nheather Posted October 10, 2021 Share Posted October 10, 2021 First we had the big breakthrough of 2k mono screens, then there were 4k and now we are looking at 8k. I understand that build plate size is a factor - if you want a bigger plate then you need more pixels to achieve the same resolution. What I’m interested in is the trade off between resolution, print speed and cost. So in the Mini size sector we are looking at resolutions of For 2k - 50u For 4k - 35u For 8k - 22u The lower the number the better it sounds but - more layers so longer print time and I’m guessing the cost of replacement screens will be higher (8k > 4k > 2k). What I would like to know is what difference can you see with the eye - not the magnifying glass, not a microscope. I recently read a review of the Mars 3 (4k) and that concluded that it was hard to see a difference between 50u and 35u so given the 35u prints took significantly longer the recommendation was to print at 50u. My primary interest would be printing wargaming figures (AFVs mostly) in scales ranging between 10mm and 28mm. Just wondering whether to go for the new 4k and 8k models or whether a cheap 2k would be more than good enough. Cheers, Nigel Link to comment Share on other sites More sharing options...
ICMF Posted October 11, 2021 Share Posted October 11, 2021 You're confusing pixel size - X/Y resolution - with layer height - Z resolution. The two variables are entirely divorced from each other. Higher X/Y resolution doesn't need any more or less time, it just prints bigger pixels. Thinner layer heights (higher Z resolution) DOES effectively take longer, because you need to print more layers*. X/Y resolution is fixed on a printer - whatever screen you have, that's your resolution, and you can not change it. Layer height IS user configurable depending on the print, but this is the same on every mSLA printer - they'll all print pretty much the same range of usable layer heights no matter what the X/Y resolution is. There's a small caveat that a smaller pixel size might have a thinner ideal theoretical layer height, but in practice, it's not going to make much difference to the way users actually print with them. FWIW, actual exposure times will be lower, because you're not exposing as much resin at a time, but it'll be net slower because you've got to raise/lower the print bed more times, which takes most of the actual print time anyway. 2 Link to comment Share on other sites More sharing options...
nheather Posted October 11, 2021 Author Share Posted October 11, 2021 6 hours ago, ICMF said: You're confusing pixel size - X/Y resolution - with layer height - Z resolution. The two variables are entirely divorced from each other. Higher X/Y resolution doesn't need any more or less time, it just prints bigger pixels. Thinner layer heights (higher Z resolution) DOES effectively take longer, because you need to print more layers*. X/Y resolution is fixed on a printer - whatever screen you have, that's your resolution, and you can not change it. Layer height IS user configurable depending on the print, but this is the same on every mSLA printer - they'll all print pretty much the same range of usable layer heights no matter what the X/Y resolution is. There's a small caveat that a smaller pixel size might have a thinner ideal theoretical layer height, but in practice, it's not going to make much difference to the way users actually print with them. FWIW, actual exposure times will be lower, because you're not exposing as much resin at a time, but it'll be net slower because you've got to raise/lower the print bed more times, which takes most of the actual print time anyway. I’m not really confusing them, I understand the difference, but I appreciate where you are coming from. But my question remains, at mini size, XY resolution is typically ranges from 80u, 50u, 35u and 22u depending on the pixel resolution of the LCD (for the same size build plate). I understand that the whole layer is printed at once do takes the same time regardless of the number of pixels printed. I agree that the level height is independent but I was saying is that if you do want to reduce it to match the XY size (so you are printing cubes not oblongs) then the print will take longer. The point of my question is 1k, 2k, 4k, 8k (80u, 50u, 35u, 22u), realistically, at what point does the human eye stop being able to tell the difference. If you printed at the same layer height can the human eye discern the difference between the prints from 2k and 4k budget printers. To me it makes sense to bring out higher resolution screens to accommodate bigger build plates, but not so convinced with this trend to squeeze more and more pixels into similar sized mini plates, but interested to hear what others think. Cheers, Nigel 1 Link to comment Share on other sites More sharing options...
ChocolateCrisps Posted October 11, 2021 Share Posted October 11, 2021 These are probably both quite niche, but for me, the two main areas I've been interested in these very high resolution printers are for text and transparencies. I feel like these are both things where further increases in resolution will have an impact that's visible to the human eye, but I understand that they're not what most users of these printers are likely to be needing them for, so I can't comment on whether the increased resolution is really necessary... Link to comment Share on other sites More sharing options...
nheather Posted October 11, 2021 Author Share Posted October 11, 2021 Think I’m going to hold off. I missed the Mars 3 pre-order. I tried for the AnyCubic ultra but fell victim to the kickstarter crash. Then their is the Phrozen 8k, interesting, looks like a good price but then you need to add postage, VAT and admin fees. I’d like to see what the DLP technology is like - see some real world reviews. I’m not convinced that xy resolution matters, sure in some cases, but generally not. We shall see because the AnyCubic Ultra is 80u which on paper makes it a low resolution printer but the technology is meant to offset that. The real issue with the ultra is the tiny build plate. With the technology advancing fast with a new ‘leap’ every year I’m not convinced that paying premium for the latest is the best way to go. Cheers, Nigel Link to comment Share on other sites More sharing options...
bootneck Posted October 11, 2021 Share Posted October 11, 2021 I to agree that, unless you want to do nameplates on OO scale locomotives or other minute detail, then a standard printer still gives good detail. I have had an Anycubic Photon for about 10 months and am happy with the output I get; plus I don't even print at the highest resolution. Printed with Anycubic Photon S and using Anycubic's ECO plant based UV resin, no need for IPA to clean. cheers, Mike 4 Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted October 11, 2021 Share Posted October 11, 2021 9 hours ago, nheather said: If you printed at the same layer height can the human eye discern the difference between the prints from 2k and 4k budget printers. In figures and busts, yes I think so. You get contour lines showing up on what should be smooth skin on every amateur printed model I've ever seen. Some better. some worse, but always something. 1 Link to comment Share on other sites More sharing options...
Andy Moore Posted October 12, 2021 Share Posted October 12, 2021 On 11/10/2021 at 17:51, Bertie Psmith said: In figures and busts, yes I think so. You get contour lines showing up on what should be smooth skin on every amateur printed model I've ever seen. Some better. some worse, but always something. The contour lines come mainly from the layer hight on the Z axis, and as such aren't really connected to the screen resolution. All the Mars printers, and I imagine most other resin printers can go down to a 0.01mm layer hight which would smooth out the contouring by creating more, but lower steps. The downside is that you'd get really long print times. In practice, the contouring only really shows up in close-up photos. To the naked eye the prints look fine. The bust in the photo below was printed on my Mars Pro, which only has a 2k screen, and was printed with 0.05 layer hight, and the contouring is only just discernible in the zoomed-in section. I've not tried the Mars 3 or any other 4k printer, but I doubt the extra X,Y resolution would dramatically increase the detail on the print. The Anycubic DLP should presumably give slightly crisper details, but we'll have to wait and see. Andy 1 Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted October 12, 2021 Share Posted October 12, 2021 It would appear that my eyes aren't to be trusted. Whatever. Link to comment Share on other sites More sharing options...
nheather Posted October 13, 2021 Author Share Posted October 13, 2021 12 hours ago, Andy Moore said: The contour lines come mainly from the layer hight on the Z axis, and as such aren't really connected to the screen resolution. All the Mars printers, and I imagine most other resin printers can go down to a 0.01mm layer hight which would smooth out the contouring by creating more, but lower steps. The downside is that you'd get really long print times. In practice, the contouring only really shows up in close-up photos. To the naked eye the prints look fine. The bust in the photo below was printed on my Mars Pro, which only has a 2k screen, and was printed with 0.05 layer hight, and the contouring is only just discernible in the zoomed-in section. I've not tried the Mars 3 or any other 4k printer, but I doubt the extra X,Y resolution would dramatically increase the detail on the print. The Anycubic DLP should presumably give slightly crisper details, but we'll have to wait and see. Andy Many thanks for this, it goes some way to confirm my thoughts. New 4k, 8k and DLP printers are very enticing but they are more expensive to buy unless you are lucky enough to catch an early bird. And I wonder about maintenance - I’ve read that inevitably LCD screens have to be replaced from time to time, and would a 4k or 8k screen be more expensive than a 2k screen. What got me thinking about this is the AnyCubic Ultra DLP which on paper has a poor resolution, just 80u but the prints that are being showcased look stunning - but bear in mind that the only videos and reviews to date are coming from AnyCubic and their supporters. Where I do think higher resolutions are put to best use is for bigger build plates - in fact we saw the reverse in the AnyCubic ultra, which with a 720P array has to reduce the build plate to little more than a credit card just to achieve a 80u XY resolution. I don’t need a big build plate for my needs but even so the Ultra is probably too small. With the Phrozen you need to add delivery, taxes and admin charges so they are more expensive than they first appear. So I am still looking at the Mars 3 (still kicking myself that I missed the pre-order) but the reason I started this is that I wonder whether I would be better off with a Mars 2 plus a wash and cure for the same price. Cheers, Nigel Link to comment Share on other sites More sharing options...
bootneck Posted October 13, 2021 Share Posted October 13, 2021 2 hours ago, nheather said: So I am still looking at the Mars 3 (still kicking myself that I missed the pre-order) but the reason I started this is that I wonder whether I would be better off with a Mars 2 plus a wash and cure for the same price. My understanding is that the wash and cure setup is only useful for the standard, toxic, resins and is no use for the plant based ECO resins. I used the plant based resins on my vehicles and radar in the photos I showed, then just give them a swirl in warm soapy water. A rinse in warm clean water then blast with swmbo's hair dryer and they are ready for curing in sunlight. Don't think I can achieve anything cheaper than that, plus that method doesn't take up any room. cheers, Mike 2 Link to comment Share on other sites More sharing options...
nheather Posted October 13, 2021 Author Share Posted October 13, 2021 2 hours ago, bootneck said: My understanding is that the wash and cure setup is only useful for the standard, toxic, resins and is no use for the plant based ECO resins. I used the plant based resins on my vehicles and radar in the photos I showed, then just give them a swirl in warm soapy water. A rinse in warm clean water then blast with swmbo's hair dryer and they are ready for curing in sunlight. Don't think I can achieve anything cheaper than that, plus that method doesn't take up any room. cheers, Mike That does sound good. Must admit that I was aware of plant-based resins but had dismissed them as I assumed that they would be a compromise - cleaner but not as good. Have you tried both standard and plant-based resins - if so do you find them the same - same precision/accuracy, same strength etc. Many thanks, Nigel Link to comment Share on other sites More sharing options...
bootneck Posted October 13, 2021 Share Posted October 13, 2021 Hi Nigel, I didn't find any noticeable difference, although I did change to plant based very early in my learning on 3D printing because I developed a very serious chesty cough, almost like bronchitis, even though I wore gloves and mask whilst cleaning. The fumes must have been in the air during the printing, or the IPA was too strong for me when cleaning afterwards. The cough disappeared as soon as I changed to plant based and soapy water. Herewith some views of printing with the standard, toxic, resin. Settings all to a layer height of 0.05mm. and with plant based resin. Mike 1 Link to comment Share on other sites More sharing options...
TheBaron Posted October 15, 2021 Share Posted October 15, 2021 On 13/10/2021 at 13:37, bootneck said: The fumes must have been in the air during the printing, or the IPA was too strong for me when cleaning afterwards. The cough disappeared as soon as I changed to plant based and soapy water. That's interesting Mike and good to know. I've used a standard resin/IPA process for the last couple of years and occasionally find the fumes an issue, mainly in winter when keeping the studio heated to printing temps. May I ask if you have you tried the plant based stuff below the 0.05 level? Best, Tony Link to comment Share on other sites More sharing options...
bootneck Posted October 15, 2021 Share Posted October 15, 2021 Hi Tony, not yet, I'm still at the experimental stage of learning CAD; so the printing is more for test prints at the moment. cheers, Mike 1 Link to comment Share on other sites More sharing options...
Alvaro Rodriguez Posted October 26, 2021 Share Posted October 26, 2021 Interesting topic indeed! While we are used to measure the printer performance on objective data, in the paper the smaller the resolution the better always, this uses to turn into a subjective matter when this also uses to depend on its impact on the actual print and the end-user preferences often. If you ask me, I would say that current mono LCDs 0.050mm resolution is a rather effective one covering almost everything you may want to print, from tiny and fine parts to bigger and much detailed figurines and busts. And combining the 0.050mm resolution with the matching 0.050mm layer height delivers a much convenient comprise between surface detail and printing speed too so we are good to go. Do not led the specs to mislead you. But, there is a but always because that´s not all. The print geometry and shapes also play here. Organic shapes use to be more forgiving than geometrical / mechanical ones often. And the scale is also relevant. In the case of the layer steps, the bigger the print the less relevant they use to be in example. I use to print small 72nd or 48th scale parts. For me the resolution and the layer step uses to be relevant always and I can notice its impact in my prints. So I´m pretty sure that a smaller resolution printer (matched with a lower layer height) should deliver better prints for my needs. Now, for rapid prototyping, I use to print at 0.050 layer height but for some parts I decrease it for having a smoother surface in example. Do not get me wrong, 0.050mm resolution is far enough for having all the tiny and fragile details I would need (no regrets in this area) but a smaller resolution printer would also give me a smoother and more detailed cross section too. These jerrycans are 72nd scale... not bad for a 2K printer. Funny enough, a few days ago I test printed a rather big –for my standards- 1/24th scale wheel prototype at 0.050mm layer height and I would say that was the best wheel I have ever printed, no matter that layer height and printer resolution, just because the bigger size minimized their impact in the actual print. It looked perfect! So far I have been resin 3D printing for a couple of years using the cheapest 3D printers out there and I have zero regrets, quite the opposite. And while I would love to give it a try to one of those 4K or 8K printers I´m not in the urgent need of switching for a more precise one, no matter I positively know I´ll do in due time. But fact is that every time I see what is in my 2K mono build plate after a print run my jaw drops the floor like day one actually. I think that this tech is already mature enough for delivering a more than reasonable surface finish and detail good enough for anyone... and it´s faster than scratchbuilding! Yes, there is some room for improvement in resolution but if that´s relevant and a must have for you it is a question linked to what you will be printing in the first place. Not necessarily a higher resolution printer will deliver better prints for your needs. Regards! Alvaro 3 Link to comment Share on other sites More sharing options...
PeteH1969 Posted November 7, 2021 Share Posted November 7, 2021 A question: When printing wheels 72nd & 48th @ 4K .030 layer thickness, what is the best way to orientate the .stl files in the Software (Chitubox) to get the best printed results please? Vertical, Horizontal or angled any advice would be appreciated? Pete Link to comment Share on other sites More sharing options...
Twobad Posted November 8, 2021 Share Posted November 8, 2021 I've posted this elsewhere, but it is pertinent to the original question. I started off getting prints done at a commercial print bureau, and eventually decided that I was spending enough to invest in my own 3D printer. I went for a Phrozen Sonic Mini 4k. The pictures going clockwise from top left are: Phrozen 4k at 35um, print bureau at 50um, cheapskate's stamp, another 35um print cleaned too vigorously resulting in some detail being brushed off. The prints are simply text raised vertically and have no slanting components which would suffer from Z-axis resolution. The same STL has been used for the prints. 5 1 Link to comment Share on other sites More sharing options...
salomon Posted May 1, 2022 Share Posted May 1, 2022 Hello, great to find a post for the 3D printer, I bought an Anycubic mono x and use the waterbase elegoo resine for the same reason that mentionned bootneck, but I can't print a simple objet properly, a lot of annoying step effet and I can't find a good setting within explosure thing. Here is the bad result, some advice for that? And this is my 3D File of the ASMPA MBDA Missile in 48 scale. I can send the file if one of you guys wanna test it, thank you. Link to comment Share on other sites More sharing options...
Twobad Posted November 8, 2022 Share Posted November 8, 2022 On 5/1/2022 at 10:15 PM, salomon said: Hello, great to find a post for the 3D printer, I bought an Anycubic mono x and use the waterbase elegoo resine for the same reason that mentionned bootneck, but I can't print a simple objet properly, a lot of annoying step effet and I can't find a good setting within explosure thing. ... I can send the file if one of you guys wanna test it, thank you. My first recommendation would be to print the items at a slight angle to vertical. They appear to be perpendicular. That should help a bit. Also, it depends on which slicing software you are using, but in Chitubox I'd experiment with the anti-aliasing, grey level and pixel blurring settings, if you haven't already. They are under the advanced tab if you aren't familiar with it. Link to comment Share on other sites More sharing options...
Rob de Bie Posted January 20, 2023 Share Posted January 20, 2023 On 5/1/2022 at 11:15 PM, salomon said: Hello, great to find a post for the 3D printer, I bought an Anycubic mono x and use the waterbase elegoo resine for the same reason that mentionned bootneck, but I can't print a simple objet properly, a lot of annoying step effet and I can't find a good setting within explosure thing. I can send the file if one of you guys wanna test it, thank you. Very nice!! I bought the 'Model Art' 1/72 resin kit, but the fuselage diameter was visibly too small. I wrote a brief review of the model: https://robdebie.home.xs4all.nl/models/asmp.htm 'Jane's Air-launched Weapons' (Issue 43) says the body diameter is 380 mm, or 7.9 mm in 1/48 scale. Did you find the same number? I would love a correct 1/72 ASMP. Would you consider selling a print? Or maybe the STL file? Rob Link to comment Share on other sites More sharing options...
salomon Posted January 22, 2023 Share Posted January 22, 2023 I missed to read the Twobad message, yes I printed it vertically and I had not tested all the settings on Chitubox again. At the moment I have very little time to take care of 3D printing unfortunately. Bob de Pie: In my opinion, the 'Model Art' 1/72 resin kit has alot of mistake about the real shape, the Heller's one is better but the details are so basic. Lots of french airplane can load the ASMP weapon but the carrying pylon changes, in my case I drew the support for the Rafale, I have not yet looked at the Mirage 2000. If you are in the European Community and the Shipping costs are cheaper than other countries, I could print this missile to you. I think I have to modify the original file to exaggerate the lines and details. My drawing was based on reality and the details are so fine that 48 we barely see the lines, compared to the Rafale from Revell at the same scale, my ASMPs and its pylon are too smooth. Link to comment Share on other sites More sharing options...
Rob de Bie Posted February 5, 2023 Share Posted February 5, 2023 On 1/22/2023 at 2:34 PM, salomon said: Lots of french airplane can load the ASMP weapon but the carrying pylon changes, in my case I drew the support for the Rafale, I have not yet looked at the Mirage 2000. If you are in the European Community and the Shipping costs are cheaper than other countries, I could print this missile to you. I think I have to modify the original file to exaggerate the lines and details. My drawing was based on reality and the details are so fine that 48 we barely see the lines, compared to the Rafale from Revell at the same scale, my ASMPs and its pylon are too smooth. Salomon, I'm still very interested in obtaining one of your ASMPs in 1/72 scale. But it sounds like it's quite a bit of work for you to exaggerate the lines and details? I'm quite good at rescribing, even faint lines, so maybe the 1/48 version printed at 66% size would do? Rob de Bie / Bob de Pie / Pob de Ieb Link to comment Share on other sites More sharing options...
