Popular Post billn53 Posted August 3, 2021 Popular Post Share Posted August 3, 2021 I recently completed the seventh addition to my collection of Wisconsin Air National Guard aircraft, the OA-37B "Dragonfly", which left just two more aircraft to complete my project: the A-10A Thunderbolt II (a.k.a. "Warthog") and the O-1A Cessna Skymaster. I've never been a fan of the Skymaster, mainly because that's the aircraft the Wisconsin ANG was given when their F-102 Delta Daggers were taken away from them. Imagine, going from a supersonic hotrod to a pedestrian, prop-driven general aviation aircraft! But, that's what happened. In 1974 the Wisconsin ANG's 115th Fighter Group converted to the forward air control mission and became the 115th Tactical Air Support Group, trading in their Delta Daggers (top speed: Mach 1.22) for Cessna Skymasters (top speed: 200 mph). The group flew Skymasters until 1979, when they transitioned to the OA-37B "Dragonfly". My plan was to begin work on the A-10 as my next Wisconsin ANG model. However, a few aftermarket items I had ordered hadn't yet arrived, so I decided to do a quick build of the Airfix Skymaster sitting in my stash. My thought was, being a simple kit, I could get the Skymaster done in a few days (a week at most) and then start on the Warthog. No WIP, just build the Skymaster and post a quick RFI. Little did I suspect . . . Here's the kit: And a dog it turned out to be! Bear with me while I do some belly-aching (and feel free to bring out the violins!) For starters, the clear parts don't fit at all. The windscreen is too wide, the openings for the side and top deck window are much larger than the clear parts meant for them, and the windows on the lower right-side are pure trash (wrong shape, and too small for the fuselage openings). I ended up cutting a vertical slice from the windscreen, to narrow it down, and replaced the top deck with a new piece, for which I cut properly-sized openings. I also replaced the lower-right side of the fuselage with new styrene, and created correctly shaped & sized windows using clear UV acrylic: The twin booms are another problem area. They are supposed to fit into slots in the wing, but the slots are much too wide. I corrected this using styrene shims: Airfix's interior is for the four-seat civilian Skymaster. I removed the two rear seats and scratch built an electronics rack. Unhappily, not much of this can be seen through the kit's thick windows: Those are the biggest problem areas. The rest of my work consisted of adding details that are missing from the kit. I opened the forward engine air inlets, and made an inlet for the rear engine (the kit has this as a blank face): I lowered the flaps to match the photo at the top of this page of a Wisconsin ANG Skymaster on the ramp: I added landing/taxi lights on the wing leading edges, made from adhesive fingernail "gems" and packing tape: I used thin brass tubing to create exhausts for the two engines: I replaced the crude underwing pylons with better ones from the spares box. I used aftermarket items for the rocket pods, as the kit items were simply horrible: The fuselage top is bedecked with various antennae, which I added, along with PE fuel filler caps on the wings: The kit is missing the anti-collision beacon on the starboard fin, so I scratch built one using styrene rod and UV-activated acrylic gel, coated with transparent red paint, for the lens: I also used the UV gel to create the wingtip navigation lights and the clear lights at the rear of the fins: Lastly, I made a pitot tube from brass rod and a bit of styrene, to replace the kit's crudely-molded item: I painted my Skymaster with MRP Sky Grey paint and Mr. Base White 1000, referencing photos of Wisconsin ANG birds: While I was painting and masking, Airfix's iffy landing gear gave way. After gluing the broken pieces together, I added reinforcement using CA glue and baking soda. The result definitely isn't scale, but at least I have some peace of mind. Decals were mainly from the kit (this boxing has decals by Scale Masters, which performed beautifully even being decades old). I printed custom decals for the Wisconsin ANG, and also used a few decals from the spares box where needed. -------------------------------------------------------------------------------------------------- Now (if you're still with me), let's see the results of all that work! One more pic, this time in an appropriate setting: And finally, to give a sense of scale . . . . Thanks for viewing, and thanks to everyone who followed my build and gave me support during this challenging project. And, if you are interested, the details of the build are in my Work In Progress: 74 2 Link to comment Share on other sites More sharing options...
manuel Posted August 3, 2021 Share Posted August 3, 2021 Excellent work. 1 Link to comment Share on other sites More sharing options...
Pete in a shed Posted August 3, 2021 Share Posted August 3, 2021 Great work on this, you've produced a little masterpiece. Pete 1 Link to comment Share on other sites More sharing options...
billn53 Posted August 3, 2021 Author Share Posted August 3, 2021 Just now, Pete in a shed said: Great work on this, you've produced a little masterpiece. Pete Hardly a masterpiece — this one will never go to a contest (too many technical flaws), but I do have a place reserved for it in my display case. Link to comment Share on other sites More sharing options...
Andy Dyck Posted August 4, 2021 Share Posted August 4, 2021 Good heavens, you have nerves of steel. This is real modeling! Finally it turns out very nice. Congratulations ! Cheers Andy 2 Link to comment Share on other sites More sharing options...
Jackson Duvalier Posted August 4, 2021 Share Posted August 4, 2021 Your perseverance is admirable, Bill, as is your ingenuity. Told you it would turn out fine, didn't jinx you at all. 🤩 1 Link to comment Share on other sites More sharing options...
dnl42 Posted August 4, 2021 Share Posted August 4, 2021 Very will done! The result is all the more impressive for the effort and determination this model needed. 1 Link to comment Share on other sites More sharing options...
Bandsaw Steve Posted August 4, 2021 Share Posted August 4, 2021 Very nice, and much smaller than I imagined. Great job! 1 Link to comment Share on other sites More sharing options...
Bertie McBoatface Posted August 4, 2021 Share Posted August 4, 2021 What an uphill struggle that was! Fine results. 1 Link to comment Share on other sites More sharing options...
Vultures1 Posted August 4, 2021 Share Posted August 4, 2021 That's excellent modelling, especially given all the shortcomings of the base kit. Great attention to detail too - well done! 1 1 Link to comment Share on other sites More sharing options...
RidgeRunner Posted August 4, 2021 Share Posted August 4, 2021 Beautifully dine, Bill :). She put up a fight but you managed to tame her - in some style! Martin 1 Link to comment Share on other sites More sharing options...
noelh Posted August 4, 2021 Share Posted August 4, 2021 Well you did a great job considering the base material. I remember the kit as part of a slightly implausible Airfix Vietnam Dogfight Double with a Mig 21. In fact highly implausible. I have a slight issue with your comment about the conversion from Delta Daggers to 0-2s. Certainly some pilots might have been horrified but remember in Vietnam many FAC pilots came from fast jets and found it to be real seat of the pants flying, low level down in the weeds. Particularly compared to the highly structured strategic intercept mission the Daggers performed. I say that but I'd choose the jet too. But believe me hauling around an aircraft the size of the Cessna at low level is a ball. Wouldn't it be nice if someone brought out an up to date 0-2? 2 Link to comment Share on other sites More sharing options...
billn53 Posted August 4, 2021 Author Share Posted August 4, 2021 25 minutes ago, noelh said: But believe me hauling around an aircraft the size of the Cessna at low level is a ball. I totally agree. I fly a Cessna 172SP in real life, and would love the opportunity to fly a Skymaster. On the other hand, if I were given the choice to fly either a Cessna, or a supersonic fighter, I’d definitely choose the hotrod. Link to comment Share on other sites More sharing options...
Knight_Flyer Posted August 6, 2021 Share Posted August 6, 2021 I reckon you've done an excellent job. The tooling itself is ancient dating back to the 70s or may even be the 60s? No surprises it's not an easy build. Thing about the kit though, it does on UK ebay auction go for imo crazy prices. Mainly heading towards £20 or $27 USD. Throw in another £5 and you can have a new tool big model Airfix Buccaneer Link to comment Share on other sites More sharing options...
billn53 Posted August 6, 2021 Author Share Posted August 6, 2021 13 minutes ago, Knight_Flyer said: Thing about the kit though, it does on UK ebay auction go for imo crazy prices. Mainly heading towards £20 or $27 USD. Tell me about it! And, the ARII kit (marginally worse than Airfix) isn’t any cheaper, sometimes even more. Link to comment Share on other sites More sharing options...
russ c Posted August 7, 2021 Share Posted August 7, 2021 Great job on that old kit, really nice work 1 Link to comment Share on other sites More sharing options...
Booty003 Posted August 7, 2021 Share Posted August 7, 2021 That is superb Bill. I have the old Airfix dogfight set (this and a MiG-21). I haven't even looked at the O-2 but seeing yours come to life has made me realise that it will be sitting in the box for some time yet....!!! That is quite some work that you've put in to make it look respectable. Phil 1 Link to comment Share on other sites More sharing options...
billn53 Posted August 7, 2021 Author Share Posted August 7, 2021 Just now, Booty003 said: That is superb Bill. I have the old Airfix dogfight set (this and a MiG-21). I haven't even looked at the O-2 but seeing yours come to life has made me realise that it will be sitting in the box for some time yet....!!! That is quite some work that you've put in to make it look respectable. Phil Thank you, Phil. I have another Airfix Skymaster sitting in my stash. Having built this one, and seeing all the things I could have done to make it better, I’m tempted to do it again and take the proper time at it. But, that’s for another day… or year… or decade. Maybe even, another life! 1 Link to comment Share on other sites More sharing options...
Alpha Delta 210 Posted August 7, 2021 Share Posted August 7, 2021 Your skill (and excellent eyesight!) have turned a sow's ear into a silk purse! Amazing work! 1 Link to comment Share on other sites More sharing options...
billn53 Posted August 8, 2021 Author Share Posted August 8, 2021 17 hours ago, Alpha Delta 210 said: Your skill (and excellent eyesight!) have turned a sow's ear into a silk purse! Amazing work! Excellent eyesight? Well.... I used to be near-sighted, and had to take my glasses off to do modeling. Then, I had cataract surgery, which gave me excellent far vision (20-10) but terrible vision up close. I use 2.25-strength reading glasses for computer work. But, for modeling, I need stronger glasses. 3.25 when airbrushing, 4.5 for "normal" building, and 6.0 for the really close-in detailing: Also, a bright light is essential when working at the higher powers: 4 Link to comment Share on other sites More sharing options...
Dermo245 Posted August 8, 2021 Share Posted August 8, 2021 Holy Shmoly, that’s class. Link to comment Share on other sites More sharing options...
CMSCHLOM Posted August 8, 2021 Share Posted August 8, 2021 Really nice job!! Hope to see you at NIMCOM next month. 1 Link to comment Share on other sites More sharing options...
billn53 Posted August 8, 2021 Author Share Posted August 8, 2021 5 minutes ago, CMSCHLOM said: Really nice job!! Hope to see you at NIMCOM next month. I hope to make it, but I may be travelling that week. 1 Link to comment Share on other sites More sharing options...
bigbadbadge Posted August 8, 2021 Share Posted August 8, 2021 What a cracking job , your efforts have been rewarded with a fantastic model. It looks amazing. Chris 1 Link to comment Share on other sites More sharing options...
billn53 Posted August 8, 2021 Author Share Posted August 8, 2021 Just now, bigbadbadge said: What a cracking job , your efforts have been rewarded with a fantastic model. It looks amazing. Chris Many thanks, Chris! 1 Link to comment Share on other sites More sharing options...
