HMS Colombo - C Class Cruiser, Trumpeter 1/350
Well done, another piece of stunning work.
Although not in your league, your work gives inspiration to aim for.
Thank you,
Martin.
Thanks for all your very kind comments - they are very much appreciated.
As to the big "R" - I'm loving it though don't seem to have much more modelling time :confused:
Too much cycling to be done at the moment.
So onwards.  A dark deck wash is applied over the wood deck (after you've applied a light coat of "Klear")
2022 07 26_3905
Allow it to dry for 10-15 minutes and then with a slightly white-spirit whetted cotton bud - gently run this along so as to pick up the wash that remains on the raised bits
2022 07 26_3897
2022 07 26_3896
The non slip dark grey is then sprayed onto the superstructure decks
2022 07 26_3895
2022 07 26_3893
There is a small contrats between the "wood" 507A decks and the Non-slip Grey decks
2022 07 26_3875
2022 07 26_3894
The rather splendid automatic Micromater twin Oerlikons are completed.  The Detail is, as we've come to expect from Simon's products, simply stunning.
2022 07 26_3898
How nice are they!!
And whilst we're on the subject - another order arrived from sunny New Zealand -
2022 07 26_3882
It's one of modelling's pleasures to open these........
2022 07 26_3883
You can work out some of the future builds by seeing what's within.  I'm needing to plan 4-5 builds ahead :nerd:
2022 07 26_3885
The Flower vents are just wonderful as are several of Simon's newst offerings
I petitioned Simon to produce some "Not in use" 20mm Oerlikons - the ones with the barrell pointing vertically.  They appear like this in a surprisingly high number of original wartime photographs
2022 07 26_3886
He's also produced stairs that are a) Very detailed and b) A cowards way out of folding etch that I mange to muck-up a depressing amount of times
2022 07 26_3889
2022 07 26_3888
Having scratched one of these in 1/72, I'm pleased to announce that Simon's is 3 x more detailed at the much smaller scale
2022 07 26_3887
These 20mm ammo lockers will feature on this build and many more - mundane but hugely valuable
2022 07 26_3909
And finally an increasing necessity is to label the pots which prevents frantic rummaging
2022 07 26_3892
So back to to the build.  I always spray Klear over ALL of the hull and superstructure paintwork.  That's partly because I can then use oils and enamels to weather without fear of "lifting" the Colourcoats paint, though I'd do the same if I used acrylics.  You can handle the model with the light varnish without fear of wearing paint down and Klear gives a very slight sheen whch I find pleasing versus a very dull matt.
Hull was duly sprayed and then masked and the below waterline hull was sprayed with a Grey enamel.  It won't be seen when the ship os "planted" in the base and is really only done for you all to see what the ship looks like.  I warm to @dickrd's research regarding the colour of antifouling and I find it aesthetically more pleasing.
2022 07 26_3876
It's so warm currently that paint dries within an hour so it's not long to the reveal
2022 07 26_3877
The hull is now nearly complete
2022 07 26_3878
2022 07 26_3879
Detailing and base next.
Thanks for looking
Rob
  • Like 22
Just to be clear for everyone's benefit, I have so far found no information regarding the lower hull colour on HMS Colombo nor made any suggestions as to what it might have been. My research into the anti fouling paint colours worn on RN ships suggests that it would most likely have been a red or a grey, but it could have been black (although this is less/un likely), and even conceivably a green (although this is highly unlikely).
Edited by dickrd
Bending PE stairs.
:angry:
Has to be my most disliked task of any build.
Jon
  • 3 weeks later...
On 7/31/2022 at 1:16 AM, steve5 said:
thanks for the link , I haven't heard of micro master before , they have some good stuff .
nice work on your build too , it looks great .
Steve - Micromaster AKA Simon Percival is a God.  His products sadly become totally addictive ;)
Well I 'm concscious that this build is beginning to stretch out so - note to self - "Get a move on".
But before I wibble on - just a shout out to a thread in "Shows" regarding the Avon IPMS show that next To Scale model World is regularly the best that I attend.  It tends to get buried out of site so check  it out if you are interested
However I'll publish some of the maritime pics from the "Mulberry Harbour SIG" that went onto win "Best of show".  The SIG has a Facebook presence
Alan Blyth is a superb modeller from IPMS London/The Assocation of London Modellers and here are some pics of his work in 1/350 for the stand
2022 08 15_4000
2022 08 15_3943
2022 08 15_3935
2022 08 15_3971
2022 08 15_3946
And his work in 1/700
2022 08 15_3991
And some from Richard Allen
2022 08 15_3988
2022 08 15_3982
Alan has generously shared with me his sea sculpt technique and I'll report back in due course as it seems delightfully straightforward.
So the Colombo build has now dragged on - so - note to self - "Pull finger out"
The etched Carley paddles that come with ship frets often seem oversized and no-one does a specific fret when they feature prominently in wartime pics...
293387678_3234279826810566_1928745043471309627_n
In a moment of (unusual) clarity I experimented with 0.3mm styrene rod
2022 08 16_4035
Clearly forgetting to switch my macro on :banghead:
Take the end of some tweezers or a a scalpel handle and just firmly press down
2022 08 16_4037
whcih takes you to this
2022 08 16_4040
The other technique I've trie with Carley rafts is "dry-brushing" a technique that I normally try to avoid.  I've peviously used washes but I can rport - dry brushing with oils is far more effective and will be my preferred way of depictign the ropework henceforth.
I've spent some time detailing the bridge with speaking tubes and even though the plans and don't iinstructions don't show them - I've added Micromaster 20" signal lamps to "pedestals" at the rear of the bridge that come moulded
2022 08 16_4039
2022 08 16_4038
You can see in the above pic what a difference the 20mm lockers make over the kit supplied "boxes".
One of the advantages of building a second ship of the same class is that you can learn form your mistakes on the first.  On Calcutta I failed to deal iwht the join on the shelter deck superstructure support that is just plain ugly and offends me every time I look at it.  I corrected it on Colombo by filing down and then respraying - lesson learnt
2022 08 16_4034
I began soome deck weathering and was struck by this modern phot of a Type 23 as to how rust a Foc'sle can get...
2022 08 15_3975-1
I believe the 2 principles of weathering that are successful are
1)  Build up iin layers so as to give depth
2)  Less is ALWAYS more
I was struck by this tutorial that I stumbled across whilst thinking aboout weathering my Centruion AVRE
https://www.facebook.com/DBScaleModelStudio/posts/pfbid02TseLHwdnsHGGYNTf4EpNz2iWTQgi1xNoG68Hf5nSEufW74pSo5c3mkf8okrB1Lf5l
Lifecolor Tensocrom products are always useful and I bought some Tensocrom (acrylic) "Rust 1" which is half wash/half filter.
2022 08 16_4033
2022 08 16_4032
It provides an initila rust/weathering base that you can then add oils to later
2022 08 16_4030
it's important to try to aim for a "layering" look - do a very little at a time
2022 08 16_4026
And as always with oils and enamels - if you over do it, providing you dont leave it too long, you can remove with white spirit.  Do little bits a t a time - have a thin and then if needs be do some more
Work continues on the base and mindful of Jon's comment about the stern of Calcutta riding high - I kept whittling until I got Colombo sitting nice and flat.  Then Mig ammo One shot primer
2022 08 16_4028
To be followed by repeat layering of Liquitex Gloss medium being as rndom as possibel in it's application
2022 08 16_4029
And a pic of what the final layout will look like
2022 08 16_4027
Time for etch superstructure supports, superstructure railings etc and I now nearly always prime the fret first
2022 08 16_4041
More soon
Thanks for looking
Rob
  • Like 19
6 hours ago, S-boat 55 said:
that's a handy tip re the paddles as well,
Would that just be be without heat could you get the same effect with flat nose smooth grip pliers do you think.  🤔
Stay Safe
beefy
2022 08 16_4027
Excellent progress - it's the small details like the paddles in the Carley Floats and trademark small boats working around around the principal subject which help bring the whole scene to life.
Thanks Fellas
Railings means we are finally getting close to the end
2022 08 24_4058
The Main mast was stepped bu the kit parts were too distorted so some 0.8mm Plastruct came to the rescue.  The war time pics do show it that the supports were quite substantial
2022 08 24_4057
2022 08 24_4056
Funnel stays were fitted using pre drilled and placed "Bob's Buckles"...
2022 08 24_4055
And then to weathering with my 4 trusty  oils - Smoke black, Faded grey, Faded UN white and the most useful Industrial Earth...
2022 08 24_4047
The hull took about 2 hours of very gentle oil application and then a combination of mostly dry brushing and using white spirit to "feather" occasionally
2022 08 24_4048
It brings the hull immediately alive
The original photos show a lot of blck/darkish fender rub marks especailly on the starboard hull...
2022 08 24_4049
The foc'sle received further washes of rust
2022 08 24_4050
and I forgot to say the depth marks are decals from the excellent "Bergemot - Royal Navy" sheet
2022 08 24_4051
The model was then left to dry for 24 hours sitting in the base
2022 08 24_4052
More soon and hopefully this will be finished in time to move directly onto Starling's new S-Class
Thanks for looking
Rob
  • Like 17
5 hours ago, longshanks said:
The master of Subtle  :nodding:
Whose oil paints are you using Rob
Kev
Hi Kev
They are "502 Abteilung" originally done by Mig productions.  They are nearly 20 yrs old and barely touched.
I have some AK oils that offer different more specific shades but are not as dense or as satisfactory IMHO (Except for the "Black smoke").
You'll only need to buy oils ONCE if you are only using them for modelling.
2022 08 25_4065
And the single most useful colour is the "Industrial Earth" :nerd:
Continue staying Safe
Rob
I've replaced all of the Trumpeter Ammo bins and deck lockers with Micromaster pieces, and this pic hopefully highlights the difference that they make.  As a small aside the Trumpeter intructions do not mention the forward 4" gun lockers but the wartime pics definitey confirm that they were there!
2022 08 30_4066
Spent all day working on this today, and as is often the case, end up with not a lot to show for it.  The Foremast was steeped which involved prethreading all the signal halyards prior to fixing it in place as it would have been really difficult to thread the eyelets with the mast in place
2022 08 30_4067
The superstructure deck rails were all ttached and painted - a lengthy old job
2022 08 30_4069
2022 08 30_4068
And a Micromaster deck ladder was used for the first time, hugely detailed and so much less frustrating than an etch offering.  The steps still need painting anti-slip
2022 08 30_4070
The base also got some attention and I filled the "micro-bubbles" that form sometines with the Gloss medium & Varnish, before applying 5 coats of "High Gloss Varnish", which really only takes about 30mins per coat to dry in this warm spell.
2022 08 30_4071
Just the main mast, final detailing and crew to go....
Thanks for looking
Rob
  • Like 16
3 hours ago, steve5 said:
lovely work rob , I bet those funnels were fun to rig .
Steve - compared to your efforts - this rigging seems trivial :winkgrin:
1 hour ago, beefy66 said:
Looking great Rob like the idea of the stairs but still think that is cheating just saying :whistle:
Stay Safe
beefy
:lol::whistle:  I'm just lazy and anything to speed these builds along!  And the steps on etched offerings always break for me, usually because i twist them the wrong way :banghead:
Rob
  • Haha 2
