David2703 Posted August 5, 2021 Share Posted August 5, 2021 Hi guys, I am slowly expanding my LAAF collection and now want to add a MiG-23bn. Now the problem is that no one seems to be making appropriate decals? The only option I know of is the recently reissued Italeri kit, however the decal sheet in the kit is lacking in that only a pair instead of the necessary four serial numbers are inlcuded. Thus, I am a bit hesitant to buy two of the horrible Italeri kits just for the decals. Does anyone know other sources for LAAF MiG-23bn numbers? Thanks & best, David Notice the repetition of the No. on the fin, making it necessary to either used 2 Italeri kits or possibly sources something like this somewhere else? I've been trying to match the font in my graphics programme but it is quite tough. 1 Link to comment Share on other sites More sharing options...
exdraken Posted August 5, 2021 Share Posted August 5, 2021 So I assume 1/48... My advice: First if you are concerned about accuracy, do NOT use the Italeri / ESCI plastic at all it has horrible shape... opt for the Trumpeter kit with the Coldwar Studio nose correction MiG-23 BN decals are generally rare. The scheme Utaleri chose is definitely attractive! Blackbird models released a Lybian sheet (pre-revolution though.. maybe numbers/ fonts can be taken from there. At least they are black or there is a Modelmakerdecal sheet for the -21.. https://www.modelhobbies.co.uk/model-maker-decals-148-mikoyan-mig-21-around-the-world---libya--48110-273620-p.asp Link to comment Share on other sites More sharing options...
GiampieroSilvestri Posted August 5, 2021 Share Posted August 5, 2021 The decal sheet of the new Italeri boxing of the Mig-23/Mig-27 is very good and for the price of around 25 Euro for the kit here in Germany you get markings for five very interesting aircraft and it costs not much more than just one decal sheet. Saluti Giampiero Link to comment Share on other sites More sharing options...
RidgeRunner Posted August 6, 2021 Share Posted August 6, 2021 Why not draw them and get them printed? It is easier and cheaper than you might think. Martin Link to comment Share on other sites More sharing options...
David2703 Posted August 6, 2021 Author Share Posted August 6, 2021 (edited) Thanks for your advice guys, 12 hours ago, exdraken said: First if you are concerned about accuracy, do NOT use the Italeri / ESCI plastic at all it has horrible shape... opt for the Trumpeter kit with the Coldwar Studio nose correction Blackbird models released a Lybian sheet (pre-revolution though.. maybe numbers/ fonts can be taken from there. At least they are black or there is a Modelmakerdecal sheet for the -21.. https://www.modelhobbies.co.uk/model-maker-decals-148-mikoyan-mig-21-around-the-world---libya--48110-273620-p.asp Yep, will not use the Italeri plastic, that was clear from the outset. Problem is that the font is rather specific. Thus, the Model Maker sheet and Blackbird sheets which I have here also are not really suitable. (Can recommend both though!) 9 hours ago, GiampieroSilvestri said: The decal sheet of the new Italeri boxing of the Mig-23/Mig-27 is very good and for the price of around 25 Euro for the kit here in Germany you get markings for five very interesting aircraft and it costs not much more than just one decal sheet. Which means that I will sadly have to get both or draw them as Martin suggested. While the Italeri kit decals and price are decent as is, I would need to get two kits to get the required four serial number decals - making this a way more expensive option. Sadly Italeri screwed up on the Libyan option. As for drawing, that idea crossed my mind also and I started playing with vector drawing yesterday, if you can recommend any specific font packages or stuff like that feel free, as this is still not an easy task. Thanks all for your input! Edited August 6, 2021 by David2703 1 Link to comment Share on other sites More sharing options...
exdraken Posted August 6, 2021 Share Posted August 6, 2021 to me those numbers are a rather good starting point, if size is ~ right! the 1 needs the upwards part added... though.... the "9"s are fine to go if you ask me! great project! Link to comment Share on other sites More sharing options...
RidgeRunner Posted August 6, 2021 Share Posted August 6, 2021 1 hour ago, David2703 said: Which means that I will sadly have to get both or draw them as Martin suggested. While the Italeri kit decals and price are decent as is, I would need to get two kits to get the required four serial number decals - making this a way more expensive option. Sadly Italeri screwed up on the Libyan option. As for drawing, that idea crossed my mind also and I started playing with vector drawing yesterday, if you can recommend any specific font packages or stuff like that feel free, as this is still not an easy task. Scan on sheet and then use it as the basis for the other, or just produce two sets so they look the same. I’m not expert on this but I know it can be done :). I’d then suggest either laser print yourself or use Arctic Decals in Finland. Martin 1 Link to comment Share on other sites More sharing options...
rossm Posted August 7, 2021 Share Posted August 7, 2021 Try looking through this thread for some sources for aviation related fonts - not just RAF 1 Link to comment Share on other sites More sharing options...
