81-er Posted October 15, 2021 Share Posted October 15, 2021 As the title suggests, I'm after a better clearcoat. I've currently got a can of Humbrol acrylic varnish, which is useless. It's giving me an almost matt finish that's slightly hazy, rather than the gloss I'm after. Must be safe for use over acrylics and must be in an aerosol as I don't have an airbrush. Otherwise, I'm completely open to ideas. Link to comment Share on other sites More sharing options...
Whistlekiller Posted October 21, 2021 Share Posted October 21, 2021 I’ve experienced a similar problem so await replies with interest. Link to comment Share on other sites More sharing options...
Black Knight Posted October 22, 2021 Share Posted October 22, 2021 1. make sure your spaying area is very warm 2. warm the spray can in a jug of very hot water, not boiling hot but nearly so 3. give the can a really vigorous and long shake to make sure its really mixed 4. Spray the first coat on lightly - a mist coat, allow this coat to 'flash' off 5. spray the next coats a bit heavier, allowing each coat to 'flash' off before spraying the next coat As well as Humbrol sprays I also use a generic automotive clear gloss lacquer which is acrylic. Even with that I do the 5 points above 1 Link to comment Share on other sites More sharing options...
iainpeden Posted October 22, 2021 Share Posted October 22, 2021 If it's a gloss coat for decaling then Klear/Pledge is the goto solution (sorry); either brushed on or can be lightly thinned with water or acrylic thinner and sprayed. As ever practice on something that doesn't matter first. PS It can also be mixed to a satin finish with an acrylic matt varnish such as Xtracrylix. Link to comment Share on other sites More sharing options...
bentwaters81tfw Posted October 22, 2021 Share Posted October 22, 2021 Halfords also do a clear gloss acrylic spray in their automotive range, and a satin lacquer. For matt, I use Citadel munitorium from Games Workshop Klear/Pledge or Lakeland Quickshine are brushable alternatives. Self levelling and leave no marks. Link to comment Share on other sites More sharing options...
Stephen Posted October 22, 2021 Share Posted October 22, 2021 50 minutes ago, bentwaters81tfw said: Halfords also do a clear gloss acrylic spray in their automotive range, and a satin lacquer. For matt, I use Citadel munitorium from Games Workshop Klear/Pledge or Lakeland Quickshine are brushable alternatives. Self levelling and leave no marks. Watch out using Halfords Clear Lacquer as it reacts to certain paints. I tried it over Xtracrylix and it made a horrible mess of the paint. I would test it first on what ever paint brand you're using. Link to comment Share on other sites More sharing options...
bentwaters81tfw Posted October 22, 2021 Share Posted October 22, 2021 1 minute ago, Stephen said: Watch out using Halfords Clear Lacquer as it reacts to certain paints. I tried it over Xtracrylix and it made a horrible mess of the paint. I would test it first on what ever paint brand you're using. Thanks. I have a can, but not used it yet. I'm no fan of Xtracrylics. Paint of last resort. Link to comment Share on other sites More sharing options...
