OV-10A Bronco Acrylic Paint Set (3008)
Mike
ICM via Hannants
ICM have recently released their own brand of acrylic paints on the market, and are creating some kit specific sets to go with their major releases, of which this is one.  The set arrives in a cardboard box with six screw-capped bottles inside, each containing 12ml of paint.  The bottles are clear Polypropylene, and are capped with cylindrical tops with knurled sides, and a one-time security seal that you break on first opening.  A label on the side gives you basic information about the colour and code, a little information regarding application in English and Ukrainian and a bar-code.
This set provides the major colours to assist you in painting your brand-new OV-10A Bronco in 1:48 from ICM themselves, and you will find the following colours in the box:
1071 Camouflage Gren
1031 Warm Grey
1032 Blue Grey
1026 Oily Steel
1002 Black
2002 Satin Varnish
The paint is thick in the bottle, with plenty of headroom between the surface of the paint and the lip of the neck.  I dropped a glass stirring ball into each bottle, and they took a few seconds to disappear beneath the surface, indicating their viscosity.
Airbrush
I used Ultimate Acrylic Thinners to dilute the paint to spray through my Gunze PS770 airbrush, which has a 0.18 needle chucked in.  The paint dilutes well once it has been mixed thoroughly, and sprays well through my airbrush, which has a smaller than usual needle that is a good test of the finesse of the pigment grind of any brand, some of which don’t spray very well though anything less than a 0.3mm needle.  There were no problems with blockages at all, and the coverage was excellent after my usual ad hoc dilution method, which was probably nowhere near the 40-60% thinners or water that’s suggested on the pack.  The photo below shows the five actual colours sprayed out onto plastic spoons that have been prepared by buffing with a fine grade flexible sanding stick of the kind you use in the penultimate step before buffing to a shine.  As the paint dried it obtained a highly matt finish with the exception of the Oily Steel paint, which is clearly semi-gloss.
The Satin Varnish also worked very well diluted with water, sprayed over the spoons that were also partially taped up to perform two functions at once.  The satin patina that resulted is exactly what was expected, and the tape lifted no paint at all, despite my best efforts to do so.  Bear in mind that the spoons were prepped by a buff with a very fine sanding sponge to give them a chance of adhesion.  There was very little damage to the cured paint from scraping my fingernails across the surface too.  There were track-marks of course, but no lifting of paint at all.
Paint Brush
As usual I used a #6 synthetic filbert brush from AMMO, which has slightly curved edges to keep tramlines in the paint to a minimum.  The colours brushed extremely well with one exception, which was the Oily Steel.  It appeared to pull up when over-brushed during application, despite the surface remaining wet, which resulted in the appearance of tiny fibre-like structures in the paint that led to a gritty finish that was also translucent even after two coats, obtaining a rather lumpy opaqueness after three coats.  The rest of the colours covered perfectly after two coats with minimal brush marks visible, which was thoroughly impressive to this long-lapsed brush painter, and some were almost completely opaque after one coat, save for the fact that they were laid down over a white surface.
The undiluted Satin Varnish brushed out well over the matt surface of the brush painted spoon undersides, and I had to leave it until the next day to have my evening meal.  The satin effect was excellent again, and the paint was tough enough to stand up to my fingernail test without lifting, although you can’t avoid leaving tracks across the surface due to the deposition of tiny particles from your fingernail on the surface.
Conclusion
The paints were excellent through the airbrush with nothing in the way of drama during the testing process, including the Oily Steel and Satin Varnish.  The solid colours also brushed out very well, as did the varnish, but what happened to the Oily Steel is a mystery to me at this stage, possibly a bad mix, or some other oddity peculiar to my bottle or batch.
There is a little less paint in the bottles than some brands, but a shade more than others, so it’s about average.  That is more than offset by the very reasonable price they’re asking for the set, even at RRP.
Highly recommended.
Available in the UK from importers H G Hannants Ltd. Currently on back-order, however.
Review sample courtesy of
