Dogtail2 Posted October 7, 2021 Share Posted October 7, 2021 Not sure if this is the right place to post this.....but, I'm building an ICM Bf 109 F4 which has a separate clear piece for the armoured windscreen which must be attached to the front of the standard windscreen. How would I best glue this on without spoiling either/both transparencies? Thanks in advance for any advice. Link to comment Share on other sites More sharing options...
Chaotic Mike Posted October 7, 2021 Share Posted October 7, 2021 PVA (white) glue is your friend... It dries transparent. 4 1 Link to comment Share on other sites More sharing options...
billn53 Posted October 7, 2021 Share Posted October 7, 2021 Another possibility is to use Future/Pledge, or a clear varnish — but I’ve not tried that before so take my suggestion with a big grain of salt. 1 1 Link to comment Share on other sites More sharing options...
Walter Posted October 8, 2021 Share Posted October 8, 2021 What they said 👆 1 1 Link to comment Share on other sites More sharing options...
Andy Young Posted October 8, 2021 Share Posted October 8, 2021 Good thing about PVA is that you could always (carefully) remove it if it doesn’t go right first time. Good luck! Cheers, Andy 1 Link to comment Share on other sites More sharing options...
Dogtail2 Posted October 8, 2021 Author Share Posted October 8, 2021 Thanks for the replies. I thought about using micro kristal klear or pva, but I was worried I might end up with a visible puddle between glass layers. I think I will experiment with all your suggestions on some scrap clear plastc. Thanks again. 1 Link to comment Share on other sites More sharing options...
bmwh548 Posted October 8, 2021 Share Posted October 8, 2021 PVA glue with the advice to apply a uniform layer of it. If it doesn't get complete "coverage" you'll see the edges when you look carefully. 1 Link to comment Share on other sites More sharing options...
Someguy Posted November 7, 2021 Share Posted November 7, 2021 Why is everyone so scared of Plastic cement on clear parts? Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted November 8, 2021 Share Posted November 8, 2021 10 minutes ago, Someguy said: Why is everyone so scared of Plastic cement on clear parts? Most tend to fog the clear. I've had no problem with standard Tamiya extra thin or C/A after the clear pieces have been pledge dipped. Link to comment Share on other sites More sharing options...
Someguy Posted November 10, 2021 Share Posted November 10, 2021 On 11/7/2021 at 6:04 PM, Corsairfoxfouruncle said: Most tend to fog the clear. I've had no problem with standard Tamiya extra thin or C/A after the clear pieces have been pledge dipped. Well I dont dip my canopies in floor varnish and I've been using Tamiya Extra Thin on them for a decade and not once damaged one. It won't even fog if you slather it over the part to be left unpainted. It just melts the plastic which obscures it beyond repair usually. But TETs capillary action makes it virtually impossible to screw up if you're just careful where you touch the brush to the parts. 1 Link to comment Share on other sites More sharing options...
colin Posted November 10, 2021 Share Posted November 10, 2021 Trouble with TET it's capillary action is so good it can spill onto areas you don't want, especially if two flat pieces are touching. 1 Link to comment Share on other sites More sharing options...
MicroGaz Posted November 14, 2021 Share Posted November 14, 2021 I have used the new Deluxe Materials Looks Like Glass and had good results. Just apply it very sparingly. And of course it's good for dipping too, that's what it was designed for..Works for me! Gaz Link to comment Share on other sites More sharing options...
