Boydie Posted February 4, 2022 Share Posted February 4, 2022 Good job on sanding the hull, I remember the seam line being pretty thick on mine too. Which year are you going to present her in? Link to comment Share on other sites More sharing options...
Rich75 Posted February 4, 2022 Author Share Posted February 4, 2022 3 hours ago, Boydie said: Good job on sanding the hull, I remember the seam line being pretty thick on mine too. Which year are you going to present her in? Thank you it took a while but it's all good for me to learn from, I'll be going for the late 44 scheme my colourcoats turned up today so I can get into it now, I see yours is coming together nicely too Link to comment Share on other sites More sharing options...
Boydie Posted February 5, 2022 Share Posted February 5, 2022 17 hours ago, Rich75 said: Thank you it took a while but it's all good for me to learn from, I'll be going for the late 44 scheme my colourcoats turned up today so I can get into it now, I see yours is coming together nicely too Cheers, I've been evicted from my man cave just now as it's been used home office for a few days. But I'll get back into it soon enough. Are you thinking about detailing the hull plating? Link to comment Share on other sites More sharing options...
mick Posted February 5, 2022 Share Posted February 5, 2022 look forward to you build Link to comment Share on other sites More sharing options...
Rich75 Posted February 5, 2022 Author Share Posted February 5, 2022 1 hour ago, Boydie said: Cheers, I've been evicted from my man cave just now as it's been used home office for a few days. But I'll get back into it soon enough. Are you thinking about detailing the hull plating? Yes I will give it a go, been looking at as many photos as possible to get an idea of how it looked theres a few in dry dock which are pretty good and of course there's yours for ref so I shouldbe ok. Link to comment Share on other sites More sharing options...
Rich75 Posted February 5, 2022 Author Share Posted February 5, 2022 6 hours ago, mick said: look forward to you build Thank you for looking in Link to comment Share on other sites More sharing options...
Rich75 Posted February 8, 2022 Author Share Posted February 8, 2022 Hi all, the last couple of days have been spent sanding the decks, dry fitting, sanding again and so on until I was happy they fitted nicely, managed to get them fairly flush in the end and then moved on to removing some of the mouldings that are to be replaced with PE. I found the anchor chains were quite tricky to remove and I left some nicks in the plastic were I didn't really want any but some dissolved putty seems to have done the trick there, so all good, some before and after Got the holes for the pedestals marked out and drilled and set the nuts in as well And then I got the decks glued into place And finally to end my day I put one piece of PE on,as a final whistle if you like! Thanks for looking in 10 Link to comment Share on other sites More sharing options...
Rich75 Posted February 9, 2022 Author Share Posted February 9, 2022 Hi all I spent a few hours today just getting some PE parts on, dont think it's too bad for a first attempt but my eyes ache not much to show for the time spent but it does take a while so the most important thing to me is that they're straight, my plan is to get the deck done so I can paint the hull and all the fittings before fitting the wooden deck so there's a fair bit of work ahead,thanks for looking in 2 Link to comment Share on other sites More sharing options...
MRMRL Posted February 9, 2022 Share Posted February 9, 2022 Nice start you've made on the KGV, looking forward to seeing how she progresses. Link to comment Share on other sites More sharing options...
robgizlu Posted February 9, 2022 Share Posted February 9, 2022 The etch details will make a big difference in the end - Good job removing that anchor chain Rob Link to comment Share on other sites More sharing options...
Rich75 Posted February 9, 2022 Author Share Posted February 9, 2022 Thanks guys much appreciated Link to comment Share on other sites More sharing options...
Rich75 Posted February 11, 2022 Author Share Posted February 11, 2022 (edited) Hi all, some time later and I have pretty much all the small hatches and doors on the deck fittings, I lost count at 70 something so I decided to start on something smaller! I wasn't to happy with the 3rd upright part from left so I took it off and did it again Then I got it into place, I decided to do the outside one first to get the gap right for the next one that attaches to the turret (barbette?) Unfortunately I can see the hatches better in the photos than through my eyeballs! So now I see a few wonky hatches I'll have to correct when my eyes have had a rest, time consuming but worth it I hope, thanks for looking in Edited February 11, 2022 by Rich75 Typo 4 Link to comment Share on other sites More sharing options...
Boydie Posted February 11, 2022 Share Posted February 11, 2022 Great job so far, you're bashing through it. Careful with those upstands though, you might find putting the wooden deck on quite hard and you might have to remove them again to get the deck in the right position. 1 Link to comment Share on other sites More sharing options...
Rich75 Posted February 11, 2022 Author Share Posted February 11, 2022 50 minutes ago, Boydie said: Great job so far, you're bashing through it. Careful with those upstands though, you might find putting the wooden deck on quite hard and you might have to remove them again to get the deck in the right position. Hmmm, maybe fit them after then you reckon? Link to comment Share on other sites More sharing options...
Faraway Posted February 12, 2022 Share Posted February 12, 2022 I’ve only used one wooden deck, on my Graf Spee, and I would be very wary about sticking stuff to the deck, prior to fitting the wood. If you remove all the little bits of wood, on the deck, where hatches etc go, it’ll give you a better idea of what you can position the deck over and what needs to go on to the deck. Especially those breakwaters, if you’ve not got the uprights in EXACTLY the right place, I think it could make fitting the deck nigh on impossible. Jon 3 1 Link to comment Share on other sites More sharing options...
Boydie Posted February 12, 2022 Share Posted February 12, 2022 11 hours ago, Rich75 said: Hmmm, maybe fit them after then you reckon? Yes, I found this out the hard way a few year ago with my first ship kit. 1 1 Link to comment Share on other sites More sharing options...
Rich75 Posted February 12, 2022 Author Share Posted February 12, 2022 Hi all, I took the advice and removed the breakwater, it came away relatively unscathed! not much spare time today so tried adding some portholes, thanks for the advice, always appreciated thanks for looking 3 Link to comment Share on other sites More sharing options...
steve5 Posted February 12, 2022 Share Posted February 12, 2022 nice job so far , I'd be very careful about relying in the wood deck glue , I've had a few that came away after a few days . 1 Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted February 13, 2022 Share Posted February 13, 2022 On 2/12/2022 at 4:05 AM, Rich75 said: Unfortunately I can see the hatches better in the photos than through my eyeballs! Gidday, I think many of us have found that close up photos point out little issues that plain eyeballs don't. I certainly have. All those PE hatch covers and scuttles would drive me bonkers but you're doing well with them. Regards, Jeff. 1 Link to comment Share on other sites More sharing options...
Rich75 Posted February 13, 2022 Author Share Posted February 13, 2022 Hi all, had a break from tiny PE today while I wait for some thinner ca to turn up, so I just spent some time going over the (several) sets of instructions before I start putting the superstructures together Can't have enough diagrams can you! Then made a start on this I removed the small hatches and doors and the plastic shield from the former boat deck, surprised there's no ladders in the pe sets for this assembly that I can see, unfortunately I have to go back to work this week after a covid enforced week off so progress will slow down now thanks for looking in 4 Link to comment Share on other sites More sharing options...
Rich75 Posted February 20, 2022 Author Share Posted February 20, 2022 Hi all, not much time spare this weekend but I have managed to get one side of the scuttles and porthole covers on, the scuttles especially are pretty fiddly aren't they, id be interested to hear how everyone else puts them on? at the moment I am unable to post any pictures as I can't sign in to Flickr so sorry for that hopefully be sorted shortly, otherwise at least I'm making progress, thanks for looking in 1 Link to comment Share on other sites More sharing options...
Boydie Posted February 21, 2022 Share Posted February 21, 2022 10 hours ago, Rich75 said: Hi all, not much time spare this weekend but I have managed to get one side of the scuttles and porthole covers on, the scuttles especially are pretty fiddly aren't they, id be interested to hear how everyone else puts them on? at the moment I am unable to post any pictures as I can't sign in to Flickr so sorry for that hopefully be sorted shortly, otherwise at least I'm making progress, thanks for looking in I've done it a few different ways. For the super glue I've used a slow drying one which allows me to move the PE to the right position. To apply that glue I either use an old scalpel or a small length of copper wire, to keep down on the excess. To put the PE into position I sometimes use a china pencil, this quite handy if you're struggling to pick up the small PE with tweezers or whatever else. But this can leave a residue from the pencil on the PE which needs to be cleaned up. Recently though I've just been using a good quality pair of tweezers, maybe it's down to practice now but I can lift tiny bits of PE quite easily and not have it ping off and for it to be never found again. Link to comment Share on other sites More sharing options...
robgizlu Posted February 21, 2022 Share Posted February 21, 2022 Tiny bit of Gel CA on the etch porthole OR the "hole" - porthole on end of cocktail stick which locates into the (drilled hole) and ease off stick with tweezers. HRH Rob Link to comment Share on other sites More sharing options...
Rich75 Posted February 21, 2022 Author Share Posted February 21, 2022 Thanks guys I'll see how the other side goes now, tbh I think it looks pretty good to my eyes, then you take a photo and it looks like I put the ca on with a trowel! I know pictures highlight everything, just want it to look right, thanks again Link to comment Share on other sites More sharing options...
Rich75 Posted February 22, 2022 Author Share Posted February 22, 2022 I worked out how to post some pictures quite an achievement for a non techy, definitely looks like a fair bit of CA around the pe but it really doesn't look like it in reality? Still I'll try to improve on this with the other side, still learning......thanks for looking 3 Link to comment Share on other sites More sharing options...
