S-boat 55 Posted August 9, 2021 Share Posted August 9, 2021 Evening all, I'm nearing the end of my current build - 1/350 Dunkerque, its my second battleship I am row and I fancy doing a carrier, I've a dozen other things in the stash but have my sights set on a flat top. Now rumour has it that they are a lot more work than they look, so question is any recommendations on first one to try? I'm eyeing up; Very fires Taiho which is due pretty soon but far from cheap (that said which of them really are!) Trumpys Hornet which is the cheapest option although not by much Merits Ark Royal is another option Or Trumpys Yorktown cv10, Not sure if it really makes a difference which I go for but thought I'd seek the collectives input incase one is known as a difficult build Thanks Sam Link to comment Share on other sites More sharing options...
Richard E Posted August 9, 2021 Share Posted August 9, 2021 1 hour ago, S-boat 55 said: Merits Ark Royal is another option Have you seen Crisp's @Ex-FAAWAFU excellent WIP ? 1 Link to comment Share on other sites More sharing options...
S-boat 55 Posted August 9, 2021 Author Share Posted August 9, 2021 14 minutes ago, Richard E said: Have you seen Crisp's @Ex-FAAWAFU excellent WIP ? I have, it's mind bogglingly good, I guess with all builds it comes down to how much you want to put into it, I'm just conscious to not bite off more than I can chew, 1 Link to comment Share on other sites More sharing options...
Jamie @ Sovereign Hobbies Posted August 10, 2021 Share Posted August 10, 2021 I hope this isn't excessively rivet-counteresque, but I'll just post this here to help you appraise the Trumpeter Hornet (red) against a generally more accurate Yorktown class hull form. This is sister ship USS Yorktown sinking. You're looking at the bow and she has capsized to port with her starboard bilge keel in the air (torpedo damage apparent). So that's the start of it, and Trumpeter's kit gets worse the more you look. 1 1 1 Link to comment Share on other sites More sharing options...
S-boat 55 Posted August 10, 2021 Author Share Posted August 10, 2021 (edited) Hmmm not sure I want to be faffing trying to correct a hull on a first carrier build I'd they're as complicated as people say, thanks for the heads up, Edited August 10, 2021 by S-boat 55 1 Link to comment Share on other sites More sharing options...
Chewbacca Posted September 11, 2021 Share Posted September 11, 2021 Simple solution to the hull - go for a waterline model 😀. That said the profile doesn't even look right above the waterline and from what I've heard, as Jamie suggests,, the hull is only the start of the problem with that kit. Link to comment Share on other sites More sharing options...
S-boat 55 Posted September 11, 2021 Author Share Posted September 11, 2021 3 hours ago, Chewbacca said: Simple solution to the hull - go for a waterline model 😀. That said the profile doesn't even look right above the waterline and from what I've heard, as Jamie suggests,, the hull is only the start of the problem with that kit. It does appear as the cheapest option for a fleet carrier and I suspect the issues are the reason for that, I went for Graf Zeppelin in the end, still eyeing a couple others though, especially the yorktown cv-10, Link to comment Share on other sites More sharing options...
