Julien Posted July 17, 2021 Share Posted July 17, 2021 Junkers Ju 88A/C Life Boat (7468) 1:72 CMK by Special Hobby There is a large group of modellers who like to open up all areas of their models and add extra detail and this set for the life raft container in the rear fuselage of the Ju 88 will appeal to them. This set from CMK is suitable for the Revell kits. The set arrives in the usual yellow-themed CMK blister pack, with the instructions sandwiched between the resin parts and the header card. Inside are three resin parts on two casting blocks, consisting of the housing. the raft and the access door. The casting is up to the usual high standards from CMK/Special Hobby with minimal clean up being needed. The housing is very thin and car will be needed if you want to remove the casting block, though as this will be inside the fuselage there is not real need. Conclusion Detail is excellent, with some work this will give your model a little extra realism on top of that already provided. Review sample courtesy of Link to comment Share on other sites More sharing options...
