Chaotic Mike Posted October 2, 2021 Share Posted October 2, 2021 Hello, I just got access to a 4k Elegoo Mars, the quality is amazing. Does anyone have any experience with 3D scanning, eg hardware, how good/bad are the results, etc? Mike Link to comment Share on other sites More sharing options...
Schwarz-Brot Posted October 2, 2021 Share Posted October 2, 2021 Can be done, but the results usually require lots of cleanup. Some professional software as well as hardware is out there that helps a lot and costs a lot as well. There are open source options, but the overhead of cleaning up the files always let me go back to draw the parts right away. Cheapish consumer options I have not tried. One thing one must understand is that you can only scan what your camera(s) can see in a straight line. So any overhang kills all the information that lies underneath and the software cannot correct for that, so assumes closed surfaces. Link to comment Share on other sites More sharing options...
Chaotic Mike Posted October 2, 2021 Author Share Posted October 2, 2021 I'm a bit of a believer in the 'You don't get anything for free' school of thought, so that doesn't surprise me. The options on my radar are either (1) get a cheapish bit of kit to do the basics, then remodel in Fusion or similar using the scan as a backdrop, or (2) get a bureau service to do scan and cleanup ready for printing. This thread is targeting option (1). I have quite a lot of experience in 2D digitisation and clean up with Inkscape and Canvas (that takes me back 30 years!), partly I am interested in seeing how the principles move into 3 virtual dimensions. Mike Link to comment Share on other sites More sharing options...
Stu_davros Posted October 2, 2021 Share Posted October 2, 2021 I bought a Shining 3D SE a few months ago, it's OK for larger scans (above 30-40mm) but for small parts it's not great. The quality of the scans is OK but not really what I wanted for detail levels and you do get a degradation of detail because it's a copy. (Some of this may be where I need to learn to use the scanner better) I would probably say that learning Fusion 360 would be the way to go for ultimate detail (and cost). Cheers, Stuart Link to comment Share on other sites More sharing options...
