VinBizz4786_ Posted October 24, 2021 Share Posted October 24, 2021 The 3d flak gun is wonderful! Like your job 1 Link to comment Share on other sites More sharing options...
Goji308 Posted October 27, 2021 Author Share Posted October 27, 2021 (edited) I have completed the flak30 machine gun on the wintergarten. I have added a small magnet so the assembly is removable while I continue to work in the conning tower. The completed 8.8 gun was a little tricky to mask as I airbrushed the base colors on it then eventually touched it up with a paintbrush. Here is the picture I used as inspiration for my deck gun. In hind sight I could have used a darker grey for more contrast Out of the many pictures of the deck gun I found this one unique with two merchant vessels painted on the side of the 8.8cm deck gun. I am not a huge fan of how the horseshoe life flotation device looks on the side of the conning tower. I know they are only on display while their at port. I wanted to add the mounts to the conning tower. Instead of trying to make the hook and pots with paper and CA, I decided to modify the stock flotation device and make my parts out of it. I used a .030 drill to make the pot look like a cup. Below in the picture you can see the hardware I am trying to make and represent Left of the vents. (The hook & pots) Chop chop I added the hook and pots to both sides Edited October 27, 2021 by Goji308 Added photo 8 Link to comment Share on other sites More sharing options...
Goji308 Posted October 29, 2021 Author Share Posted October 29, 2021 (edited) The wood deck is pretty flat so I attempted to add some wood rails around the main deck adding detail and texture. I imagine in most sea conditions at night firing that weapon could be pretty squirley. I believe that’s why they had raised rails to position your feet against for stability. I used .015” styrene sheet and a caliper to size a series of strips. I airbrushed the strips flat black and touched them up after I glued them in place. I scaled the pattern from the existing pattern of the the stock plastic supplied deck. I installed the wintergarten permanently to the aft deck of the conning tower. Edited October 29, 2021 by Goji308 Added a photo / wintergarten detail 11 Link to comment Share on other sites More sharing options...
VinBizz4786_ Posted October 31, 2021 Share Posted October 31, 2021 Love it!! 1 Link to comment Share on other sites More sharing options...
Goji308 Posted October 31, 2021 Author Share Posted October 31, 2021 (edited) Well it looks like this Uboat is just about complete. I finished most of the details. The wooden deck is now in place permanently. Deck rails have been installed. I did use the stock rails but in the future I will try to make my own using a smaller diameter rod. I am in the process of painting the isolators for the cables. The one decal (two tone shield ) for the U-82 insignia is now on the tower. After a light coat of matte varnish I will weather it tying into the existing weathering. I added a light wash to the main 8.8cm deck gun for a little detail and contrast. It was looking a little dry and light. A little more to come. Edited October 31, 2021 by Goji308 4 Link to comment Share on other sites More sharing options...
Goji308 Posted November 2, 2021 Author Share Posted November 2, 2021 (edited) Well I was on a roll the other evening and I pretty much finished the U-boat. I added the decal and weathered it just a tad. I added the cables, aerials, and aerial insulators. With a brush and a little paint I touched up a random rogue spot or two. I was going to add additional weathering to blend the deck with the hull but then decided not too. I think the weathering is close enough to the heavy weathering I had in mind for this build. Once you go to far I hear it’s tough to go back. Thank you for tagging along my adventure and commenting on the way. I learned a lot with this build (2nd) as I did with my last one, my first. There were several first time moments during this build that I was able to learn and grasp on the fly. A few new tools, oil paints, techniques with oils, masking a camouflage pattern, building a Photo Etch/ resin gun, and adding a real wooden deck to this model. Thanks again for the company. I will add more pictures in the “ ready for inspection” Area. Link below. Ready for inspection link: (more photos) Edited November 3, 2021 by Goji308 11 1 Link to comment Share on other sites More sharing options...
ArnoldAmbrose Posted November 2, 2021 Share Posted November 2, 2021 Gidday Goji. That Is Beautiful. And beautifully presented. I think the dark background enhances the model greatly. It makes the mounting poles much less evident and to me it appears that the U-boat is running very deep. Very well done. Regards, Jeff. 1 1 Link to comment Share on other sites More sharing options...
VinBizz4786_ Posted November 2, 2021 Share Posted November 2, 2021 (edited) MAN! This is just OUTSTANDING ! Wonderful! Your model deserved to be in a museum Edited November 2, 2021 by VinBizz4786_ 1 Link to comment Share on other sites More sharing options...
Dmitriy1967 Posted November 2, 2021 Share Posted November 2, 2021 Great job! Very realistic. Weathering that you believe. 1 Link to comment Share on other sites More sharing options...
Goji308 Posted November 3, 2021 Author Share Posted November 3, 2021 Thank you guys for the kind compliments. I appreciate them. Brian Link to comment Share on other sites More sharing options...
adolfocaetanonetto Posted November 5, 2021 Share Posted November 5, 2021 Hei, Goji, I need a help´, please! I read that the deck of new submarines was painted with black or dark gray protective varnish. During missions, the deck was wearing and getting more clear, and brown, when the wood appea. Is what you made in your model? I want painting my sub like your, (if I can - I dont trust in my hands and eyes when is the painting phase)! 1 Link to comment Share on other sites More sharing options...
Goji308 Posted January 6 Author Share Posted January 6 (edited) On 11/5/2021 at 8:37 AM, adolfocaetanonetto said: Hei, Goji, I need a help´, please! I read that the deck of new submarines was painted with black or dark gray protective varnish. During missions, the deck was wearing and getting more clear, and brown, when the wood appea. Is what you made in your model? I want painting my sub like your, (if I can - I dont trust in my hands and eyes when is the painting phase)! Sorry for the late reply and I hope this helps. I just saw your post. First I applied a sealer to the wood with a disposable brush and let it dry for a day. I airbrushed the deck a dull primer black. I basically masked off little features like hatches, etc and light sanded partially through the black primer. I tried to imagine where foot traffic might be and sanded there. I then added grime around the gun, a touch of salt here and there, and a little rust around the tower feature, railings, etc. Basically trying to tie it all together hoping the effort would add to my story. Edited January 6 by Goji308 Link to comment Share on other sites More sharing options...
