Roger Newsome Posted August 13, 2021 Share Posted August 13, 2021 It's been awhile since I did an away at work wip due to various problems with the ships Internet but it looks that’s all sorted now so here goes! This is the version I'm going to build.... 12 Link to comment Share on other sites More sharing options...
Roger Newsome Posted August 14, 2021 Author Share Posted August 14, 2021 Cockpit painted and assembled yesterday evening and this afternoon. 5 Link to comment Share on other sites More sharing options...
Roger Newsome Posted August 14, 2021 Author Share Posted August 14, 2021 I'd better explain what appears to be a random spraying of black. Because the light isn't that great in here I sprayed the cockpit walls black before spraying them grey so I could see what was doing. 1 Link to comment Share on other sites More sharing options...
Roger Newsome Posted August 15, 2021 Author Share Posted August 15, 2021 Everything is going together nicely so far.... 4 Link to comment Share on other sites More sharing options...
drake122 Posted August 15, 2021 Share Posted August 15, 2021 (edited) Intakes are a proper nightmare to fit. It is easier if you cut apart the inner intake structure part (I also put nose weight in that area instead of the nose). And also airbrake fit on upper side is horrendous, had to put plasticard in there, even the resin replacement is small for size. And you can't really keep the airbrakes open to hide this problem because airbrakes on the Ja-37 were welded shut as pilots rarely if ever used them. Edited August 15, 2021 by drake122 3 Link to comment Share on other sites More sharing options...
Roger Newsome Posted August 15, 2021 Author Share Posted August 15, 2021 12 minutes ago, drake122 said: Intakes are a proper nightmare to fit. It is easier if you cut apart the inner intake structure part (I also put nose weight in that area instead of the nose). And also airbrake fit on upper side is horrendous, had to put plasticard in there, even the resin replacement is small for size. And you can't really keep the airbrakes open to hide this problem because airbrakes on the Ja-37 were welded shut as pilots rarely if ever used them. I thought it was going too well, thanks for the heads up. I'll try and do what I can in those problem areas. Link to comment Share on other sites More sharing options...
Roger Newsome Posted August 15, 2021 Author Share Posted August 15, 2021 Forwarned by @drake122 about the problem fitting the intakes I decided to skip ahead and take the bull by the horns. The problem, that will not fit where it is supposed to.... Problem solved with the aid of a sanding stick... Superglued into position, a tiny bit of filler and a sand. It still needs a bit more tidying up but I think that problem is solved, now the airbrakes. 5 Link to comment Share on other sites More sharing options...
Christer A Posted August 18, 2021 Share Posted August 18, 2021 Ooooh, the mighty JaktViggen! I've yet to build one strangely enough, but who cannot like it? Your're off to a good start Roger. Link to comment Share on other sites More sharing options...
Roger Newsome Posted August 18, 2021 Author Share Posted August 18, 2021 13 hours ago, Christer A said: Ooooh, the mighty JaktViggen! I've yet to build one strangely enough, but who cannot like it? Your're off to a good start Roger. Thanks Christer. You've never built a Viggen? Nooooo. This is how it's looking at the moment. 8 Link to comment Share on other sites More sharing options...
Electric Indigo Posted August 18, 2021 Share Posted August 18, 2021 On 15/08/2021 at 16:27, drake122 said: And also airbrake fit on upper side is horrendous I built the 1/48 Viggen, and it had the same problem. I put a generous dab of polyester putty on the region, sanded it flush with the fuselage and then re-engraved the contour. 1 Link to comment Share on other sites More sharing options...
Bjorn Posted August 19, 2021 Share Posted August 19, 2021 The upper air brake problem is present on almost every Viggen kit. Making them as separate parts is a stupid idea, since they were never extended on a parked aircraft. Thus, separate parts only causes problem, since fit seldom is good. The only kit where they are as they shoud be - just panel lines - is Matchbox. But on their kit, they have the wrong shape instead... 1 2 Link to comment Share on other sites More sharing options...
LOX Posted August 19, 2021 Share Posted August 19, 2021 Nice build so far, good work ! 1 Link to comment Share on other sites More sharing options...
exdraken Posted August 19, 2021 Share Posted August 19, 2021 Great work!! 1 Link to comment Share on other sites More sharing options...
Roger Newsome Posted August 19, 2021 Author Share Posted August 19, 2021 @LOX @exdraken Thank you both very much. Getting some paint down now. The underside has had a coat of Mr Color C11. Prior to this the whole model received a base coat of Mr Color C137, Tire Black. No particular reason for it being Tire Black it's just that it was the darkest colour I have the most of with me. 7 Link to comment Share on other sites More sharing options...
najkos Posted August 20, 2021 Share Posted August 20, 2021 Nice work so far, looks good! Just remember NOT to put any anti-collision light on the belly, it was only present on the AJ-family of Viggens. Don't remember what the instructions tell you to do.. 1 Link to comment Share on other sites More sharing options...
Roger Newsome Posted August 22, 2021 Author Share Posted August 22, 2021 On 8/20/2021 at 10:15 AM, najkos said: Nice work so far, looks good! Just remember NOT to put any anti-collision light on the belly, it was only present on the AJ-family of Viggens. Don't remember what the instructions tell you to do.. Thanks very much. I'll check that anti collision light out, I can't remember if there's one or not. I usually leave that kind of thing to near the end. Update time, upper surfaces painted, I've tried to get a bit of subtle variation on some of the panels which may or may not show up on the photos. 3 Link to comment Share on other sites More sharing options...
Roger Newsome Posted August 24, 2021 Author Share Posted August 24, 2021 A bit further.... 10 Link to comment Share on other sites More sharing options...
billn53 Posted August 26, 2021 Share Posted August 26, 2021 Looking good, Roger! 1 Link to comment Share on other sites More sharing options...
adolfocaetanonetto Posted August 26, 2021 Share Posted August 26, 2021 This machine is fantastic. Simply BEAUTIFUL! 1 Link to comment Share on other sites More sharing options...
Roger Newsome Posted August 26, 2021 Author Share Posted August 26, 2021 4 hours ago, billn53 said: Looking good, Roger! 2 hours ago, adolfocaetanonetto said: This machine is fantastic. Simply BEAUTIFUL! Thank you both very much. Another update will hopefully follow later today. Link to comment Share on other sites More sharing options...
Bobby No Mac Posted August 26, 2021 Share Posted August 26, 2021 It's looking marvellous. I've not been brave enough to tackle my Special Hobby Viggens yet but will heed the advice shared in this thread when I do. Thanks 1 Link to comment Share on other sites More sharing options...
Roger Newsome Posted August 26, 2021 Author Share Posted August 26, 2021 2 hours ago, Bobby No Mac said: It's looking marvellous. I've not been brave enough to tackle my Special Hobby Viggens yet but will heed the advice shared in this thread when I do. Thanks Thank you. Apart from the intakes it's been pretty much plain sailing. I'm sure you'll enjoy yours when you get round to them. 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted August 26, 2021 Share Posted August 26, 2021 Wow Roger, fantastic progress on this one and I did like the way you solved the intake fit issue! I need to follow this one closely as I have a double bosing of this from SH (came also with a superb book on the Viggen). Terry 1 Link to comment Share on other sites More sharing options...
Roger Newsome Posted August 26, 2021 Author Share Posted August 26, 2021 31 minutes ago, Terry1954 said: Wow Roger, fantastic progress on this one and I did like the way you solved the intake fit issue! I need to follow this one closely as I have a double bosing of this from SH (came also with a superb book on the Viggen). Terry Thank you Terry. I think the intake solution was more luck than judgment but it worked. This is where I am now. You can probably see some PVA on the bottom edge of the canopy. I did two dry test fittings prior to committing to superglue and they were both a perfect fit. You can guess the rest. 5 Link to comment Share on other sites More sharing options...
drake122 Posted August 26, 2021 Share Posted August 26, 2021 That turned out lovely, makes me want to start another SH viggen... if only there was enough time 1 Link to comment Share on other sites More sharing options...
