Painting raised text on plastic
FrankJ
Not really sure where I should post this question as I'm in the middle of building  Yamaha xv100 Virago motor bike which I know should be in vehicles forum but as my question relates to a method of painting I thought I'd try here first.
The picture below is supposed to be painted with semi-Gloss Black but the writing (Virago) to be to  be painted in Gold Leaf which will need a fine point brush which I have, the logo on the fuel tank was bad enough but this seems impossible, I can barely read it let alone paint it. I'm using Tamiya paints.
Anyone have a tip to highlight the writing or forget it and paint the lot simi gloss black?
Decals would have been better in this case.🙄
Hi Frank,
I also have not tried their gold. It seems a simple solution. Although if it was me I would be using a Kolinksky Sable brush, a No.1 to hold paint yet still superfine tip and Gunze metallics.
Ray
You could always paint the logo first, then paint the background, and while it's still wet, wipe off the new paint to expose the chrome/gold.  You might have to put a clear acrylic varnish between layers if you're using enamels, but you get the idea :)
Speaking personally, I'd use a 000 W&N Series 7 to very carefully paint it by hand, but then I've always been a glutton for punishment ^_^
I'm with you Mike but use bigger Kolinkskys because they keep an exceptionally fine tip and plenty of body in the brush. I love my Kolinkskys almost as much as my Iwatas.
