Any difference between Kinetic Alpha Jet regular and Patrouille de France?
David2703
Hi all,
question is pretty much in the title. If one has no intention of building an A variant, is there any difference beyond the decals between those two boxings beyond getting two kits in the Patrouille de France boxing? Any missing antennae or pylons? I assume that weapons would be missing. Anything beyond that?
Many thanks,
David
Edited by David2703
  • David2703 changed the title to Any difference between Kinetic Alpha Jet regular and Patrouille de France?
13 hours ago, exdraken said:
Decals
Probably different PE, not sure.
https://www.scalemates.com/kits/kinetic-k48043-alpha-jet-a-e--207874
The plastic parts seem to be the same.
There is also a Luftwaffe boxing. Same plastic again.
What do you want to build?
 Thanks. I want to build a few African export ones, i.e. Morocco or Ivory Coast. So I will need a few and am now just thinking what the cheapest option would be given that I do not need kit decals.
OK, those are all "French" E models with the blunt nose. I do not know about ejection seats, but I guess they'd also be the same ones...
Both/ all Kinetic boxing should do then! (Wingman Models did some expensive and hard to find special boxing, but more related to the pointy nose A versions...)
