US Mk.17 Depth Charges (648691) 1:48
Mike
1:48 Eduard Brassin
The AN-Mk.17 Mod.2 depth charge was used by the US Navy during WWII, carrying 325lbs of either TNT or Torpex in a cylindrical casing with welded-on dome head, and having a drum-shaped tail fin for stabilisation during flight from the launching aircraft.  A small spinner armed the fuse on the side as the weapon fell, and the single suspension lug was a triangular bracket welded to the body.
As is now usual with Eduard's smaller resin sets, they arrive in a shallow Brassin cardboard box, with the resin parts safely cocooned in bags, and the instructions folded around acting as padding.  This is one of Eduard’s new Castless Print sub-variant, and the resin parts are SLA printed directly from the CAD files.  Inside the box are two units that have already been removed from their bases, with just a fraction of a millimetre of the support lattice still visible on the bottom of the fin ring, which will be the work of moments with a sanding stick to remove.  The charges are ostensibly complete save for the spinner on the nose, which is made from two PE parts and a short length of 0.4mm rod from your own stocks.  The blades on the spinner will need twisting slightly with a pair of tweezers, then a PE ring is added to the front and the spinner is slipped over the rod and is glued in place.
The front of the instruction sheet has a colour diagram showing the painting of the depth charges with their usual Gunze colour call-outs, plus the location of the few stencils that are applied to the finished article from the small sheet that accompanies the set.
Highly recommended.
Review sample courtesy of
