German railway sleepers - 1930's
Geo1966
I am looking to make a couple of sleepers for a WW2 diorama in 1/35.
Having googled the dimensions i came up with this:
German railway sleepers measure 16 cm. x 26 cm. x 2.6 m. or 2.7 m.
Does that sound right? 16cm x 26cm seems small to me.
If you can help i will be much appreciated.
Thanks,
George
Close match to UK sleepers which are around* 6in x 10in x 8ft 6in long (150mm x 250mm x 2.59m)
*overall dimensions of sleepers did vary over time as speeds and weights of trains increased, with these dimensions 'standardising' in the mid 30's. That said as timber sleepers had a life of around 20 - 25 years there would be a variety around (although not usually at the same location). Longer sleepers were used where points & crossings were located.
Those dimensions sound about right for standard gauge.  UK sleepers were around 6” deep x 8”-10” wide x 8’ or 8’6” or 9’ depending on particular company’s standards or shortage of cash!  Wider and longer sleepers would be used at points.  So those German dimensions are plausible .
Also the spacing of sleepers can vary slightly depending on traffic and finances, on older jointed track in the UK they were slightly closer at the joints, though i don’t know about German practice (though US also did).  Apart from the sleepers UK track isn’t a very good guide to the rest of the worlds railways as UK traditionally used chaired bullhead rails whereas ROW was for flat- bottom rail profile.
Thanks Gents, very helpful.
One thing I forgot to ask is, did they cut into the sleepers to mount the tracks or did they bolt them straight onto the sleeper as below?
Thanks again,
George
Please forgive my intrusion on this interesting conversationI’m not sure if you know this but in the U.S. these are referred to as railroad  ties. When I started reading the discussion I was picturing dimensions of sleeping cabins on a sleeping car at first. When I saw the photo in @Geo1966’s last post realized that europe calls them something different. Amazing the things you can learn just by accident.
Dennis
This link to track preserved at Auschwitz  might help answer your questions
LINK
there's plenty of others available on the web
