Mike Posted December 3, 2021 Share Posted December 3, 2021 Laffly V15T French Artillery Tractor (35570) 1:35 ICM via Hannants Ltd The Laffly V15T was a particularly niche entry into the French Artillery Tractor roster, with only 100 being made before production ceased at Laffly to be taken over by another company. The type saw limited service in the French army pulling the outmoded 25mm anti-tank guns, and after capitulation, in service with the Wehrmacht as transport or radio wagons. The unusual aspect of this vehicle was the four apparently ‘vestigial’ wheels on axles spurring off the chassis rails that were intended to increase the off-road abilities of the type. When viewed from the side however, the small balloon-wheels appear to be above the level of the main axles, so whether this actually worked anywhere but in the deepest ruts is another matter. We don’t see them on modern vehicles, so I’m guessing they were more trouble than they were worth. The Kit This is a brand-new tool from ICM, and I imagine we’ll be seeing a combination boxing with a 25mm pop-gun and crew, and probably another in German service. It’s typical of modern ICM in that it is well-stocked with detail, and arrives in their standard small top-opening box with captive inner lid. There are seven sprues of grey styrene inside, plus a clear sprue, four flexible black tyres, a small decal sheet and the glossy-covered instruction booklet with spot colour and colour profiles to the rear. It’s a full interior kit including engine, chassis and crew compartment, so there are plenty of parts to get your glue on. Construction begins with the chassis, with an option to remove the rounded rear-end where the towing hitch attaches, which is cut off easily with a scalpel or razor saw using the red outlined section on the drawings as a guide. A number of cross-braces are added, and a jig is placed under the inverted chassis onto which the rear suspension arms are laid, so that they set up at the correct angle, taking care not to glue the arms to the jig. If you have left the rear section on the chassis, the towing eye and other parts are glued in place, then the various leaf springs, ancillary axles and other suspension/steering parts are attached to the sides, with a sizeable transfer box and twin drive-shafts placed in the centre facing aft. The front axles are made up and glued in place with twin springs above them on the chassis, two more drive-shafts pointing forward, and more suspension/steering parts for the small wheels. The little balloon tyres are each made from two halves each, and four are created to affix to the small axles that project from the chassis rails, the front one of which has some limited steering capability. The 4-cylinder 2.3L petrol engine is next to be built, beginning with the two-part block and adding the sump, timing pulleys, transmission, exhaust manifold and finely-moulded cooling fan, plus other ancillaries that should result in a highly detailed rendition that just needs some HT-wires and sympathetic painting to complete. It is laid into the centre-front of the chassis along with the airbox and intake hosing, then is bracketed by a pair of tapered inserts that fill the gap between the block and the chassis rails. The main cab is based on the shaped floorpan, with sides, aft bulkhead and some internal structures added along the way, which later form ammunition storage bunkers around the sides of the rear portion. The front crew have a seat each with separate backs, and there is another optional wider seat in the middle of the rear compartment, which installs over a moulded clamshell door with pull-handles. A set of driver controls are added to the left front of the body, then a firewall with pedals, a breadbin-like compartment and other small parts is fixed to the front of the body, with a steering column and wheel added after the bodyshell is fixed to the chassis. The dashboard with dial decal is added over the wheel, and the area is covered over with a curved scuttle panel. In the rear compartment, the tops to the stowage boxes are fitted, and these have the individual sections and their handles moulded-in. Returning to the engine compartment, the steering column is extended into the lower chassis and a horn is fixed to the trim panels, then the three-part radiator is assembled and glued to the front of the vehicle, defining the engine bay. A loop of hosing joins the radiator to the engine, and the cowling panels are closed over the compartment, although you have the option to leave them open if you wish. Some small parts are added to the lower edges of the cowlings, which has crisply detailed louvers moulded-in. A pair of curved front wings are glued to the lower body over the wheels, and each of the four main wheels have a brake drum part added to the end of each axle, after which the wheels themselves are made from two hub halves that mate inside the hollow tyres and glue to the axles, allowing the vehicle to stand on its own wheels. At the rear, an axe and shovel are fixed to the bulkhead with a stop sign and the towing hook, a folded tilt is added to the rear, and the windscreen is made up from a frame and two individual clear panes. A trio of rolled-up canvas anti-splatter covers are pinned to the fronts of the door apertures and the two headlights have their clear lenses glued on before they are put in place on their mounts next to the tiny wheels at the front. The final parts are a front number plate board and an optional square unit plaque on the left front wing. What a weird little truck! Markings There are two decal options provided on the sheet, and they’re both painted in a US Green shade, despite being French. From the box you can build one of the following: Light Mechanised Brigade Anti-Tank Squadron, France, early 1940 France, Summer, 1940 The decals are printed by ICM’s usual partners, and consist of dials, number plates and a few other small decals, with good register, sharpness and good solid colours. Paint Clever folks that they are, ICM have created a box of paints from their new range that are specific to this kit. This set arrives in a card box with a header tab at one end, and inside are six 12ml plastic bottles with white plastic lids and a one-time tear-off safety ring. While they bear a passing resemblance to another brand of paint from ICM’s neighbourhood, they have stated categorically on Facebook that it is not a collaboration, and having now used both brands, they are indeed substantially different in look and use. The paint is undiluted, so will need thinning by between 40-60% with water or acrylic thinner for use with an airbrush, and they naturally have a semi-gloss finish that can be adjusted by the use of varnishes, and are waterproof when dry. Inside the box are the following colours: 1072 US Dark Green 1042 Pale Sand 1052 Hull Red 1039 Rubber Black 1027 Gun Metal 2001 Matt Varnish If you would like to see an in-depth review and spray/brush-out of the paint system, check out our recent review of the set that they made for their new 1:48 OV-10A Bronco, which you can find here Conclusion Until this kit arrived, I had no clue that the type existed, and it’s a curious-looking beast that’s endearing for its unusual shape and design. Detail is excellent, and if you don’t fancy the options on the sheet, a little research will probably turn up some alternative schemes. The paint set is a quick and easy way to get things painted up the correct colour, as well as being quite pocket-friendly into the bargain. Highly recommended. Available in the UK from importers H G Hannants Ltd. Laffly V15T (35570) Paint Set (3009) Review sample courtesy of 3 Link to comment Share on other sites More sharing options...
Basosz Posted December 3, 2021 Share Posted December 3, 2021 "Vestigial wheels" That's pretty funny Link to comment Share on other sites More sharing options...
Mike Posted December 3, 2021 Author Share Posted December 3, 2021 1 minute ago, Basosz said: "Vestigial wheels" That's pretty funny They reminded me of those little arms on the front of the Alien Queen. 1 Link to comment Share on other sites More sharing options...
Julien Posted December 3, 2021 Share Posted December 3, 2021 That looks plain strange! 1 Link to comment Share on other sites More sharing options...
sinnerboy Posted December 3, 2021 Share Posted December 3, 2021 I think the tool designers messed up here. They've made the front 1/48 and the back 1/35. what a strange beast. 1 1 Link to comment Share on other sites More sharing options...
Mike Posted December 4, 2021 Author Share Posted December 4, 2021 19 hours ago, Julien said: That looks plain strange! It’s a truck, not a plain. Link to comment Share on other sites More sharing options...
