Владимир Мишонин Posted October 2, 2021 Share Posted October 2, 2021 (edited) A valid retail price list for our products. We accept payment in US dollars, through the Pay Pal system. The cost of the kits and postage services is indicated in the price list. When purchasing several sets, we will weigh your order and calculate the cost of complex delivery (do not worry, we will not take extra money from you). We send parcels twice a week. All parcels are declared and tracked with a postal track number. 1/32 upgrades and convertion sets #319 RV-2 Radioaltimeter antennas. 3D printed (ten items per set) $7.00 1/48 upgrades and convertion sets #481 Lockheed C-130E/H correct powerplant resin set, T-56A-15 engines & HS 54H60 props (for Italeri kit) $37.80 #483 Lockheed C-130 control surfaces universal resin set, for all series C-130 (for Italeri kit) $33.50 #484 Lockheed C-130B/F correct powerplant resin set, T-56A-15 engines & HS 54H60-91 props (for Italeri kit) $37.80 #485 Lockheed C-130H+NP2000, T-56A-15 engines & NP2000 eightblades props convertions resin set (for Italeri kit) $37.80 #487 Lockheed C-130A powerplant convertions resin set, T-56A-9 engines & A6341FN-D1A props (for Italeri kit) $52.20 #487-1 Lockheed C-130A modernised powerplant convertions resin set T-56A-9 engines & HS 54H60-91 props (for Italeri kit) $52.20 #487-2 Lockheed C-130A survivers powerplant convertions resin set T-56A-9 engines & HS 54H60 props (for Italeri kit) $52.20 #476 RV-2 Radioaltimeter antennas. 3D printed (ten items per set) $6.00 #477. 1/48. GAU-2B/A - M-134 barrels block. classic type. 3D printed $6.00 #478. 1/48. GAU-2B/A - M-134 barrels block. classic type. with the big flash hider. 3D printed $6.00 #479. 1/48. GAU-2B/A - M-134 barrels block. classic type. with the tulip flash hiders. 3D printed $6.00 #482 Lockheed C-130B/F propblades, airscrew HS 54Н60-91 series (for Italeri kit) $16.50 #488 Grumman E-2C/D & C-2A, correct airscrews NP2000 resin set (for Kinetic & Italeri kits) $19.90 #491 Lockheed С-130А “Roman Nose” resin set(for Italeri kit) $19.80 #492 Messerschmitt Bf-109E control surfaces (for Eduard) $10.90 #493 Messerschmitt Bf-109F/G control surfaces (for Eduard & Zvezda) $9.90 #494 Messerschmitt Bf-109G/K control surfaces (for Eduard & Zvezda) $9.90 #501 С-130A/B/Е/Н resin exausts ends, for Allison T-56 engine series $19.80 #502 С-130J resin exausts ends, for Rolls Royce 2100 engine series $19.80 #503 JATO KS15-1000-A1 rocket boosters resin set $14.30 #504 Beechcraft 18/C-45 later series convertions set $18.50 #505 Lockheed C-130 wheels, RAF & European operators, circa 60-80 XX. $25.50 #515 Lockheed C-130 wheels, USAF & worldwide, circa 60-70 XX. $25.50 #522 Lockheed C-130 wheels, USAF & worldwide, circa 90 XX - 00 XXI. $25.50 1/72 upgrades and convertion sets #715 Refuelling pods resin set. Cobham "48. Most usually refuelling pods for KC-130 series $18.00 #716 Refuelling pods resin set. Cobham 900E. Refuelling pods for KC-130 JASDF and later MC-130H series $18.00 #717 Refuelling pods resin set. Cobham 908E. Refuelling pods for German AF A 400M $18.00 #721 Lockheed C-130E/H correct powerplant resin set. T-56A-15 engines & HS 54H60 props (for Italeri kit) $27.00 #723 Lockheed C-130 control surfaces universal resin set, for all series C-130 (for Italeri kit) $23.50 #724 Lockheed C-130B/F correct powerplant resin set, T-56A-15 engines & HS 54H60-91 props (for Italeri kit) $27.00 #725 Lockheed C-130H+NP2000 pwerplant convertions resin set, T-56A-15 engines & NP2000 eightblades props (for Italeri kit) $27.00 #736ZV Lockheed C-130 control surfaces universal resin set, for all series C-130 (for Zvezda kit) $23.50 #708 RV-2 Radioaltimeter antennas. 3D printed (ten items per set) $5.00 #710. 1/72. GAU-2B/A - M-134 barrels block. classic type. 3D printed $5.00 #711. 1/72. GAU-2B/A - M-134 barrels block. classic type. with the big flash hider. 3D printed $5.00 #712. 1/72. GAU-2B/A - M-134 barrels block. classic type. with the tulip flash hiders. 3D printed $5.00 #720 JATO KS15-1000-A1 rocket boosters resin set $9.90 #722 Lockheed C-130B/F propblades, airscrew HS 54Н60-91 series (for Italeri kit) $12.00 #738 С-130A/B/Е/Н resin exausts ends, universal set, for Allison T-56 engine series $12.00 #739 С-130J resin exausts ends, universal set, for RR 2100 engine series $12.00 #728ZV Lockheed C-130H3, NP2000 airscrews convertions resin set (for Zvezda kit) $17.80 #740 Mikoyan MiG-25 ventral fuel tank (for ICM kit) $8.50 #741ZV Lockheed L-100-20/30 resin stretching plugs (for Zvezda kit) $23.50 #793 Beriev Be-12. AV-68D airscrews (later type) (for Modelsvit Be-12 kit) $12.80 #793-1 Beriev Be-12. AV-68D airscrews (earlier type) (for Modelsvit Be-12 kit) $12.80 #794 Antonov An-8. AV-68D airscrews (for Amodel An-8 kit) $9.90 #795 Antonov An-12/Ilyushin IL-18. AV-68i airscrews (later type) (for Roden An-12 & Amodel IL-18 kits) $17.80 #795-1 Antonov An-12/Ilyushin IL-18. AV-68i airscrews (earlier type) (for Roden An-12 & Amodel IL-18 kits) $17.80 #796 Antonov An-24/26/30. AV-72 airscrews (later type) ( Amodel An-24/26/30 kits) $11.90 #796-1 Antonov An-24/26/30. AV-72 airscrews (earlier type) ( Amodel An-24/26/30 kits) $11.90 #797 Antonov An-32. AV-68DM airscrews ( Amodel An-32 kit) $11.90 #798 Tupolev Tu-95 AV-60 airscrews (later type), for Trumpeter & Amodel kits $32.00 #798-1 Tupolev Tu-95 AV-60 airscrews (earlier type), for Trumpeter & Amodel kits $32.00 #800 Lockheed C-130 wheels, RAF & European operators, circa 60-80 XX. $18.90 #801 Lockheed C-130 wheels, RAF & European operators, circa 80-present times. $18.90 #804 Lockheed YC-130 & earliest C-130A wheels, USAF, circa 50-60 XX. $18.90 #805 Lockheed C-130 wheels, NAVY & USMC, circa 60-70 XX. $18.90 #807 Lockheed C-130 wheels, NAVY & USMC, circa 80-90 XX. $18.90 #809 Lockheed C-130 wheels, USAF & worldwide, circa 60-70 XX. $18.90 #811 Lockheed C-130 wheels, USAF & worldwide, circa 80-90 XX. $18.90 #815 Lockheed C-130 wheels, USAF & worldwide, present times. Modernised with UTC Aerospace rims and brakes. $18.90 #816 Lockheed C-130 wheels, USAF & worldwide, circa 90 XX - 00 XXI. $18.90 #817 Lockheed C-130 wheels, RAF service, present times. Modernised with UTC Aerospace rims and brakes. $18.90 1/144 upgrades and convertion sets #144001 Boeing B 777 resin wheels set. $17.80 standard wet decals #481D Lockheed C-130 B/D/F/E/H/K stencils HS 54Н60 airscrew $8.80 #721D Lockheed C-130 B/D/F/E/H/K stencils HS 54Н60 airscrew $8.80 laserprint wet decals #722D deicers panels AV-64 & AV-68 airscrew, later series $5.00 #722D-1 deicers panels AV-64 & AV-68 airscrew, earlier series $5.00 #723D deicers panels AV-72 airscrew, later series $5.00 #723D-1 deicers panels AV-72 airscrew, earlier series $5.00 #724D deicers panels AV-62i airscrew $5.00 #725D deicers panels AV-60 airscrew, earlier series $6.00 #725D-1 deicers panels AV-60 airscrew, later series $6.00 #726D deicers panels Aeroproduct A644FN-C airscrew $5.00 #727D deicers panels Hamilton Standard 43E60 airscrew $5.00 canopy 1/48 postals for this sets are $7.50 per each #438 F/A-18A/C (Hasegawa) corrected $6.00 #439 Lavochkin LaGG-3 (ICM) corrected $6.00 #440 Lavochkin La-5 (Zvezda) stock copy $6.00 #441 Yakovlev Yak-9 (ICM/Alanger) corrected $6.00 #442 N.A. P-51C (ICM/Tamiya) stock copy $6.00 #443 N.A. P-51B (ICM/Tamiya) stock copy $6.00 #444 Mi-24V/VP (Zvezda) corrected, with mask $10.50 #445 Bf-109E-4/7 (Eduard/Zvezda) stock copy $6.00 #447 Bf-109G-6/G-10 (Eduard/Zvezda) stock copy $6.00 #448 Bf-109K/G-14 (Eduard/Zvezda) stock copy $6.00 #449 Spitfire Mk.VIII (ICM) corrected $6.00 #450 Mikoyan MiG-3 (ARKmodels) stock copy $6.00 canopy 1/72 postals for this sets are $7.50 per each #744 A-6E (Fujimi) corrected $6.00 #745 B-29/B-50Е/Тu-4 (Аcademy/Моdelist) stock copy with mask $10.50 #746 Аn-12 (Roden) stock copy with mask $9.00 #747 Аn-14 (VEB-Plasticart/Reifra) corrected $7.00 #748 AVRO Shackleton Mk.3 (FROG/NOVO/EE) stock copy $5.00 #749 Мi-8 (Zvezda) corrected $5.00 #750 Shin-Meiwa PS/US-1 (Hasegawa) stock copy $6.00 #751 IL-76/78 (Амоdel) stock copy $9.00 #752 W. Lynx (Hobby Boss) stock copy $6.00 #753 Ка-29 (Zvezda) stock copy $4.50 #754 Be-12 (Моdelsvit) corrected $6.00 #756 Ка-52 (Zvezda)stock copy $5.50 #757 P-47D-25 (Tamiya) stock copy $4.50 #758 P-47D-15 (Tamiya) stock copy $4.50 #759 P-47M (Revell)stock copy $4.50 #760 A-1H Skyraider (Hasegawa) stock copy $4.50 #761 Мi-24А (Zvezda) stock copy, with masks $9.00 #762 Еr-2 (Amodel) corrected $8.00 #763 Ме-410 (Fine Molds) corrected $5.00 #764 Shorts "Tucano" T.1 (Airfix) stock copy $5.00 #765 MiG-15 (Eduard) stock copy $4.50 #766 Su-35S (Hasegawa) stock copy $5.00 #767 A-20J "Havoc" (MPM) stock copy $6.00 #768 F/A-18A (Hasegawa) stock copy $5.00 #769 F/A-18A (Fujimi) stock copy $5.00 #770 F/A-18E (Revell) stock copy $5.00 #771 F/A-18F (Revell) stock copy $5.00 #772 МiG-3 (Hobby Boss) corrected $4.50 #773 SB (ICM) corrected $7.00 #774 Ju-290A-5 (Revell) corrected $9.50 #775 G3M "Nell" (Hasegawa) stock copy $6.30 #776 Vought A-7E Corsair II (Fujimi) stock copy $4.50 #777 Мi-24V/VP (Zvezda) corrected, with mask $9.00 #778 Мi-6 (Amodel) stock copy $7.00 #779 Yak-3 (Zvezda) stock copy $4.50 #780 Polikarpov fighters set: I-5, I-15bis, I-153, I-16, I-16-4/5 $5.50 #781 Pе-8 (Zvezda) corrected $9.00 #782 Blohm & Voss BV-138 (Revell) corrected $8.00 #783 Blohm & Voss BV-222 (Revell) corrected $9.00 #784 Аn-28 (Amodel) stock copy $7.00 #785 Su-12 (MSD/Kopro) corrected $9.00 #786 МBR-2 (Eastern Express) corrected $5.50 #787 Henschel Hs-126 (Airfix) corrected $4.50 #788 Nakajima Ki-49 (Hasegawa) corrected $6.30 #789 Heinkel He-111B (Roden) corrected $7.50 #790 МiG-31B (ICM) stock copy $4.50 #791 F-14A (Academy) corrected $5.00 #792 Aero L-39 (Modelist) corrected $5.00 #793 Sukhoi Su-33 (Zvezda) stock copy $4.50 Edited March 26 by Владимир Мишонин 1 Link to comment Share on other sites More sharing options...
