Eduard Bf 109E-3 1/48
1/48 Bf 109-E3
Subject Stab III / JG I
France, June 1941
Pilot Grupen Adjudant Maj. Reinhard Heydrich (yes, that SOB)
Balkankruz and chevron done by airbrush with Microdesign Photoetch stencil from
https://www.ebay.ie/str/miracleworldofhobby
This was a new departure for me in airbrushing markings as opposed to using decals, It does require some practice.
Next time I think I will lay down white, spray in the black and then mask off the markings.
I think in my case, the jury is still out on airbrush vs decals, but with a bit of practice it worked out OK and was not overly hard.
Kit Eduard Weekend addition 84157
After market decals (Techmod) via trinitymews
https://www.ebay.co.uk/str/accurahobbykits.
Techmod Decals 48013E
With regards the subject, I got a bit of flack on facebook.
One person went so far as to say that Heydrich was not part of the 'clean' Luftwaffe
I built the model out of historical interest, and perhaps a morbid sense of historical content - he was a reserve Major in the Luftwaffe - flew in the Poland campaign as a turret gunner - flew then in Norway campaign, then in France and against the RAF in a Bf 109.
Flew finally in combat in the USSR.
I first became aware of it after reading 'Hitler's Hangman: The Life of Heydrich' by Robert Gerwarth. Peer reviewed from University press if memory serves me correctly
Incidentally he would fly to his families holiday home and arrived at the Wansee conference in a plane he piloted himself in 1942.
I did not post it to engage in a historical debate, I did out of an interest in the hobby and a matter of historical fact.
If the model was a WHIFF I would have stated so.
And if you use Deluxe Plastic magic cement be careful with oil washes, hit the gloss coat with turpentine before doing a pin wash, and had to re-glue a lot of parts - at least that was my experience.
Edited by simonj
Tags, photos
  • Like 18
Primer AK 178 Black
For the base I used mostly Heilblau RLM 78 from Mig Ammo - Grey was IJN Grey from Tamiya 75 with a drop of Tamiya XF 2 flat white (about 10:1)
I would go lighter if I could do it
Greens were Mig Ammo RLM 81 and RLM 82 Cammo Green, again, next time I will look at something of a lighter shade - Still getting used to model shade
Prop Vallejo Black Green 71.018
Cockpit was Tamiya XF-65 field grey used as a sub for RLM 02 - also used in the wheel wells
Blacks XF-85 tyre black
Gloss Coat - first sealing Pledge 'Revive it' Floor Gloss
Satin coat /Sealing coat Galeria Satin Varnish (Acrylic)
Edited by simonj
Varnishes
Nice job but the pics are a bit dark. Please consider the Silhouette solution as you'll be able to do your own masks, and what a difference does it make for the weathering process! Best regards.
Nice job on that.  I've never tried them, but I can't imagine that PE stencils are particularly user-friendly.  Have you considered using self-adhesive masks from Montex, or similar?  Also, what made you choose late war greens like 81 and 82 for an Emil - or was this particular to Heydrich's a/c..?
Just the paints I had at hand, COVID has limited the budget fairly severely
I found the PE stencils to be fairly easy to use.
When I get back on my feet however, a vinyl printer is certainly on the cards
Edited by simonj
printer
Oh, man. In Brazil the Covid is destroying lifes. Bolsonaro Government is a catastrophe! 😪
Return to model, amazing. I building a 109 E-4, that I paint like Adolf Galland aircraft in the Battle of Britain. My son is a fan of Galland!
