Buccaneer S.2B Upgrade Set & Masks (for Airfix) 1:72 Eduard
1:72 Eduard
The new Airfix kit is one of the crop of new tool kits which are excellent direct from the box, this has not stopped Eduard from offering some upgrades.
Upgrade Set (73742)
Here we get a sheet of brass for the airframe parts, and a small sheet of nickel-plated and pre-painted PE for the cockpit and ejection seats.
Firstly from the nickel fret you get new head boxes for the seats, firing handles, and complete seat harnesses. In the cockpit you get new multipart instrument panels and all the side consoles. New rudder pedals are provided. For the airframe you get the interior of the large prominent rear air brake, burner can details for the engines, and heat shields for the exhausts. Internal skins for the landing gear well are provided, as well as new skins for the gear door.
Masks (CX601)
Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with a full set of masks for the canopy both inside and out, with compound curved handled by using frame hugging masks, while the highly curved gaps are in-filled with either liquid mask or offcuts from the background tape.  In addition, you get a set of hub/tyre masks for the wheels, allowing you to cut the demarcation perfectly with little effort.
Review samples courtesy of
