nick Posted December 10, 2021 Posted December 10, 2021 I've finally made a start on drawing a Cosworth DFV that will work with a lot of Tamiya 1/12th kits. I'm drawing the CAD 1:1 as is my preference which will give me some flexibility on scale. The idea is that I will produce versions to suit the majority of Tamiya (and possibly other kits) that use the DFV engine. Anyway, very early days, this where 2 days work gets you to:- I've got most of the dimensions and geometry figured out now which is the hard part, so I'm just working on the detailing of the heads and block. The heads and cam carriers are both identical with different end plates which is a real bonus. I've got the Andrew Noakes book now, which only has about 4 useful photos in it, and I've done my usual trawl of the internet, so once again if anyone has a stash of DFV images (or drawings - you never know!) all contributions gratefully received Thanks for looking Nick 5
silver911 Posted December 10, 2021 Posted December 10, 2021 Excellent timing Nick...perfect choice of project for me Ron
Coors54 Posted December 11, 2021 Posted December 11, 2021 Good to see this progressing Nick, I can feel my wallet twitching already! Any objections if I put some DFV pictures in this thread or would you prefer them sent by PM? Dave
nick Posted December 11, 2021 Author Posted December 11, 2021 3 minutes ago, Coors54 said: Good to see this progressing Nick, I can feel my wallet twitching already! Any objections if I put some DFV pictures in this thread or would you prefer them sent by PM? Dave Hi Dave, I’m sure others would like to see them too so put them on thread by all means if it’s not too much trouble. regards, Nick 1
AntPhillips Posted December 11, 2021 Posted December 11, 2021 Ooh, gotta love a bit of "Double Four Valve" engine work. Somewhere in my library I have "The Power To Win" book by John Blunsden, plenty of good info in there. Just found it:
Coors54 Posted December 11, 2021 Posted December 11, 2021 Thanks Nick, you have probably seen most of these but I'll put them up anyway. Fuel metering unit Love the surgical way this is being handled! That's a start, all pictures used for reference purposes only and some obviously have their source on them. Dave 1
Coors54 Posted December 11, 2021 Posted December 11, 2021 Nick, have you seen the Modatek website? https://modatek.co.uk/ They might have drawings you could use. Or maybe this might do? https://www.ebay.co.uk/itm/154446813297?hash=item23f5bf5871:g:fgUAAOSw58VgmC-6 Dave
nick Posted December 11, 2021 Author Posted December 11, 2021 This is a bit odd, I suspect that the cylinder spacing isn't even, I have the cylinder pitch as 104.1mm but looking at this (and other) images of the block I believe the centre two cylinders are further apart than the rest. Anyone ever heard this before? Nick 2
nick Posted December 11, 2021 Author Posted December 11, 2021 57 minutes ago, nick said: This is a bit odd, I suspect that the cylinder spacing isn't even, I have the cylinder pitch as 104.1mm but looking at this (and other) images of the block I believe the centre two cylinders are further apart than the rest. Anyone ever heard this before? Nick Strangely, now I've noticed that, everything suddenly seems to fit where it didn't quite before. Who would have thought? Nick
Vesa Jussila Posted December 11, 2021 Posted December 11, 2021 Look photo in this advertisement: https://racecarsdirect.com/Advert/Details/82110/damaged-dfv-cylinder-head You can see difference in cylinder head.
nick Posted December 11, 2021 Author Posted December 11, 2021 12 minutes ago, Vesa Jussila said: Look photo in this advertisement: https://racecarsdirect.com/Advert/Details/82110/damaged-dfv-cylinder-head You can see difference in cylinder head. Yes I’m sure now. It’s about 6mm by my reckoning. Haven’t come across this before. The limited data I have all just quotes the 104.1mm cylinder offset, no mention of the different offset between the centre pair of cylinders. Nick
PeteH1969 Posted December 11, 2021 Posted December 11, 2021 Nick Are you modelling the engine in sections with sub assemblies or as one solid? From what I can see of your render it looks very good. Pete
nick Posted December 11, 2021 Author Posted December 11, 2021 1 hour ago, PeteH1969 said: Nick Are you modelling the engine in sections with sub assemblies or as one solid? From what I can see of your render it looks very good. Pete Pete, It’s sub assemblies. As a general principle if something is a separate component on the real thing, then it is in my model. Don’t know if you saw my F40 engine but that was around 600 parts in total in the end. this will be less as it’s a more simple engine in many regards. Nick 1
nick Posted December 12, 2021 Author Posted December 12, 2021 I've incorporated the pesky cylinder offset into everything now and have completed the Cam carriers today as well as revising the valve covers. The head assemblies are a bit odd in as much as they are a sandwich of the cam carriers at the top, then the conventional cylinder heads, separate castings, all clamped down (without a head gasket) onto the wet liners/block. I know there's no real need to model the internals of these things, but I can't really help myself to be honest :). I was struggling to reconcile the photos with the drawings, but the cylinder offset has suddenly trued everything up. so hopefully progress will be a bit quicker now. I'm making good progress on the block and it should be plain sailing after that. 6
nick Posted December 13, 2021 Author Posted December 13, 2021 Cracking on with this now Some very strange 'speed holes' as Homer would call them in the top deck of the vee. Nick 5
nick Posted December 14, 2021 Author Posted December 14, 2021 Got the heads done today. Cracking on now. I reckon I can knock an engine like this out in about a week or so now. I can't really help myself with the internals, I know they will never been seen, but something has to fill the space up, so why not an approximation of what's really there? I know. I'll keep taking the pills. Nick 7
Fnick Posted December 14, 2021 Posted December 14, 2021 34 minutes ago, nick said: I'll keep taking the pills. Well they're certainly helping you turn out beautifully detailed engines so yeah fill your boots! 😄 Nick
nick Posted December 16, 2021 Author Posted December 16, 2021 Lots of tidying up yesterday and made a start on the Oil Pan. Nick 6
Malc2 Posted December 16, 2021 Posted December 16, 2021 Wow, when I made the suggestion to you do a DFV back in July, I did not think it would acually happen! So based on that can we have a Coventy Climax FWMV in 1/12 next please! Looking good, as do all your CAD and prints! Malc. 1
nick Posted December 17, 2021 Author Posted December 17, 2021 Finished the Oil Pan/Lower Crankcase today. A surprisingly complex beastie actually in the end. working from a single set of ancient, ropey thumbnail sized E-bay images didn't help either, so this may well be out. Making stuff up doesn't cover it. Nick 9
Orso Posted December 17, 2021 Posted December 17, 2021 Is this something for you?: https://sites.google.com/site/speeddetails/speed-details/b-publications/5-plumbing-and-wiring-strategies-for-the-dfv 1
nick Posted December 18, 2021 Author Posted December 18, 2021 8 hours ago, Orso said: Is this something for you?: https://sites.google.com/site/speeddetails/speed-details/b-publications/5-plumbing-and-wiring-strategies-for-the-dfv OK I’ll drop them an email, thanks for the link. Do you know if they are still active? The website looks to be at least 10 years old. regards, Nick
Coors54 Posted December 18, 2021 Posted December 18, 2021 11 hours ago, nick said: Do you know if they are still active? The website looks to be at least 10 years old. They pop up on the F1M.com forum from time to time so I think they are still around. Dave
nick Posted December 19, 2021 Author Posted December 19, 2021 First set of prints have come off now. Looking OK so far, pictures to follow soon! Nick 1
modelbautony Posted December 21, 2021 Posted December 21, 2021 You may already have this one Nick: from this book: Let me know if you want it at higher res, I will message you directly 1
