Julien Posted December 1, 2021 Posted December 1, 2021 Eurofighter "Luftwaffe 2020 Quadriga" (03843) 1/72 Revell The Eurofighter EF2000 Typhoon started out as the EAP programme in the 1970s engineered entirely by BAe, but was later joined by a number of international partners due to an allegedly common requirement, with the partnership changing over time to end up with Britain, Germany, Spain and Italy remaining, while France went their own way with the Aerodynamics data to create the Rafale, which has a similar general arrangement. Delays and cost overruns seem to be a common factor in modern military procurement, and the Typhoon suffered many, resulting in the Germans taking delivery of the first airframe in 2003, Italy in 2005 and the UK in 2007. Operational airframes have since taken part in operations in Libya and under Italy's control in Albania. After the British Typhoons were initially ordered without guns, then with guns but without ammo, which was again overturned in due course, they were grounded in 2011 due to a lack of spares, which required the RAF to cannibalise grounded airframes to keep flying. The two-seat variant is used for training and conversion, although it is capable of going to war if needs required it, having all the systems in place to make it viable. The aircraft is a great air show crowd pleaser due to its agility at all speeds, and the impressive tearing roar of its twin EF2000 jet engines that propel it forwards with an impressive 20,000lbf of power per engine with reheat engaged. The Luftwaffe doe s not use the term Typhoon for some reason The Kit Here Revell have re-released their own tool kit which traces it's history back to 2016. The kit arrives on 3 large sprues, a smaller sprue; and 2 clear sprues. Construction starts in the cockpit with the 4 part seat going together then being placed in the tub along with the instrument panel and control column. Instruments are provided as decals. The tub is then placed in the fuselage and this is closed up. The lower intake parts are put into the lower wing section, if any underwing stores are to be used the holes for these need opening up at this stage as well. Moving back to the fuselage the exhaust inners go in at the rear, and the top part of the intake at the front. The lower wing can then be joined to the fuselage with the upper wings, vertical tail, nose cone; and front canards then being added. The exhaust nozzles are hen fitted with either open or closed ones being supplied. Wing tip pods go on followed by the top central spine, and at the front the cockpit coaming. The landing gear and doors can then be assembled and added to the model, or just the closed doors if you wish. If you like to open things up there is the option of an extended refuelling probe, and an extended airbrake. The canopy can be fitted either open or closed. It is good to see Revell provide a selection of missile and tanks to hang under the aircraft which some other manufacturers could take note of. Decals Decals are supplied for one specially marked aircraft. 31+49 of the TaktLwG 31 "Boelcke" The markings have "the green binary code stands for the digitization of the Air Force, the blue polygons for the corporate design of the Bundeswehr". The Quadriga points to the Eurofighters of the fourth tranche. Conclusion This is a good little kit from Revell and will appeal to those who like the special schemes, or just ant another Eurofighter in their collection. Recommended. Revell model kits are available from all good toy and model retailers. For further information visit or 1 1
PhantomBigStu Posted December 2, 2021 Posted December 2, 2021 One thing say least these special schemes are nice, think I’ll be getting next years, speaking more for others as I’ve got a few sets from the old kit spare but after 5 releases assume have sold plenty they could spend a little bit on a full stencil sheet and decals for regular sqn bird of Luftwaffe/RAF…..
