7.5cm PZGR. & GR. PATR. KW.K 40 Shells w/Ammo Boxes (35381) 1:35
Mike
1:35 MiniArt via Creative Models Ltd
Arriving in a shrink-wrapped figure box, this set contains eight sprues in grey styrene, allowing the modeller to make up twelve of each type of shell, with six used cartridges that have slide-moulded hollow openings, and six ammo crates that are capable of holding three shells of one type.  Also included are decals for each type of shell, and stencils for the ammo boxes themselves, just to finish them off.  The shells are all a single part each, but the boxes are made up from five or six sides (depending if opened) with supports for the rounds moulded into the bottom, and additional handles on each end.  The end walls also have depressions moulded-in to prevent the shells from rattling round, and the optional lids also have more supports moulded-in, but it would be a waste to hide three shells inside a closed box, so don’t.  Detail is excellent as you’d expect, and the shells will just need a little preparation to remove the two sprue gates and the unavoidable moulding seam before painting.
The instructions are on the rear of the box, and show the correct location of the shell stencils for both types, plus a colour chart showing Vallejo, Mr Color, AK RealColor, Mission, AMMO, Tamiya plus swatches and colour names that should provide more than enough information to make informed paint choices.
Highly recommended.
Review sample courtesy of
