1/32 F-4D Spook on a Spook
Hello all,
I've been working on this one for a while now and i was hoping to get outside and get some photo's on a diorama and in daylight, but the weather hasnt been playing ball.
So, i thought i'd get some indoor pics done and then update this later.
The build includes Red Fox Studios instrument set and all the weapons are attached with magnets for ease of transportation, paints were from Gunze and oil washed with Abteilung Starship filth for the most part.
All comments welcome 🙂
  • Like 65
  • Thanks 3
That's very nicely done. I like almost everything about it, the unusual scheme, the quality of the build, and the photography too. For my taste you went a little too universal on the dark oil wash, but that's a minor thing. I love the cockpit.
In 1/32 a Phantom must have a real physical presence, mm. Your build is certainly tempting me, I can feel my wallet itching.
Man, is your work ever impressive! Wonderfully built and painted model. I'm curious as to what you did to get the engine air intakes to look as good as they do. As I'm sure you know, Tamiya's 1/32 Phantom intakes are notorious for not having a good fit and most folks blank off the intakes with intake covers.
If you go down the Tamiya route you'll find it a very easy build, the intakes need some surgery to get to look half decent. Tamiya are know for their great kits, but I have no clue as to what they was thinking when they engineered this area of the kit.
Thank you for your kind comment and I was waiting for this question to come up, but I didn't think to take pictures of the surgery needed.
If you have the kit, you'll notice that the fuselage has some parts of the inner intake attached to it, these need removing. What I did then was place these inner walls onto the intake and test fit them to see they looked and fit correctly, after checking this it was a case of sanding and filling the intake smooth, painting and then attaching them. Hope that helps.
Thanks. That's a little nugget of useful information to file away. It will presumably be the same on all of their F-4 family.
I believe so, its certainly the same on the C/D and J but is easily fixable if you flow what I did in reference to SAT69's question.
20 hours ago, CJP said:
You've done a great job on your Phantom and using magnets for attaching the weapons is an interesting idea.
CJP
It's quite easy to do in this kit as the pylon mounts are 2.5mm wide and its quite easy to get hold of some 2.5mm cylinder magnets. What it does do is save the pylons getting knocked off in transit.
Hi David - I was very interested in your use of magnets to hold the  underwing stores on so bought some 2mm x 1mm micro magnets from Amazon - I am using them on my 1/32 Revell Hawker Hunter outer pylons so I can have the option of having SNEB rocket pods or 100 gallon fuel tanks - great tip
thanks
CJP
