JFM148 Posted March 3, 2022 Share Posted March 3, 2022 Totally sadden by the critical situation in Ukraine. Obviously not Revell´s fault. Right now as modelling community is all about supporting and helping the Ukrainian and Russian model companies, this savage war is not their fault either. I pray they and their families are OK under these difficult times. Link to comment Share on other sites More sharing options...
exdraken Posted August 12, 2022 Share Posted August 12, 2022 On 1/1/2022 at 10:45 PM, Homebee said: MAY 2022 - ref. 03820 - 1/48 - Eurofighter Typhoon - "Blackjack" - re-release with new decals decals look great, aka fantastic! unfortunately only Black Jack, no service aircraft or even orndance markings... 1 Link to comment Share on other sites More sharing options...
sniperUK Posted August 12, 2022 Share Posted August 12, 2022 49 minutes ago, exdraken said: decals look great, aka fantastic! unfortunately only Black Jack, no service aircraft or even orndance markings... Has it Saintys or Adam O'Hares name on the sheet? 1 Link to comment Share on other sites More sharing options...
exdraken Posted August 12, 2022 Share Posted August 12, 2022 15 minutes ago, sniperUK said: Has it Saintys or Adam O'Hares name on the sheet? that is what you get in names James Sainty Anarchy 1 and Keith Watson/ James Pavitt hope you like them Link to comment Share on other sites More sharing options...
sniperUK Posted August 13, 2022 Share Posted August 13, 2022 3 hours ago, exdraken said: that is what you get in names James Sainty Anarchy 1 and Keith Watson/ James Pavitt hope you like them Shame it's not Adams name on there as he's this years pilot and a good mate. Keith Watson is still the teams SENGO this year. 1 Link to comment Share on other sites More sharing options...
Adam Poultney Posted August 13, 2022 Share Posted August 13, 2022 Hope next year we get the 32 scale gliders back and the 144 a400m and c17 Link to comment Share on other sites More sharing options...
Homebee Posted December 1, 2022 Share Posted December 1, 2022 (edited) Soon - 1/48th - ref. 03823 - Douglas B-26 Invader https://www.tapatalk.com/groups/revellations/1-48-douglas-b-26-invader-03823-t5510.html This is not the Monogram tooling dating from 1993, but the recent ICM kit re-boxed LINK V.P. Edited December 1, 2022 by Homebee 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted December 1, 2022 Share Posted December 1, 2022 (edited) Can anyone please explain what the big round object is on the port cheek of the invader ? Ive circled it in white and cannot figure it out ? Ive been up close to real invaders and never have seen this item. I have seen a flat circle of sheet aluminum but nothing that bulges out like this piece. Edited December 1, 2022 by Corsairfoxfouruncle Link to comment Share on other sites More sharing options...
MrB17 Posted December 1, 2022 Share Posted December 1, 2022 18 minutes ago, Corsairfoxfouruncle said: Can anyone please explain what the big round object is on the port cheek of the invader ? Ive circled it in white and cannot figure it out ? Ive been up close to real invaders and never have seen this item. I have seen a flat circle of sheet aluminum but nothing that bulges out like this piece. It looks different in the photo, probably because of the big black dot in the centre. It’s actually slightly domed with a very small dimple in the centre. Some have them like this, others are flush like you mentioned. It’s moulded as part of the main fuselage on the kit, and the nose section has a semicircular cutout where it fits. Sanding it flush would be simple as well as filling the small dimple, which would be almost gone by sanding it flush. I have seen the domed panel in some photos, but the dimple is not centred, but lower down on the panel. I have no idea what it’s for. The Hamilton standard props don’t look very good either, the propeller boss should not be tapered and the blade shape is questionable and has little twist to it. It just looks wrong. Cheers Jeff 1 Link to comment Share on other sites More sharing options...
Creepy Pete Posted December 2, 2022 Share Posted December 2, 2022 (edited) I've looked at some pics, and I think they are usually faired over with that flat circle of aluminium from the factory. I think it might be a hoist point. Here's one with the cover removed. You can see that strip between the fuselage and the nose has been peeled away as well: https://icm.com.ua/wp-content/uploads/2020/10/d4801_photo_1.jpg And one from the other side, with the hoisting stuff (probably not the correct technical term ) added: https://www.3rdattackgroup.org/resources/A-26_Invader/3rd BG 89th Attack Squadron.jpg Then again, I might be totally wrong. Edit: Looks like I am. It clearly says "Jack Here" on the patch here: https://i.pinimg.com/originals/77/27/ce/7727cee1741c416d5afb92941130a08c.jpg Maybe you insert a pin in there for the jack. Edited December 2, 2022 by Creepy Pete 2 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted December 3, 2022 Share Posted December 3, 2022 5 hours ago, Creepy Pete said: I've looked at some pics, and I think they are usually faired over with that flat circle of aluminium from the factory. I think it might be a hoist point. Here's one with the cover removed. You can see that strip between the fuselage and the nose has been peeled away as well: https://icm.com.ua/wp-content/uploads/2020/10/d4801_photo_1.jpg And one from the other side, with the hoisting stuff (probably not the correct technical term ) added: https://www.3rdattackgroup.org/resources/A-26_Invader/3rd BG 89th Attack Squadron.jpg Then again, I might be totally wrong. Edit: Looks like I am. It clearly says "Jack Here" on the patch here: https://i.pinimg.com/originals/77/27/ce/7727cee1741c416d5afb92941130a08c.jpg Maybe you insert a pin in there for the jack. The lift here/Jack here is the winner I think. The one photo showing the tube and the one with the gear attached do help explain what those circles are covering. I would definitely sand and fill the kit one. That or use a cut circle of plastic over it after its been sanded flat. 1 Link to comment Share on other sites More sharing options...
MrB17 Posted December 3, 2022 Share Posted December 3, 2022 On 12/1/2022 at 2:58 PM, Corsairfoxfouruncle said: Can anyone please explain what the big round object is on the port cheek of the invader ? Ive circled it in white and cannot figure it out ? Ive been up close to real invaders and never have seen this item. I have seen a flat circle of sheet aluminum but nothing that bulges out like this piece. The cover should be flush and flat, because it’s a fabric patch to cover the hoisting attachment. Right on the money @Creepy Pete. Here is the diagram from the maintenance manual. It’s on both sides, and only on the Bombardier nose “glass nose”. Note the pinking shown on the edge of the patch on the diagram. So sand it flush and fill it. The one I saw with the aluminium domed panel, as shown on the model, was on a warbird. Warbirds and museum restorations are not always a reliable source, as is evident here. Cheers Jeff 2 1 Link to comment Share on other sites More sharing options...
MrB17 Posted December 3, 2022 Share Posted December 3, 2022 25 minutes ago, Corsairfoxfouruncle said: The lift here/Jack here is the winner I think. The one photo showing the tube and the one with the gear attached do help explain what those circles are covering. I would definitely sand and fill the kit one. That or use a cut circle of plastic over it after its been sanded flat. Didn’t mean to step on your toes mate. I was composing my post, when I saw your reply come up. It took me a few hours to find the drawing, if you don’t use the exact nomenclature while searching the manual, it’s like finding a green jellybean on the front lawn. Haha Cheers Jeff 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted December 3, 2022 Share Posted December 3, 2022 2 hours ago, MrB17 said: Didn’t mean to step on your toes mate. You didnt … Im sorry if that was the impression I sent ? Link to comment Share on other sites More sharing options...
MrB17 Posted December 3, 2022 Share Posted December 3, 2022 1 hour ago, Corsairfoxfouruncle said: You didnt … Im sorry if that was the impression I sent ? No not at all, you had arrived at the same conclusion while I was composing, that’s all. Cheers Jeff 1 Link to comment Share on other sites More sharing options...
