MBM Posted July 29, 2021 Share Posted July 29, 2021 Hi all, Just a quick question about thinning Revell aqua paints and their compatibility with Mr Leveling Thinner. Revel 371 is the perfect colour for airliner wings, and I really want to be able to put it on in thin layers but have never had much luck/the control when thinning them with acrylic thinners. I have tried thinning it down with Mr Color Leveling Thinner, about 25% paint to 75% thinner and got very mixed results. A couple of times it has gone on like a dream, thin smooth coats with the control I want but recently whenever I've tried thinning it down and then spraying it comes out in little spoldges and not in a mist and I have no idea what is going on. I've been thinking that the paint might be drying in the air before it hits the model but that's never happened with the Mr Thinner before. Are Revell Aqua Paints (and Vallejo acrylics come to think of it) and Leveling Thinner simply not compatible with each other or am I doing something wrong? I'm just really confused as to why it worked fine one day and then not from then on so any help would be greatly appreciated, I have a VC10 and 2x 767's in desperate need of paint!! Many thanks, M Link to comment Share on other sites More sharing options...
spruecutter96 Posted July 29, 2021 Share Posted July 29, 2021 Not trying to be a smart-bottom here, but the "perceived wisdom" is that most paints should only be thinned with that same manufacturer's thinner and if they work well with other maker's thinners, then that is an added bonus. The original manufacturer's thinner formula has been developed for that job exclusively. Anything made by another firm could have who-knows-what-in-it. The formula could be made to combine well with "Ingredient X", but will not play well with paint that lack "X". The assumption that a second maker's formulation should work with your paints is a pretty bold one. This is not meant to be condescending or aggravating - but I fully understand that if it's read in the wrong "tone" it could come across that way. It is purely intended as friendly advice (nothing more). Hope this helps. Chris. 5 Link to comment Share on other sites More sharing options...
treker_ed Posted July 29, 2021 Share Posted July 29, 2021 3 hours ago, MBM said: Hi all, Just a quick question about thinning Revell aqua paints and their compatibility with Mr Leveling Thinner. Revel 371 is the perfect colour for airliner wings, and I really want to be able to put it on in thin layers but have never had much luck/the control when thinning them with acrylic thinners. I have tried thinning it down with Mr Color Leveling Thinner, about 25% paint to 75% thinner and got very mixed results. A couple of times it has gone on like a dream, thin smooth coats with the control I want but recently whenever I've tried thinning it down and then spraying it comes out in little spoldges and not in a mist and I have no idea what is going on. I've been thinking that the paint might be drying in the air before it hits the model but that's never happened with the Mr Thinner before. Are Revell Aqua Paints (and Vallejo acrylics come to think of it) and Leveling Thinner simply not compatible with each other or am I doing something wrong? I'm just really confused as to why it worked fine one day and then not from then on so any help would be greatly appreciated, I have a VC10 and 2x 767's in desperate need of paint!! Many thanks, M Vallejo Acrylics are a type of polyurethane based acrylic paint - they don't react very nicely to other thinners and turn into a gloopy mess (found that out the hard way using their primers!!!!!). I used to used Revell, and managed to thin them using Tamiya X20A and also Ultimate Modelling Product Thinners. No problem at all using these to thin Revell. BUT..... do not use Tamiya to thin Vallejo. Tamiya paint and thinner is an alcohol (or such) based paint and thinner and will react badly with the Vallejo paint. As the post above says - ideally use Vallejo thinner or cleaner with Vallejo paints. 3 Link to comment Share on other sites More sharing options...
dnl42 Posted July 30, 2021 Share Posted July 30, 2021 1 hour ago, treker_ed said: Vallejo Acrylics are a type of polyurethane based acrylic paint - they don't react very nicely to other thinners and turn into a gloopy mess (found that out the hard way using their primers!!!!!). I too found this out the hard way. It was a complete mess to clean out my airbrush. Never again. Now, as @spruecutter96 noted, I'm a big fan of only thinning with the manufacturer's thinner or known good combinations. As I use Mr Color paints, MLT is by goto thinner--the combination is magnificent! If you do want to try some foreign thinner-paint combo, do so. But only in an easy-to-clean or disposable container, and let it sit. Try painting it with an easy-to-clean or disposable brush. Only if it still looks good and flows well should you try it in an airbrush. 1 Link to comment Share on other sites More sharing options...
Ray_W Posted July 30, 2021 Share Posted July 30, 2021 6 hours ago, MBM said: Are Revell Aqua Paints (and Vallejo acrylics come to think of it) and Leveling Thinner simply not compatible with each other or am I doing something wrong? I'm just really confused as to why it worked fine one day and then not from then on so any help would be greatly appreciated, I have a VC10 and 2x 767's in desperate need of paint!! I agree with the others and would not use Mr Color Leveling Thinner (MLT) with Revell Aqua. I find when using paint chemistries that work well with water as a thinner, such as Revell Aqua, try water as your first thinner of choice. You will need to thin more than you expect. Start with your 25% paint to 75% water (which still might be too much paint as Revell is quite thick) and build thin coats. I use Lifecolor this way and very happy with the results. Use deionised water if you like although I use just tap water. I have added a small amount of Windsor & Newton Flow Slo-Dri Retarder to water to make a pre-mix thinner to prevent tip dry. I have also used their Flow Aid with good results even though it is a different product. It does work. Others will recommend IPA and a range of other home brew solutions and yet water, for me, was best. These days I have largely moved away from water thinned paints for airbrushing. Far too variable although I still like them a lot for brush painting. Lacquers (Gunze, Tamiya LP, AK Real Color, MRP) and alcohol solvent aqueous paints like Gunze Mr Hobby Color and Tamiya (X and XF range) thinned with MLT or their proprietary brand thinners are now my go to paints. Ray Link to comment Share on other sites More sharing options...
Chimpion Posted July 30, 2021 Share Posted July 30, 2021 Revell do their own Aqua thinner which works well with these. It can be hard to find in stock but should be available on order. Link to comment Share on other sites More sharing options...
MBM Posted September 8, 2021 Author Share Posted September 8, 2021 On 29/07/2021 at 21:26, spruecutter96 said: Not trying to be a smart-bottom here, but the "perceived wisdom" is that most paints should only be thinned with that same manufacturer's thinner and if they work well with other maker's thinners, then that is an added bonus. The original manufacturer's thinner formula has been developed for that job exclusively. Anything made by another firm could have who-knows-what-in-it. The formula could be made to combine well with "Ingredient X", but will not play well with paint that lack "X". The assumption that a second maker's formulation should work with your paints is a pretty bold one. This is not meant to be condescending or aggravating - but I fully understand that if it's read in the wrong "tone" it could come across that way. It is purely intended as friendly advice (nothing more). Hope this helps. Chris. Hi Chris, Many thanks for your advice it's greatly appreciated and apologies for my late reply, moving city and work has put modelling on the backburner for a while! I completely see where you're coming from and thanks for your honesty its certainly taught me to try and stick with one paint brand so I'm not having to get lots of different thinners etc. I try to cross mix where I can to simply save money and this has worked well (more or less!) with acrylics but yes I agree it is bold to assume crossing brands would work. Many thanks, Mark Link to comment Share on other sites More sharing options...
spruecutter96 Posted September 9, 2021 Share Posted September 9, 2021 No problem at all, Mark. Good luck with your modelling endeavours. Chris. Link to comment Share on other sites More sharing options...
MBM Posted September 14, 2021 Author Share Posted September 14, 2021 On 30/07/2021 at 00:18, treker_ed said: Vallejo Acrylics are a type of polyurethane based acrylic paint - they don't react very nicely to other thinners and turn into a gloopy mess (found that out the hard way using their primers!!!!!). I used to used Revell, and managed to thin them using Tamiya X20A and also Ultimate Modelling Product Thinners. No problem at all using these to thin Revell. BUT..... do not use Tamiya to thin Vallejo. Tamiya paint and thinner is an alcohol (or such) based paint and thinner and will react badly with the Vallejo paint. As the post above says - ideally use Vallejo thinner or cleaner with Vallejo paints. Hi! Many thanks for your advice and apologies for my slow reply. I will bare the above in mind, I think a huge takeaway from this is don't thin Revell or Vallejo with anything other than their own brand thinners. Many thanks, M Link to comment Share on other sites More sharing options...
MBM Posted September 14, 2021 Author Share Posted September 14, 2021 On 30/07/2021 at 01:33, dnl42 said: I too found this out the hard way. It was a complete mess to clean out my airbrush. Never again. Now, as @spruecutter96 noted, I'm a big fan of only thinning with the manufacturer's thinner or known good combinations. As I use Mr Color paints, MLT is by goto thinner--the combination is magnificent! If you do want to try some foreign thinner-paint combo, do so. But only in an easy-to-clean or disposable container, and let it sit. Try painting it with an easy-to-clean or disposable brush. Only if it still looks good and flows well should you try it in an airbrush. Hi, Many thanks for your advice, having read your comment and experimenting myself I would agree 100% that I'll only use paints and their own brand thinner. The interesting thing is that the Revell and MLT mix, massively thinned though, seemed to look like it would flow well through an airbriush but it spits in a very weird way out of the nozzle and doesn't create a smooth layer, more of a mottled effect. Many thanks, M Link to comment Share on other sites More sharing options...
MBM Posted September 14, 2021 Author Share Posted September 14, 2021 On 30/07/2021 at 04:50, Ray_W said: I agree with the others and would not use Mr Color Leveling Thinner (MLT) with Revell Aqua. I find when using paint chemistries that work well with water as a thinner, such as Revell Aqua, try water as your first thinner of choice. You will need to thin more than you expect. Start with your 25% paint to 75% water (which still might be too much paint as Revell is quite thick) and build thin coats. I use Lifecolor this way and very happy with the results. Use deionised water if you like although I use just tap water. I have added a small amount of Windsor & Newton Flow Slo-Dri Retarder to water to make a pre-mix thinner to prevent tip dry. I have also used their Flow Aid with good results even though it is a different product. It does work. Others will recommend IPA and a range of other home brew solutions and yet water, for me, was best. These days I have largely moved away from water thinned paints for airbrushing. Far too variable although I still like them a lot for brush painting. Lacquers (Gunze, Tamiya LP, AK Real Color, MRP) and alcohol solvent aqueous paints like Gunze Mr Hobby Color and Tamiya (X and XF range) thinned with MLT or their proprietary brand thinners are now my go to paints. Ray Hi Ray, Many thanks for your advice and apologies for my late reply. When I started airbrushing I did use water as a thinner (I wasn't risking using enamels/lacquers in an airbrush back then) firstly I never thinned it enough which didn't help but I found living in the South-East with the hard water the minerals sometimes reacted with the paint and produced some really odd effects. So yes I will look into deionised water, however it seems Xtracolor (Hannants) thinner works well with the Revell Aqua. I think I will start to move away from acrylics and only use them when absolutely necessary as they do seem a lot less reliable than the lacquers. Many thanks, Mark On 30/07/2021 at 13:35, Chimpion said: Revell do their own Aqua thinner which works well with these. It can be hard to find in stock but should be available on order. Hi, Thanks, yes I agree its hard to find these days although from what I remember Wonderland Models still sells it, costs a lot compared to other thinners though for the amount you get! Many thanks, Mark Link to comment Share on other sites More sharing options...
