Gondor44 Posted August 6, 2021 Share Posted August 6, 2021 So I have some Dimond Warding files which are getting clogged. Unlike the normal likes with I can easily unclog with pins and knives I can't find a method for removing the clogged material. Any advice please. Gondor Link to comment Share on other sites More sharing options...
Head in the clouds. Posted August 7, 2021 Share Posted August 7, 2021 What material are we trying to remove? Link to comment Share on other sites More sharing options...
Gondor44 Posted August 7, 2021 Author Share Posted August 7, 2021 Vallejo Plastic Putty 70.401 which the tube says is 100% Acrylic Resin. I had used it to fill seam joints in my Airfix new Vulcan intakes and used semi circular and round warding files to get rid of the excess. On a side note, is this Plastic Putty smothable with a wet brush? Gondor 1 Link to comment Share on other sites More sharing options...
bmwh548 Posted August 7, 2021 Share Posted August 7, 2021 I would try dipping them in some lacquer thinner and maybe using a brush to scrape the putty. Careful not to melt the handles. Link to comment Share on other sites More sharing options...
stevehnz Posted August 7, 2021 Share Posted August 7, 2021 4 minutes ago, Gondor44 said: On a side note, is this Plastic Putty smothable with a wet brush? Yes, or wet finger or cotton bud depending on location of course. Steve. 1 Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted August 7, 2021 Share Posted August 7, 2021 I suggest that you soak them in Flash or other multi-surface cleaner with ammonia. This dissolves and strips Vallejo and other acrylic paints. I don't see why it wouldn't shift acrylic putty. 1 Link to comment Share on other sites More sharing options...
Head in the clouds. Posted August 7, 2021 Share Posted August 7, 2021 Failing any of the above try filing something harder than what is clogging the teeth of the file, mild steel would work or PE fret . 1 Link to comment Share on other sites More sharing options...
Gondor44 Posted August 7, 2021 Author Share Posted August 7, 2021 19 minutes ago, bmwh548 said: I would try dipping them in some lacquer thinner and maybe using a brush to scrape the putty. Careful not to melt the handles. Sorry, don't have anything lacquer in the house 9 minutes ago, Head in the clouds. said: Failing any of the above try filing something harder than what is clogging the teeth of the file, mild steel would work or PE fret . This type of file dosent have normal teeth or I would have been able to deal with it. I have a small carding brush bought from a wool shop a long time ago which usually cleans out must gunk from my normal files, the tougher stuff I use an ild pencil, that had a terrible lead that kept breaking, I replaced the leat at the pointed end with a pin held in place with superglue. There are also knives to get between teeth of a file but these Diamond warding files are different and look as if the Diamond is just scattered on the surface in no particular order. Gondor Link to comment Share on other sites More sharing options...
Head in the clouds. Posted August 8, 2021 Share Posted August 8, 2021 10 hours ago, Gondor44 said: Diamond warding files are different and look as if the Diamond is just scattered on the surface in no particular order Yes, I have some diamond tools tool. The same principle should work though, the harder material acting like a rasp clearing softer material, I often get my files clogged with soft materials at work and home and I do find I get some good results. Another option if you are able is to use a mini gas torch to burn away debris but not sure what effect this will have on the material bonding the diamond to the file body. I think a period of trial and error is the only way forward, it is not much use as is so maybe nothing to loose. Good luck. Link to comment Share on other sites More sharing options...
PhoenixII Posted August 8, 2021 Share Posted August 8, 2021 @Gondor44 An alternative would be a suede brush, or, if you need real heavy duty, try a wire brush. 1 Link to comment Share on other sites More sharing options...
Gondor44 Posted August 8, 2021 Author Share Posted August 8, 2021 1 hour ago, PhoenixII said: @Gondor44 An alternative would be a suede brush, or, if you need real heavy duty, try a wire brush. I will give that a go, no idea when though as I may or may not have one somewhere under the kitchen sink..... literally Gondor Link to comment Share on other sites More sharing options...
