Tempest Mk.II Upgrade Sets & Masks (for Eduard/Special Hobby) 1:48
1:48 Eduard & Eduard Brassin
We’re so lucky to get so many brand new Tempest kits in 1:32 and now 1:48, with this latest Tempest Mk.II ProfiPACK a superb exercise in the current state of the art of styrene injection moulding.  Eduard's new range of sets are here to improve on the kit detail even further in the usual modular manner.  Get what you want for the areas you want to be more of a focal point.  As usual with Eduard's Photo-Etch (PE), small Brassin sets and Mask sets, they arrive in a flat resealable package, with a white backing card protecting the contents and the instructions that are sandwiched between.
SPACE (3DL48030)
The Eduard SPACE sets use new 3D printing techniques that lay down successive layers of different colour resin, creating highly realistic almost full complete panels that are supplied on a decal sheet.  They can depict metallic shades, plus glossy, satin and matt colours too, which really ups the detail on everything they print.  In addition, a small sheet of nickel-plated and pre-painted PE is included for the aspects of the set that lend themselves better to this medium, such as seatbelts and rudder pedals.
This set includes rudder pedals with adjustment wheels; a new set of four-point seatbelts for the pilot; levers for the instrument panels, while the 3D decals cover the instruments on the main panels; the side consoles; compass and adjustment wheel on the throttle quadrant.
Exhaust Stacks(648654)
This set contains just two parts on a single casting block, which replace the kit parts as drop-in replacements, offering a squared-off hollow lip to each of the eight exhaust stubs, and including detail around the stacks, and the curious angling outwards of the top pipe on each side.
Seatbelts STEEL (FE1208)
These belts are Photo-Etch (PE) steel, and because of their strength they can be etched from thinner material, which improves realism and flexibility in one sitting.  Coupled with the new painting method that adds perceived extra depth to the buckles and other furniture by shading, they are more realistic looking and will drape better than regular brass PE.  It includes a set of crew belts that consist of a pair of lap belts and the shoulder belts with the section that passes down the rear of the seat to its anchor point on the bulkhead.
Masks Tface (EX796)
Supplied on a sheet of yellow kabuki tape, these pre-cut masks supply you with everything needed to mask the exterior of the canopy, but also give you another set of masks tailored to fit the interior of the glazing so that you can paint the interior and give your model that extra bit of realism.  The highly curved gaps are in-filled with either liquid mask or offcuts from the background tape.  In addition you get a set of masks for the tiny tail-wheel hubs, allowing you to cut the demarcation perfectly with little effort.
Review sample courtesy of
