`Deuce` F,102 Delta Dagger, 509 FIW, Tan Son Nhut Airport, S Vietnam 1966
russ c
You did a badass job. You polished the painted surface, creating a super-realistic result. The exhaust section looks convincing. You weathered well, but did not over-weather the aircraft or fall victim to "gridding" the panel lines.
Looks very nice and I hope my F-102s turn out that well so I can display them nicely.
Really impressive build! I did not known that F 102 flown in Vietnam still in 1966!  Moreover, I lived in opinion, apparently wrong, that all USAF machines in Vietnam had three colors upper scheme, and not such light grey with red air superiority livery. Thank you for sharing :)
Regards
J-W
That's outstanding. I do love the '102...a very elegant aircraft that just looks right from every angle. You've done a fine job on the 'old' kit. Just one question....it looks like engraved panel lines...but i thought these old Monogram kits were raised?
Thanks, re:panel lines, I sanded them all flush and drew them in later with a pencil using the instructions as a guide. Then varnished and weathered.
Cheers Russ
Your usual top-notch work, for sure!
The pencil panel lines are quite a brilliant concept (I've never been diligent enough to go at full re-scribing like some do).
Excellent results as always!
:clap2::clap2::clap2:
