Chipmunk T10 in Army colours (Airfix 1:48 scale)
SimonL
I haven’t made an aircraft kit since last Christmas and my local hobby shop has a pile of these in stock, so thought I would have a go.
resized_278cf719-5621-4385-b4c7-bc16e181
Sprue shots:
resized_cc390dc9-15b1-40f4-96bf-2793cc98
resized_06798549-a19e-40a2-b4cc-a90fcb44
resized_52fc851c-eab5-4519-ae5d-5fd506e6
Looks like just the right amount of
complexity that I can handle at the moment - reasonably detailed but not too complicated.
Transparencies still all wrapped up.
resized_3ccecadd-b00e-496a-a469-244774b1
A rather busy decal sheet - although I’m going to do the Army one, so not so many of the little stencils to be done for that one.
resized_8e25f246-f3f2-4dc0-9f84-753b4967
Here is the one I am going to do - Middle Wallop was just a short distance from where we lived (for multiple postings) when Dad was in the Army.
resized_e778f7c8-34a6-42d7-b196-3c32a4a3
Started work on the cockpit straight away. This is going to be a straight out of the box job. All went together very nicely.
resized_94318f48-a55c-4412-928c-ad5646b9
Then paint, a couple of coats of Tamiya XF69 NATO Black were brushed on, followed by some dry brushing with a light grey acrylic. A wash with Army Painter Dark Tone wash, and the finished with a coat of Italeri clear flat. I used a few dots of Tamiya X22 gloss clear for the instrument dials.
resized_fcc1c7e8-1da0-4846-8c93-847d63da
While the paint was drying I had a go at the canopy - which has me a little anxious. Airfix provide a little jig to align everything. It’s a bit fiddly, but I took it slowly, using very careful application of Tamiya Extra Thin Cement, and it looks like it’s worked ok. Couple of tiny gaps that some PVA will fix.
resized_fb72225a-1e7b-4fdd-8fb7-609207f1
resized_34e7d979-606c-4d32-bb59-3bb16283
That’s it for today, so far it’s a good start.
Progress this weekend. After adding some masking tape seat belts, painted dark grey, it was time to seal up the fuselage - which was pretty easy. Also in shot is the under side of the wing. I’ve glued some aluminium foil to the backside of the underwing light to give an impression of the lamp.
resized_eb56a2a4-8591-4b73-8c27-96a2bb8d
resized_25428440-1d64-4616-9139-fd58e5a1
Once the glue had dried only needed a little sanding of the seams and then I fitted the lower wing. This needed a bit of fettling to fit correctly. I ended up removing the little “tags” on the wing and it fitted fine. Then on with the top of the wings. Again I needed to remove the pins to make everything line up ok - not sure whether it’s my ineptitude, but it looks ok. I’ve made a start on painting the wheels - Tamiya XF16 flat aluminium for the hubs and Vallejo Panzer Aces Dark Rubber for the tires.
resized_7e0fc3a0-25b4-483c-819b-d05cf24a
resized_024a77d3-88dd-42a1-a15b-425cd354
That’s it for the weekend.
