HMS King George V 1/350
Rich75
5 hours ago, thekz said:
Thanks for sharing this, much appreciated, there's a lot to take in there ! I'd be interested to know if anyone else finds it difficult to navigate that site though, don't know if maybe it's not suitable for a smart'ish phone....
Yeah, combining web surfing with windsurfing doesn't always work)
In my opinion, full-fledged internet surfing is possible only from a desktop computer with a large monitor.
By the way, let me give you one more piece of advice: use different search engines. Yandex (I hope it is not blocked) gives the link I sent you as the third result when you search for "radar type 279b". Google does not give it at all!
So Russian things sometimes work! I also advise you not to forget about Yahoo
  • 5 weeks later...
Hi all, small update so I can ask for some advice more than anything, I decided to go back (literally) to the shelter deck because I want to get the main parts of the ship done before I finish the masts and I was waiting for the kagero plans to turn up while I did the w/t office. If anyone can help I'd like to ask what the structure circled behind the pom-pom director might likely be? I'd like to make it slightly more detailed if I can so it would be great if someone could shed some light on it. Everything I added so far I've tried to use pictures to make a reasonable attempt at but I can't find any of these, I don't like to just guess so any help is greatly recieved,
2023-10-01_06-52-53
Thank you and thanks for looking in
Don't have a copy of the original plans, but considering the location I'd guess it's a pompom RU magazine (the space below the upper bridge pompoms is also used as an RU magazine). NMM has a GA online but not at a legible resolution...
Thank you that's really useful, I may put some doors there then, maybe a vent ? There's some pictures where you can almost see something.
Using this as a reference from HMS Belfast...
2023-10-02_08-13-13
I think I'll put a small hatch at the bottom of the director too.
Thank you, that's really useful. I think I'll put a couple of doors there. There's some pictures where you can almost see. Using this pic from HMS Belfast..
2023-10-02_08-13-13
I might put a small hatch at the bottom of the director as well, although I'm not sure if it looks quite original or not?
So, I just thought of opening Ian Buxton's Duke of York's book... there's a small GA in there as well, but, printed much smaller than the other plans. The print is tiny and grainy but it seems like it reads Radar Office (so a small room with equipment for the pompoms?) The plans indicate a door at the funnel's side, as far aft possible, with the hinge bow-side.  The small structure in centre between the pompoms has its fwd compartment as 'Ru MAG' (I think :) ). Could upload a scan for some pixel interpretation....
Well that's interesting! If you can upload the scan that would brilliant, thank you for looking into it I really appreciate that
10 hours ago, Zoran Srb said:
You are really going above and beyond.... I admire your perseverance and hope you see her through... Cheers...
Thank you, I'll do my best, I feel I'm making reasonable progress with her now
  • 5 months later...
Hi all, been a long time since my last update, I haven't given up or lost interest in KGV, personal problems took over I'm afraid. Anyway I thought I'd share where last got to and hopefully at some point soon I can restart the build.
I had decided to add some details into the shelter deck and also make a start on the boat deck. If you look at pictures of KGV there aren't many of the shelter deck in the later configuration so when @foeth shared the pictures of DOY a while back it gave me some great rreferences. He also very kindly gave me an idea of what I was looking at in them so many thanks @foeth.
I started by going back to the kit boiler room vents which I'd built quite early on, I didn't like them so much, so I took inspiration from @PeterMachin and his excellent KGV build and had a go at making them a bit better..
20231022_152226
They were tricky to unstick, sorry for the lack of before photo, after that shelter deck, I added some vents to the engine room vents under the pom pom directors
20231126_184050
 I've also removed the PE around the the aft most director and tried to scratch the larger box structure around it and made a fog light and platform from one of the kit signal lamps and some spare PE
20231126_184016
Also added the heat shields around the funnels..
20231112_192514
20231112_192427
 And also added what I believe is a water tank under the upper ammo lockers
20231126_183810
And some gussets under where the cranes are mounted
20231126_184241
After that I removed the kit gussets from the boat deck and added some of my own, I think there were too many on the kit and also the kagero plans too so I used the Allan C Green photos for reference
20231112_192725
Thanks for looking in, I've missed you all too! so hopefully have some more to share soon, cheers
