Mike Posted September 21, 2021 Share Posted September 21, 2021 NX-326 USS Franklin Detail Set (06218-1/350 for Moebius) 1:350 GreenStrawberry The USS Franklin appeared in Star Trek Beyond, part of the new Kelvin Timeline series of films with that actor that wasn’t Bill Shatner – Chris Pine maybe? It was marooned on the planet Altamid after an accidental trip through a wormhole in 2164, where it was kept in reasonable order by one of the characters, conveniently waiting for Cap’n Kirk and his chums to come along and get it back in space again during the climax of the afore-mentioned film. The Franklin was pre-Federation, and the first ship capable of Warp Factor 4, with some fancy defensive and offensive capabilities for its time, which came in handy during the film. It also had a Star Trek: Enterprise vibe about it, which was set a decade or so earlier than its disappearance. Moebius kitted it in 1:350 in 2018, and it’s a nice model but maybe a little spartan for some modellers, so along comes this detail set from our capable friends at GreenStrawberry. The set arrives in one of GreenStrawberry’s familiar medium-sized boxes, and inside are resin parts in a Ziploc bag, two large frets of Photo-Etch (PE) brass, some clear acetate with the two outlines of the view-screen printed on it in black, plus a set of A4 instructions, with a sheet of black paper separating the two PE sheets, stopping them from chaffing during transport. The bridge floor is the first to be made, which involves laminating four layers of PE, then another two and finally creating a thick lamination from those sub-assemblies and two more layers, before the crew seats and the various consoles are glued to the new 3D stepped surface on their contact depressions using CA. The large resin “tub” forms the basis of the walls and ceiling, with a two-part lamination of perforated PE parts adding central detail before the floor is glued into position. The centre of the saucer section is drilled out to the correct size according to the instruction, and is filled with a new hatchway made from folded PE, which includes a ladder and floor section, following which the bridge is glued to the rear of the bridge window, with the clear acetate and a PE outer skin added in the front of the styrene aperture. Attention turns to the exterior of the ship now, with two small assemblies either side of the engraved USS Franklin on the front of the saucer, with 20 tiny circular PE parts topping off the paired upstands on the underside of the saucer. Back to the top again, 10 small trestle-like assemblies are folded up and glued to the surface, and the final parts are a pair of mesh panels with circular perforations for the impulse engines at the rear of the saucer. Conclusion This set will give your USS Franklin just the right amount of visual interest, and if you’re lighting the model, the centre section of the bridge ceiling is perforated to give the effect visible in the original. The engine grilles will also add some detail to the exterior lighting, as will all the delicate parts. Very highly recommended. Review sample courtesy of 1 1 Link to comment Share on other sites More sharing options...
