nick Posted October 5, 2021 Author Posted October 5, 2021 Just reprinted the inlet manifold in hi-res, so hopefully will get rid of all that nasty stepping. Mostly got the SUs drawn today too. Now they’re finished, I’ve managed to get them oversize somehow, so tweaking required. Don’t know what happened there. pictures later. Nick
nick Posted October 5, 2021 Author Posted October 5, 2021 I think I've spent too long looking at this now, I can't decide if the proportions are correct or not. Might be time for a break! Nick 9
nick Posted October 8, 2021 Author Posted October 8, 2021 Got around to taking some proper photos today As is always the case, spotted some bits that need tidying in the photos. Regards, Nick 13 2
nick Posted October 8, 2021 Author Posted October 8, 2021 4 hours ago, modelbautony said: stunning Nick. Thanks Tony.
albergman Posted October 8, 2021 Posted October 8, 2021 That's just breathtaking Nick! Hope there's a nice market for them. 1
Dancona Posted October 9, 2021 Posted October 9, 2021 Blimey, that's come out well, looking incredible Nick, you have done a remarkable job on this, all it needs now is a liberal coating of straight mineral oil ! I'm looking at the photos and trying to find something that doesn't look quite right, and I cant see anything off at all !!!!!!!!!!!!, the camshaft drive, cross shaft gear area is exquisite. Simply stunning Cheers David
nick Posted October 9, 2021 Author Posted October 9, 2021 7 minutes ago, Dancona said: I'm looking at the photos and trying to find something that doesn't look quite right, and I cant see anything off at all !!!!!!!!!!!!, Even the bloody cam cover? praise indeed, thanks David, that's the ultimate accolade if you can't find anything wrong. Regards Nick 1
nick Posted October 9, 2021 Author Posted October 9, 2021 I've almost completed the CAD work for the engine now. I have completely redrawn the supercharger and carbs and I'm a lot happier with everything now. A lot of printing to do tommorrow then! Thanks for looking, Nick 13 1
Pete in Lincs Posted October 10, 2021 Posted October 10, 2021 That looks pretty darned fabulous. I can almost smell the Castrol R.
Jo NZ Posted October 10, 2021 Posted October 10, 2021 It looks like a real engine - not blobs of plastic.
nick Posted October 10, 2021 Author Posted October 10, 2021 Is there a prize for the fullest build plate? Nick 8
Malc2 Posted October 10, 2021 Posted October 10, 2021 Dissappointed you haven't used the space in the middle of the clamp band!!🤣 Seriously, very interesting to see the print plate. (PS I think the carb dash pot tops look a bit too tall - The narrow neck for the damper housing) M. 1
nick Posted October 10, 2021 Author Posted October 10, 2021 18 minutes ago, Malc2 said: Dissappointed you haven't used the space in the middle of the clamp band!!🤣 Seriously, very interesting to see the print plate. (PS I think the carb dash pot tops look a bit too tall - The narrow neck for the damper housing) M. Turns out it was a bit much, I think I’m starving of resin, so need to be a bit less greedy. hear what you’re saying about the Dashpots, every photo I look at is slightly different, these are based on Birkin SUs I found. you pays yer money and takes yer chance. if you can find views of all 4 sides of a closer match you’re doing better than me! Nick 1
Malc2 Posted October 10, 2021 Posted October 10, 2021 Yes, good point, the carbs do seem to vary a lot, even between blowers, e.g. a lot of them have a different flange to the blower with only two fixings. I guess carbs are one of the things that are changed a lot during the life of any specific car due to wear and 'performance upgrades'. Malc.
nick Posted October 10, 2021 Author Posted October 10, 2021 Just bit the bullet and joined the Elegoo Jupiter kickstarter program while the big discount is still available. So big printer next spring, that should put the cat among the wosnames to paraphrase Mr Pratchett. Nick. 1
nick Posted October 11, 2021 Author Posted October 11, 2021 I know what you're going to say, black wire is on order! I was asked for a comparison shot with the airfix item so here it is Thanks for looking, Nick 19 1
armored76 Posted October 12, 2021 Posted October 12, 2021 I'm left without words! This is absolutely amazing!!!
Mpfiend Posted October 12, 2021 Posted October 12, 2021 That looks fantastic. Will you be producing an engine stand, so that modellers can display this by the car if they like? Best regards Keith.
nick Posted October 12, 2021 Author Posted October 12, 2021 35 minutes ago, Mpfiend said: That looks fantastic. Will you be producing an engine stand, so that modellers can display this by the car if they like? Best regards Keith. Possibly - if I knew what one looked like! yes I've seen the enormous dynamometer setup for the continuation series, but that's a bit much I think! Nick 2
albergman Posted October 12, 2021 Posted October 12, 2021 You keep raising the bar ever higher Nick. Just incredible detail. I'm usually left wondering how you did this or that in Fusion. Now that I don't use it any longer I'm starting to forget how things were done. Did the purchased version bring you any new tools or could you do most of this with the free one? Anyway, your skill level with Fusion is what is setting you apart from others with printers. Frank
heloman1 Posted October 12, 2021 Posted October 12, 2021 Hi Malc, I've just found your Bentley build, I'm normally found in the aircraft section. Your renders are exquisite but as an ex aircraft mech, your wire locking leaves a lot to be desired. The locking wire should transit from the one side of one nut to the opposite side of it's opposite number almost a figure of eight. I think you might have to draw and print a wire locking tool! (ha). There is lots of enthusiastic input from the crowd, which I think is helping you. As an ex industrial modelmaker, I'll follow your build with interest. Colin
