Mike Posted September 27, 2021 Share Posted September 27, 2021 Eclipse Side-Feed Takumi Airbrush (ECL350T) Iwata via The Airbrush Company My first slightly reasonable airbrush was the Humbrol airbrush that was pretty far from reasonable if I’m honest, but it was a side-feed airbrush, relying on gravity to help the paint flow out of the cup and into the body from the side, rather than from above, directly in front of the needle. This combines the benefits of gravity working on your behalf to supply your airbrush with paint, with the lack of obstacle right in your view of the front of the airbrush. This certainly renders it worth a look, especially as it’s from Iwata. We’re probably all quite familiar with Iwata, who have an excellent reputation for producing high quality tools for the airbrush artist (we’ll call ourselves artists, why not?), and have been doing so for many years now, with a huge variety of airbrushes of all varieties in their catalogue, in a variety of needle widths, trigger types and cup sizes to suit your line of work. In Japanese art circles, a highly-skilled artist with years of experience under their belt garners the name Takumi, a master craftsman. This airbrush arrives in a cardboard sleeved thick cardboard box, and after cutting the tape the lid slides slowly off to reveal a turquoise foam liner that cradles the airbrush and some additional parts within. The ‘brush is finished in high-gloss reflective chrome, and the 0.24oz/7ml paint cup is removable, sitting above the body within its own cut-out, with another cut-out below for the nozzle spanner, and a final recess for a small tube of Iwata Lube silicone-free airbrush oil. There are other pockets for parts that have been cut but not removed, showing that two larger paint cups could be fitted into the box if a different option was purchased. One looks large enough to take a diluted bottle of your average model paint with ease, and from the drawings on the short instruction sheet, it converts the brush to operate using a syphon feed, further increasing your options. Removing the airbrush is simple thanks to relief around the rear of the cut-out, which shows off the compact body, tipped with a soft clear protector slipped over the crown, the large flat trigger with its grippy surface, and the inlet for the paint cup, which caters for both left- and right-handed users, having two inlets and a stopper than can be transferred between them, allowing paint ingress through either orifice, with the plugged side preventing pass-through. Both fit using friction, thanks to some high-quality milling of the two parts at the factory. Chances are that if you are going to move them, you’ll only do it once unless you are that rare beast – an ambidextrous modeller! The stopper will doubtless get quite a grip of the aperture, so if you ever envisage changing it, make it a regular task to remove it and clean any debris to prevent it silting up and jamming. The handle of the brush has two cut-outs in its sides that allow you to adjust the chucking of the needle without removing the handle, and at the rear is a knurled knob that you can screw in or out to give you a “bump-stop” that will allow you to select the same flow width again-and-again, if for example you are painting mottled camouflage. Removing the handle shows a rubber washer around the join that will help prevent the handle sticking in place on the body. The needle screw is fully visible, and the tension adjuster just in front of it is exposed. If you’re like me, you’ll wind that all the way in at the beginning and only touch it again to either make sure it hasn’t wound back out, or to remove the rear internals by unscrewing them for seriously deep maintenance. At the front, the flexible cap comes off with light finger-pressure, and should be kept handy, as it is useful for back-flushing your brush during cleaning, remembering to put your fingertip over the little hole in the end. The crown is now visible, protecting the delicate ip of the needle from harm during light fumbling or delicate droppage. The four-pronged crown can be unscrewed to offer very slight smoothing of airflow for delicate painting, although the difference is so slight that I might be imagining it, and it might just be that I can both see the surface better, as well as get the needle fractionally closer to my work. The air cap is then visible, and this too unscrews to show the front of the nozzle and the tip of the needle, which is the most delicate part of any airbrush, so should be kept as safe as possible at all times. The very tip of the nozzle has flats on it implying that it can be removed, but the spanner included with this set isn’t suitable for the task, and I understand that the bi-metal nozzles aren’t meant to be separated, so take the hint and leave it in place like a sensible user. Instead, the large spanner grips the flats machined into the outer forward body of the brush, allowing the user to remove that and then free off the teardrop-shaped complete nozzle from its depression, permitting you to remove the needle forward for deep cleaning and to avoid dragging paint through to the rear. The aft section of the nozzle is brass, while the tip where the finest tooling has been carried out is a robust, long-lasting silver-coloured alloy that is unlikely to split unless you handle it very roughly, at which stage you’ll already have bigger problems. Brass wouldn’t hold up very long at all by comparison. In general usage the needle is removed from the rear after loosening the chuck, and here again the compact size of the airbrush shows itself in the length of the needle, which is 0.35mm at its tip, which makes it excellent for a general use airbrush that is capable of a great many spray widths, depending on how you use it. The technical data shows a spray pattern varying from 0.35mm to 50mm, which should suit most modellers’ needs. As proof of this, Iwata have included a small sheet of paper with the instructions that is a test sheet, showing both a tiny, narrow scribble in black that expands to a wide band and then fades out to a hazy trail of paint particles. The 7ml (0.24oz) tapered cup is finished in matching chrome, and has a long horizontal feed tube at the bottom, that mates with the body at the side. The lid has a lip inside to reduce dripping, and the syphon-cut breathing hole in the lid also helps to prevent paint build-up, gravity automatically decanting it back into the cup before it dries. The final part in the box is the lube, which should be used very sparingly away from the paint path to keep the various moving parts from sticking. This tiny tube should last years. The needle packing is PTFE, but unless you’re planning on soaking your airbrush in very ‘hot’ thinners, there shouldn’t be an issue, and I’ve used Mr Self-Levelling Thinners in many many airbrushes with PTFE seals over the years. I've now got a brand-new airbrush lying in pieces on my desk, so I’d better put it back together again and think next about painting something with it. I believe that’s called modelling, I think? In Action It wouldn’t be a review without running a bit of paint through the review sample, so I’ve done that. This is a medium sized needle, so I’ve been using it for medium-sized jobs. I primed a small model with some Alclad Grey Primer, and that came out lovely, with very little in the way of surface preparation needed for the next coat, which was to spray some Mirror by Stuart Semple, which I consider to be the best chrome paint I’ve ever used. It’s not cheap though, but you don’t use much because it’s so thin. The airbrush took both paints in its stride with no problems other than my own clumsiness, which is legendary. When cleaning the primer from the airbrush I managed to loosen the cup and it fell off and rolled down the front of my spray booth. Oopsie! On the upside, it didn’t dribble much paint, and what it did release was easy to clean up, but it illustrates the fact that you should push the cup well into the side of the airbrush, lest it come loose when you’re wiping paint away from the body. The surface of the Mirror came out nice and smooth, with a shiny surface that couldn’t be improved on much without putting real chrome on it. I know this is a review about the airbrush not the paint, but it’s worth noting that the Mirror paint is very thin, and Chrome is a tricky colour to spray consistently. With regard to the offset of the colour cup, I honestly didn't notice it after I’d filled it up with paint. It doesn’t noticeably affect the balance of the airbrush, and visibility is good thanks to the lack of cup in the way, which works for both left- and right-handers just as well if you switch the cup over. The tipped-forward trigger falls nicely to hand and is very grippy, adding little that could block your view of the work in progress, even with your finger in place. Clean-up is easy too, and being able to dismantle the whole nozzle is useful if you leave paint in your airbrush for too long, coupled with the compact nature of the airbrush itself will lend itself to anyone with small to medium hands who might find a standard sized ‘brush feels too large. I’ve got fairly large hands, and didn’t find any issues there, just noticing that it felt quite petite in my hand compared to my usual. Only the truly large-of-hand would find it too small, but then the whole modelling thing might be tricky if your hands are that big. Most gravity fed airbrushes are stuck with the one size of paint cup once you’ve bought them, unless you have the screw-on type. The side feed option takes the benefits of gravity feed with those of the syphon feed, and throws most of the negatives in the bin. The availability of larger cups that can hang downward and turn your ‘brush into a syphon-feed is useful for those that paint larger areas, or like to run several colour cups at once for a quick change. Conclusion This is a good quality airbrush with a feel in use that backs that opening phrase up all the way. It’s a great all-round ‘brush, and comes with everything you need to get going except the hose and possibly a Quick Release (QR) connector if you swap ‘brushes frequently like I do. Highly recommended. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
