Dassault Super Mystére B2...AZ Model...
18 hours ago, John Masters said:
Thank you @VG 33...the decals arrived.  Now I can continue on with this!  Tell me Patrick...where does the Mastiff go?  Opposite the Scorpion?
--John
Good morning John
 Yes the Mastiff goes on the left side and the Scorpion on the right
This should help you
https://www.scalemates.com/products/img/5/1/7/1129517-85-instructions.pdf
Best Regards
Patrice
Finally back at this!  This feels really good.  I chose Vallejo Air Silver for the first stage of the NMF.  I'll give the exhaust some Burnt Iron, some of the panels will get Duraluminum.  I'll Levi the anti-glare panel on the nose matte black unless someone tells me differently.
Btw...I began to move house a few days ago.  I will take a long time to keep it mostly painless.  I owed up and moved all the built models this morning.  Below is an example...a Box of Migs...
Process..layer of aircraft on a bubblewrap base.  Then the peanuts.  Then the lid.  I dis this repeatedly. Most bins have two layers.  I think I need to build more Migs.
And I ended up with these...
Not bad.  The hard part will be unpacking them carefully, re-shelving, etc.
--John
  • Like 9
When I moved house a couple of months ago, that is how I moved my models.  I used the bubble wrap and packing noodles and also shredded paper.  Only breakage was a radar aerial off the nose of a Me-110G nightfighter.  One thing I did that I regret was in some boxes I used the bits of foam used as cushion filling, this was a mistake as it left a layer of fine particles on the models.
AW
That will be part of the difficulty with unpacking: using a fine soft brush to dust the models before the go back on the shelf.  It'll take some time.
8 hours ago, Vultures1 said:
Good luck with the move John.
Thanks!  Slowly, slowly...
On 9/20/2021 at 11:03 PM, VG 33 said:
I understand it was right on time to send you the decals before moving home.
Perfect!  Thank you1
I am applying the decals on this tonight.  I must wrap this up.  I have other builds wish to begin!
The anti-glare area...
--John
Thanks to @VG 33 again.
I applied the decals tonight.  I also attached the undercarriage, painted the wingtips green and the top of the fin a light blue.  The kit decals were ok...just ok.  Opaque enough, but oh, sooo fragile.  Those long arrows on the side split quite a few times.  The trick was to let them soak for a long time, then run a very soft brush beneath the decal to release it from the paper.  Slide it on with a lot of water.
Tomorrow I'll carefully give it some varnish, then a bit of pinwash here and there for panel detail.
--John
  • Like 9
