AaCee26 Posted September 19, 2021 Share Posted September 19, 2021 On 9/15/2021 at 11:21 AM, Richard Tucker said: I did but I don't think I'd be able to do a good enough job of the painting. I'd need to mask it and I think it would pull off the decals Hi Richard, I have done new decals in similar cases (wrong colour, side or lack of availability) just scanning the originals and printing it in black. Cheers, AaCee 1 Link to comment Share on other sites More sharing options...
Richard Tucker Posted September 20, 2021 Author Share Posted September 20, 2021 On 9/18/2021 at 11:40 PM, trickyrich said: you could almost turn them into masks with a scalpel I hadn't thought of this - its a good idea. Link to comment Share on other sites More sharing options...
arfa1983 Posted September 20, 2021 Share Posted September 20, 2021 Photocopy onto glossy paper then stick tamiya over the top and cut with sharp blade. The tamiya tape will peel straight off the glossy paper creating a perfect mask. 3 Link to comment Share on other sites More sharing options...
Richard Tucker Posted September 28, 2021 Author Share Posted September 28, 2021 Some progress now as I have finished off the Potez 630 in the French Fancy GB. I've glued most of the main parts together and it will need some sanding and filling in a few gaps. I've done some filling and sanding but will spray the primer to see what it left to fill. 6 Link to comment Share on other sites More sharing options...
Col. Posted September 28, 2021 Share Posted September 28, 2021 Certainly looks to be taking shape nicely 1 Link to comment Share on other sites More sharing options...
trickyrich Posted October 1, 2021 Share Posted October 1, 2021 I agree, very nice! 1 Link to comment Share on other sites More sharing options...
Richard Tucker Posted October 5, 2021 Author Share Posted October 5, 2021 Some progress since the last update. I've sprayed the camo. The canopy has come up well. The only mistake is I snapped off the intake above the cowling so that needs gluing on. Next stop, some gloss and then the selection of decals / painting / masking that I need to do for GS-G. 7 Link to comment Share on other sites More sharing options...
Richard Tucker Posted October 8, 2021 Author Share Posted October 8, 2021 I glued the intake on and then jumped in with both feet on the decals / GS-G. I took the advice above and used a strip of wide tamiya masking tape to stick over the letters while they were still on the decals sheet. I draw around them and then peeled off the tape and stuck it on some card. I used a sharp scalpel to cut around the inside creating a quite flimsy but surprisingly resilient mask. I stuck it on the fuselage, sprayed the black and then peeled it off. I repeated with the other side and then masked off the "S" leaving just the G. I stuck the roundels on from another set of decals I have as they have the darker red colour. Once they had gone off a bit, I sprayed the G on using the same GS mask. It is not brilliant but it is pretty good. There was some overspray which I have fixed. Some areas of the letters didn't quite get enough black either so I've touched them up a bit. I did a little panel lining with a dark thin pen and wiped off the excess. 14 Link to comment Share on other sites More sharing options...
trickyrich Posted October 12, 2021 Share Posted October 12, 2021 I'd say that looks really good, well done!!! Considering what you had to do to get those marking correct aI think you've done a fantastic job, they look great! 1 Link to comment Share on other sites More sharing options...
Richard Tucker Posted October 20, 2021 Author Share Posted October 20, 2021 I'm calling this one done. Not too much weathering. All the little bits are stuck on. Thank you for all the advice on the thread. It is really appreciated. A special shout out to @Vingtor and @dogsbody for the help and photos. 12 Link to comment Share on other sites More sharing options...
Vingtor Posted October 20, 2021 Share Posted October 20, 2021 Job well done. Not the easiest among kits to build. And a very good-looking aircraft. Nils 1 Link to comment Share on other sites More sharing options...
Hewy Posted October 20, 2021 Share Posted October 20, 2021 Very nice job Richard, i like float planes 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted October 20, 2021 Share Posted October 20, 2021 Well done … Seeing this one built makes me want to build one even more. 1 Link to comment Share on other sites More sharing options...
desert falcon Posted October 20, 2021 Share Posted October 20, 2021 Very nice👍 1 Link to comment Share on other sites More sharing options...
trickyrich Posted October 25, 2021 Share Posted October 25, 2021 Well done on completing her, she looks great! It's nice to see something quite different in the build, and for most of use we wouldn't have known about this aircraft, so am glad you brought it along. I hope you enjoyed the build, it was great to have you along. 1 Link to comment Share on other sites More sharing options...
Paul J Posted October 25, 2021 Share Posted October 25, 2021 How about scanning the decals and getting the lettering printed in the right colour? Link to comment Share on other sites More sharing options...
Richard Tucker Posted October 25, 2021 Author Share Posted October 25, 2021 3 hours ago, trickyrich said: I hope you enjoyed the build, it was great to have you along I did thank you. I'll be right back with another new build for the GB in 10 minutes 3 hours ago, Paul J said: How about scanning the decals and getting the lettering printed in the right colour? I could have scanned them but I've never printed any decals. Can I do that with an Ink Jet printer? Link to comment Share on other sites More sharing options...
JOCKNEY Posted November 15, 2021 Share Posted November 15, 2021 Looks the business, congratulations Cheers Pat 1 Link to comment Share on other sites More sharing options...
