Mike Posted September 17, 2021 Share Posted September 17, 2021 Messerschmitt Bf.109G-6 (A02029B) 1:72 Airfix With almost 34,000 examples constructed over a 10-year period, the Messerschmitt Bf.109 is one of the most widely produced aircraft in history and it saw active service in every theatre in which German armed forces were engaged. Designed in the mid-1930s, the Bf.109 shared a similar configuration to the Spitfire, deploying monocoque construction and V12 engine, albeit an inverted V with fuel injection rather than a carburettor used in the Spit. Initially designed as a lightweight interceptor, like many German types during WWII, the Bf.109 evolved beyond its original brief into a bomber escort, fighter bomber, night fighter, ground-attack and reconnaissance platform. The Bf.109G series, colloquially known as the Gustav, was first produced in 1942. The airframe and wing were extensively modified to accommodate a more powerful engine, greater internal fuel capacity and additional armour. In contrast to early 109s, which were powered by engines delivering less than 700hp, some of the later Gustavs could output almost 2000hp with water injection and high-performance superchargers. The Gustav series accounted for a dizzying array of sub-variants, some of which featured a larger tail of wooden construction. Odd number suffixed aircraft had pressurised cockpits for high altitude operation, Erla Haube clear view canopy with clear rear head armour, underwing points for tanks, cannon or rockets and larger main wheels resulting in square fairings on the inner upper wings to accommodate them. The Kit Airfix's Bf.109G-6 dates back to 2009, and as such is one of the earlier kits released under Hornby's ownership. The kit bears all the hallmarks of that particular era, with a low part count and broad, deep panel lines. Those hoping that this would be a re-tooling of the aforementioned kit will be disappointed, as the plastic is exactly the same as that provided in the original release. The kit is part of Airfix's Skill Level 1 range, and it arrives in a top opening box with the kind of dramatic artwork that we have come to expect from Big Red. Inside the box are three sprues of grey plastic and a single, small clear sprue. There are just 41 parts in total, which is quite low when you consider that the more recent 'Emil' in the same scale is made up of 64 parts. Out of the box the kit is cleanly moulded and the plastic has a satin finish to it. The cockpit is extremely spartan, comprising of a simplified seat, pilot and nothing else. There is no instrument panel, no control column and no sidewall detail, which harks back to days gone by. This is in stark contrast to the Emil, as that kit was very nicely detailed, despite being part of the series 1 range. The instructions recommend that the propeller be joined to the fuselage at the same time that the fuselage halves are joined, but I would recommend leaving this step until the end as it will make painting more difficult otherwise. The bulges for the 13mm MG 131s on the upper fuselage in front of the cockpit are inaccurate as they are represented by a single large bulge rather than two separate bulges on each side of the fuselage with a depression between them. The wings follow the usual format for a model of this type, with a single span lower wing and separate port and starboard upper wings. Flaps and control surfaces are moulded in place, but some basic structural details have been moulded onto the roof of the main landing gear bays. The horizontals stabilisers are moulded as solid parts, as is the rudder. As with other recent Airfix kits, there are different parts provided for you to use if you wish to pose your model with landing gear up or down. The landing gear legs provided for the down option are moulded in place with the bay doors, which is a plus point for strength and ease of assembly, but a negative point in terms of detail and ease of painting. A drop tank and two under wing gun pods are provided, along with a choice of canopies, including the aforementioned Erla Haube canopy. Both are duplicated and moulded in one piece, but this is no great loss given the lack of internal detail. Markings There are the usual two options from the included decal sheet, both different enough to give you variety, and both having some fun schemes that will test your masking and airbrushing skills. Option A has a saw-tooth splinter pattern on the wing uppers, while option B has a an RLM75 sinewave squiggle on all its upper surfaces. Better get your airbrushing and/or masking skills honed for either option. From the box you can build one of the following: Bf.109g-6 Maj. Herman Graf, Jagdgeschwader 50, Wiesbaden/Erbenheim, Germany, Autumn 1943 Bf.109GF-6/R6 Lt. Manfred Dieterle, 3./Jagdgeschwader 300, Bonn-Hangelar Airfield, Germany, Mar-April 1944 Decals are by Cartograf, which is a guarantee of good registration, sharpness and colour density, with a thin gloss carrier film cut close to the printed areas. Conclusion This isn't the most detailed nor the most accurate Gustav on the market. It also lacks finesse in terms of the overall finish. All-in-all, there isn't much here to tempt the modeller with a primary focus on detail. Having said that, this is probably one of the cheapest Gustavs around, which is perhaps a hint to its intended market? Possibly the best thing about the kit is that it shows how far Airfix have come since this kit was initially tooled. Recommended. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
