PhantomBigStu Posted November 8, 2021 Share Posted November 8, 2021 (edited) Spent most of this year either finishing or disposing builds, (baring one that gone away into storage for a while and another that will definitely be built for this, but a got a few hanging around to pick from. First Lot Edited April 23, 2022 by PhantomBigStu Link to comment Share on other sites More sharing options...
PhantomBigStu Posted November 8, 2021 Author Share Posted November 8, 2021 And here's the rest, though actually have a hankering for one that got mistakenly culled back in feb 4 Link to comment Share on other sites More sharing options...
Anatol Pigwa Posted November 10, 2021 Share Posted November 10, 2021 Hmm, start with the ones which are most advanced so you can finish more, or the ones which are least advanced in order to take advantage of the time? Questions, questions. 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted November 10, 2021 Share Posted November 10, 2021 The best possible one Id like to see is the B-25. 2 Link to comment Share on other sites More sharing options...
CliffB Posted November 10, 2021 Share Posted November 10, 2021 2 hours ago, Corsairfoxfouruncle said: The best possible one Id like to see is the B-25. 1 Link to comment Share on other sites More sharing options...
JOCKNEY Posted November 10, 2021 Share Posted November 10, 2021 The Gnat looks nearly done, the Mitchell will be great when finished, but probably not enough time left in this GB for all the decals that go on a Phantom ! Best of luck. Cheers Pat 2 Link to comment Share on other sites More sharing options...
Swamp Donkey Posted November 10, 2021 Share Posted November 10, 2021 Mirage gets my vote SD Link to comment Share on other sites More sharing options...
PhantomBigStu Posted November 10, 2021 Author Share Posted November 10, 2021 B-25 winning the popular vote so far, fitting as my first KUTA entry and completion was my first attempt at the Airfix kit and it’s the longest serving build, started it in the spring of 2019 after the build had a horrible accident before life and other builds got in the way. 3 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted November 13, 2021 Author Share Posted November 13, 2021 (edited) Been doing some sorting out and as well as culling the aforementioned other build I culled the b-2, and unintentionally the gnat as I tried to correct the bad step in the wing fuselage join. But anyway decided will indeed progress the b-25 and a finish that mirage iv off Edited November 13, 2021 by PhantomBigStu 3 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted November 14, 2021 Author Share Posted November 14, 2021 (edited) Well actually turns out it wasn’t my first KUTA, that was a eurofighter 3 years earlier…anyway here was the previous build, this time will be easier as the decals include a non stripy one, though part of me wonders if I should get the xtradecal sheet and do one not in OD/NG Edited November 14, 2021 by PhantomBigStu 5 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted November 29, 2021 Author Share Posted November 29, 2021 (edited) Done a load sanding today and got some xtracrylix desert sand on. Changed scheme and going the one from the kit but it’s operational guise Edited November 29, 2021 by PhantomBigStu 3 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted December 2, 2021 Author Share Posted December 2, 2021 Sand wasn’t fully mixed and after some sanding touch’s up and a complete repaint here it is with the upside in the more correct lighter and pinker form 2 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted December 8, 2021 Author Share Posted December 8, 2021 Underside sanded and painted neutral grey mix few areas to attend to before can sort out the proper demarcation 2 Link to comment Share on other sites More sharing options...
Dansk Posted December 8, 2021 Share Posted December 8, 2021 don’t forget to put a shedload of noseweight in the mitchell stu. 😉 Link to comment Share on other sites More sharing options...
jean Posted December 9, 2021 Share Posted December 9, 2021 16 hours ago, Dansk said: don’t forget to put a shedload of noseweight in the mitchell stu. 😉 Ain't it a bit late for that? JR Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted December 9, 2021 Share Posted December 9, 2021 Gidday, model planes aren't my forte but it seems to me that the undercarriage is retracted, ie the plane's flying. So will you need the nose weight at all? Regards, Jeff. Link to comment Share on other sites More sharing options...
Dansk Posted December 9, 2021 Share Posted December 9, 2021 2 hours ago, jean said: Ain't it a bit late for that? JR no. theres no glass installed yet Link to comment Share on other sites More sharing options...
jean Posted December 9, 2021 Share Posted December 9, 2021 1 hour ago, Dansk said: no. theres no glass installed yet Hi Paul, I don't know the kit. Can weights be pushed behind the pilots' seats? Filling up the bomber's position with lead wouldn't look to hot! Cheers JR Link to comment Share on other sites More sharing options...
Dansk Posted December 9, 2021 Share Posted December 9, 2021 42 minutes ago, jean said: Hi Paul, I don't know the kit. Can weights be pushed behind the pilots' seats? Filling up the bomber's position with lead wouldn't look to hot! Cheers JR Loads here painted black I reckon - Link to comment Share on other sites More sharing options...
Dansk Posted December 9, 2021 Share Posted December 9, 2021 2 minutes ago, Dansk said: Loads here painted black I reckon - edit: hold on this is stupid. Stu has the gear up anyway! haha 🤣 1 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted January 21, 2022 Author Share Posted January 21, 2022 Did some more before Christmas before it went back in the draw till yesterday when I discovered I don’t have the decals for my spitfire in the spares and I cracked on and finished the underside. 2 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted January 22, 2022 Author Share Posted January 22, 2022 Pilots painted and now to put various bits on 2 Link to comment Share on other sites More sharing options...
PhantomBigStu Posted February 19, 2022 Author Share Posted February 19, 2022 This went horribly wrong a few weekends back when it came to the clear parts, couldn’t get some to fit, lost a landing light part into another dimension though good old revell clear sorted them out only for the canopy to brake on the Monday hence the thread went dark. Couldn’t get a spare but all is not lost, decided to use the one the more framed one the kit came with to do an raf one so the pink will be repainted olive drab Link to comment Share on other sites More sharing options...
PhantomBigStu Posted March 3, 2022 Author Share Posted March 3, 2022 (edited) - Edited April 9, 2022 by PhantomBigStu Link to comment Share on other sites More sharing options...
PhantomBigStu Posted April 10, 2022 Author Share Posted April 10, 2022 To give the thread a happy end here’s what should be a quick build, going for the luftwaffe option from the hobbyboss kit as the hasegawa shares the same wing type Link to comment Share on other sites More sharing options...
