I would love to make one, but I believe it would demand some serious scratchbuilding skills to make one, since, as far as I know, there is no kit in 1/72 scale for it. 1 Link to comment Share on other sites More sharing options...
fmichelsen Posted December 19, 2021 Author Share Posted December 19, 2021 I build the cockpit, OOB. The seat are really bad, looks more like a wingback chair for a livingroom, than a seat in a helicopter, I've made some simple seatbelts of tamiyatape. Should I ever build another one, I would buy some aftermarket ones. The plastic in this kit is very "hard". When cutting it, it snaps sometimes. The front controllever snapped 2 places Took some care to fix it, specially since the "middelpieces" were completly lost to the carpet monster, so made at new part of stretched sprue. The fit is however excellent, no gaps or need to use force to glue the fuselage parts together The chairs. Since this picture was taken, I've given it a wash, and a bit detail painting. Pictures of that next time. Cockpit again. Slight sight of the instrument panel. The decals did not fit that well, so had to cut it in several pieces to fit, but turned out okay The fuselage joined together - superb fit 1 Link to comment Share on other sites More sharing options...
Gondor44 Posted December 19, 2021 Share Posted December 19, 2021 Very interesting, and I have one of those in my stash too. Gondor 1 Link to comment Share on other sites More sharing options...
fmichelsen Posted December 19, 2021 Author Share Posted December 19, 2021 So far this kit have not been to difficult, and now it is ready for a grey primer Hopefully not to many mistake will turn up I decided not to glue many part to the fuselage since it feels like a fragile set, so they will be painted seperately, then mounted The main body - some mr. surfacer was need. Specially around til back og the canopy Some of the part - to be primed soon 2 Link to comment Share on other sites More sharing options...
Lewis95 Posted December 19, 2021 Share Posted December 19, 2021 Looking good buddy. In regards to the Mr Surfacer, do you use this as a putty and sand back or are you using thinners to wipe it flush? 1 Link to comment Share on other sites More sharing options...
fmichelsen Posted December 19, 2021 Author Share Posted December 19, 2021 7 minutes ago, Lewis95 said: Looking good buddy. In regards to the Mr Surfacer, do you use this as a putty and sand back or are you using thinners to wipe it flush? I've used thinner, specially on this one, with it's raised panellines, I'm trying to avoid sanding as much as possible Link to comment Share on other sites More sharing options...
fmichelsen Posted December 19, 2021 Author Share Posted December 19, 2021 I just discovered that it would be a "tail-sitter". Luckily I havent put on any paint yet I managed to take the nose of it with out damaging anything, fill it with lead, then glue it on again. Onve the glued is set, it go over it again with som mr. surfacer Disaster avoided Link to comment Share on other sites More sharing options...
Lewis95 Posted December 19, 2021 Share Posted December 19, 2021 4 hours ago, fmichelsen said: I've used thinner, specially on this one, with it's raised panellines, I'm trying to avoid sanding as much as possible Do you find the thinner method works well? Would you mind describing your method from the top? I'm still sanding away like a badger after multiple applications Link to comment Share on other sites More sharing options...
fmichelsen Posted December 19, 2021 Author Share Posted December 19, 2021 2 hours ago, Lewis95 said: Do you find the thinner method works well? Would you mind describing your method from the top? I'm still sanding away like a badger after multiple applications For sure. It's quite simple, fill the gap with Mr. Surfacer 500, normally I use a old brush or a toothpick, leave it to dry for about a hour (if longer, it will become more difficult to remove). Then I apply some Mr Color Thinner to a cottonswap, and starts to wipe over it, and after some time, it becomes softer and sticks to the cottonswap, except for what's left in the gap. Hope that it can help you 1 Link to comment Share on other sites More sharing options...
k5054nz Posted December 20, 2021 Share Posted December 20, 2021 Cobra's looking great! 16 hours ago, fmichelsen said: About the 214ST, I would love to make one, but I believe it would demand some serious scratchbuilding skills to make one, since, as far as I know, there is no kit in 1/72 scale for it. I recently saw a scratchbuild on, I believe, a Japanese Facebook page and it was amazing. Hopefully it's possible to track down that modeller so you can compare notes. If I happen upon the model again I'll post it for you. 1 Link to comment Share on other sites More sharing options...
Lewis95 Posted December 20, 2021 Share Posted December 20, 2021 13 hours ago, fmichelsen said: For sure. It's quite simple, fill the gap with Mr. Surfacer 500, normally I use a old brush or a toothpick, leave it to dry for about a hour (if longer, it will become more difficult to remove). Then I apply some Mr Color Thinner to a cottonswap, and starts to wipe over it, and after some time, it becomes softer and sticks to the cottonswap, except for what's left in the gap. Hope that it can help you Ah excellent. Thank you very much Albeit, the current gaps on my Dak require PPP but I will retain that knowledge! Link to comment Share on other sites More sharing options...
fmichelsen Posted December 21, 2021 Author Share Posted December 21, 2021 Got it primed, and saw many many flaws. There where quite large cracks and gaps needing filler. So I gave it som more mr surfacer, and wiped it of with thinner, and most of the primer came of as well So after quite a lot of sanding to make sure everything was smooth, I primed it again, and postshaded it with some black. Next up, the sand colour 2 Link to comment Share on other sites More sharing options...
