Mike Posted August 28, 2021 Share Posted August 28, 2021 T-55/T-55A Transmission Set (37073) 1:35 MiniArt via Creative Models Ltd MiniArt’s new interior kits of the T-55/A are highly detailed masterpieces of injection moulding, but for the inveterate detail hound, anything and everything can be improved upon. This new set includes the full transmission system, which is absent from the base kit because it is hidden away behind the radiators that sit above it. The list of kits that are compatible at time of writing is as follows: 37016 T-55A Early Production Mod.1965 Interior Kit 37018 T-55 Mod.1963 Interior Kit 37020 T-55A Mod.1981 Interior Kit 37022 T-55A Late Production Mod.1965 Interior Kit The set arrives in a small top-opening box, and inside are six sprues of grey styrene plus the instruction booklet, which is a proper booklet because the instructions are quite involved, having some changes to the base kit’s parts, as well as interleaving the new parts with the build. Needless to say, the detail is excellent and once you have got your head round the method used to explain how things fit together between the two kits, just take your time and everything should go well. The elements that are included in this box are the cooling system exhaust fan and its associated ducting, a reservoir to the right of the assembly, and an alteration to the framework that supports the kit’s engine. The casing for the transmission is based upon two halves, which are large castings on the real thing, to which a gaggle of inspection covers, power take-offs and what looks like a small compressor are added, then the two cylindrical brake housings are built and attached to their locations in each end of the transmission housing. Anti-torque suspension rods for the brakes and hosing are also added around the assemblies, then attention turns to the radiator, which is built up as a box with the concave core visible from the top, then lifting lugs, hosing couplers and pivot points are added for installation in the hull later. The base kit’s engine is altered slightly by using some different hoses that join to the airbox that is also from the kit, then the interior walls of this part of the engine bay are detailed with inserts so that the cooling fan can be installed along with the supports for the transmission. More parts are substituted in the rear of the engine deck, then the transmission is inserted along with a lot of other ancillaries and hosing that are in that area. An oil cooler or intercooler airbox is laid over the transmission on the port side, then the kit engine is dropped in with whatever steps are required by the kit instructions. The section of the engine deck over the space between the engine and transmission is replaced by a new assembly, which allows the main radiator housing to be posed down or lifted into maintenance position with bespoke hose parts to fit either, but if you’ve bought this set you’re probably going to leave it up. Finally, there is another short section of engine deck with individual louvers that can be posed up or down. There are no decals in the kit, but the rear page of the booklet is filled with two views of what’s included and it also has a colour chart at the bottom in Vallejo, Mr Color, AK RealColor, Mission Models, AMMO, and Tamiya, as well as the colour names and small swatches to help you out. Highly recommended. Review sample courtesy of 1 Link to comment Share on other sites More sharing options...
