Julien Posted August 26, 2021 Share Posted August 26, 2021 Meteor T.Mk7 (FR0045) 1:72 Azur FRROM The Gloster Meteor was the first British jet fighter and the Allies' first operational jet aircraft during the Second World War. The Meteor's development was heavily reliant on its ground-breaking turbojet engines, pioneered by Sir Frank Whittle and his company, Power Jets Ltd. Development of the aircraft itself began in 1940, although work on the engines had been underway since 1936. The Meteor first flew in 1943 and commenced operations on 27 July 1944 with No. 616 Squadron RAF. Nicknamed the "Meatbox", the Meteor was not a sophisticated aircraft in terms of its aerodynamics, but proved to be a successful combat fighter. Several major variants of the Meteor incorporated technological advances during the 1940s and 1950s. Thousands of Meteors were built to fly with the RAF and other air forces and remained in use for several decades. The Meteor saw limited action in the Second World War. Meteors of the Royal Australian Air Force (RAAF) provided a significant contribution in the Korean War. Several other operators such as Argentina, Egypt and Israel flew Meteors in later regional conflicts. Specialised variants of the Meteor were developed for use in photo-reconnaissance and as night fighters. The T.7 twin seat trainer was developed from the Mark 4. 640were produced for the Royal Air Force, 43 for the Royal Navy; and 72 for export. 20 Belgian F.4s were modified locally into T.7s. Many nations would operate the T.7 with a pair of T.7s being the first jet aircraft to land in Israel. These were locally converted to carry belly mounted camera. The Kit This is a re-release by Azur Frrom of the MPM kit. This now includes masks (not shown) for the heavily framed canopy. The masks look to be the same as the new tape masks from Special Hobby. Construction first begins in the cockpit which builds up to a complete module that slots into the fuselage when built up. The centre bulkhead is added to the floor and then side consoles are added. The centre instrument console is then built up and installed along with both seats. The rear bulkhead goes on, and both control columns. To the underside of this module the nose gear well is then added. This assembly can then go into the right fuselage. The pilots instrument panel then goes in as do the remainder of the side consoles. The fuselage can then be closed up with the nose gear now being fitted. Construction now moves onto the wings. Firstly the engines and jet pipes need to be assembled. There is a basic representative of the Derwent which you will see the front face of through the intake. Behind this there is the jet pipe, and exhaust. These go into the one part lower wing. In front of the engines goes the fairing over the front wing spar which is seen through the intake. Single part intake inners are then fitted. Moving on the the upper wing the main gear wells need to go in. The two wing sections can then be joined. The intake leading edges, and exhaust trailing edges are then fitted. The fuselage can now be joined to the wings. At the rear the tail planes then go on. The main gear units are then assembled and added along with their retraction struts and the main gear doors. Like the real units these are complicated and care need to get them right. Take note to assemble the wheels correctly and not as per the instructions. The wheels are not handed like most aircraft. Luckily here the wheels are separate from the mud guards so they can be put in the correct way around. The modeller will need to make their own stay from the rear of the mudguard. To finish off the wing and belly tanks are fitted followed by the canopy, aerial and pitot tube. Markings The glossy decal sheet is printed in house and looks sharp and in register. There are markings for four aircraft Nr 9, coded 30-MY, Escadrille 2/30 "Camargue", Tours 1956 ED-42, Ecale de Chasse de Coxyde, Belgium, 1958 Black 15 with Suez / Operation Kadesh stripes, Israel 1957 Conclusion It is good to see the T7 back out there. Highly recommended. Review sample courtesy of 2 Link to comment Share on other sites More sharing options...
